Poor glmark2 score on ZCU104 (2018.2) with X11
we're working with a ZCU104 board, our plan is to use Qt5 with FBdev in future. The first tests we startet with the default settings in petalinux with the provided ZCU104 board BSP (inclusive X11, with some adaptions, see below)
Problem: We see a poor openGL performance with X11.
We've cross compiled glmark2 for Ultrascale+
Start application: glmark2-es2
    glmark2 2017.07
    OpenGL Information
    GL_VENDOR:     ARM
    GL_RENDERER:   Mali-400 MP
    GL_VERSION:    OpenGL ES 2.0 "ee3a815"
[build] use-vbo=false: FPS: 2 FrameTime: 500.000 ms
[build] use-vbo=true: FPS: 3 FrameTime: 333.333 ms
[loop] fragment-steps=5:fragment-uniform=false:vertex-steps=5: FPS: 2 FrameTime: 500.000 ms
[loop] fragment-steps=5:fragment-uniform=true:vertex-steps=5: FPS: 2 FrameTime: 500.000 ms
                                  glmark2 Score: 2
[Full logfile see attached: glmark2.log]
If we start glmark2-es2 --off-screen we get a better result:
glmark2 2017.07
OpenGL Information
GL_VENDOR: ARM
[build] use-vbo=false: FPS: 350 FrameTime: 2.857 ms
[build] use-vbo=true: FPS: 391 FrameTime: 2.558 ms
[texture] texture-filter=nearest: FPS: 483 FrameTime: 2.070 ms
[loop] fragment-loop=false:fragment-steps=5:vertex-steps=5: FPS: 226 FrameTime: 4.425 ms
[loop] fragment-steps=5:fragment-uniform=false:vertex-steps=5: FPS: 226 FrameTime: 4.425 ms
[loop] fragment-steps=5:fragment-uniform=true:vertex-steps=5: FPS: 226 FrameTime: 4.425 ms
glmark2 Score: 239
[Full logfile see attached: glmark2.offscreen.log]
Question: Is there any issue with X11 in combination mit the Mali Lib?
Thanks for any help!
Best Regards
Petalinux build with following configuration:
BSP: xilinx-zcu104-v2018.2-final.bsp
Config rootfs:
Filesystem Packages-> libs-> libmali-xlnx-> libmali-xlnx         => enable
Filesystem Packages-> libs-> libmali-xlnx-> libmali-xlnx-dev     => enable
Filesystem Packages-> Petalinux Package Groups -> packagegroup-petalinux-v4lutils -> packagegroup-petalinux-v4lutils => disable (otherwise build errors)
Filesystem Packages-> Petalinux Package Groups -> packagegroup-petalinux-qt -> packagegroup-petalinux-qt => enable
Petalinux Package Group -> packagegroup-petalinux-benchmarks     => enable
