ritanagar
Porting linux kernel on ML410 Virtex4
hi,
I aleady done porting on ML507 , but doing in ML410 .But whatever procedure given in different  for ML410,every body used Montavista.I m using virtex4-ML410 board on RHEL5 system with Xilinx12.2.I taken linux_2_6 on OS support in Xilinx and then generate lib. and BSP.the xparameters_ml410.h generated.I copied in linux_kernel_directory (ppc/boot/platforms/xparameters/).I m taking linux-2.6.10 linux kernel.I created Image also.But whenever I run zImage.initrd.elf it shows error ---
cable locked --trying
Plz someboby help me where I m wrong.
Is the Image I made is wrong or some other problem.
Thanks , Plz
Anonymous
Not applicable
If the cable is locked, try running xclean_cablelock from the XMD prompt and then try your download again.
Anonymous
Not applicable
ritanagar
Ya I tried that,its shows like this -
RUNNING>XMD%
Cable locked.........Keep trying
Is there anything wrong with the ML410 Image.
Anonymous
Not applicable
I don't think that it's an image problem - it's most likely a cable problem. Is there another software tool using the cable? Impact or chipscope?  Are you using windows or linux? Have you tried unplugging the cable?
Terry
ritanagar
Thanks sir for quick response.
I done image creation work on RHEL5 system with Xilinx 12.2, linux_2_6 as OS Platfort Support.
I am running that application in windows Xilinx 9.1,first I m downloading download.bit using Impact tool after that I m running zImage.initrd.elf in XMD.I also remove the cable but nothing happened.
I m taking kernel 2.6.10 .I download.bit I m taking default:ppc405_0_bootloop as Mark Initial BRAM as my zImage.initrd.elf will be in different folder of linux kernel.So .bit will not display anything on Hyperterminal.Similar work I done for ML507 and it was working.
Plz help me to correct this problem.Is I m taking wrong kernel version?or what can be this issue?
