jhoon12.cho
Please let me know how to set petalinux to zc706
I have zc706 board.
I know that zc706 board can use two cores without special FPGA image.
I want to upload linux OS to zc706.
Please let me know some guide to set linux OS environment to zc706 board.
Thank you.
hpoetzl
Voyager
Voyager
Hey @jhoon12.cho,
Check out the Prepare Boot Medium wiki page.
Hope this helps,
Herbert
-------------- Yes, I do this for fun!
florentw
Hi @jhoon12.cho,
You can follow the tutorial from UG1156. The main difference on petalinux between the xilinx board is the BSP you have to download from xilinx webpage.
Then you just have to follow the tutorial
Hope that helps,
Florent
Florent
