10-27-2017 07:51 AM
Hi all,
I'm just starting with PetaLinux and I don't seem to get my head around the various resulting images. The prebuilt/linux directory contains the following files:
-rw-rw-r-- 1 user user 2.1M Oct 26 16:29 BOOT.BIN -rw-r--r-- 1 user user 18K Oct 26 16:29 system.dtb -rw-r--r-- 1 user user 2.1M Oct 26 16:29 System.map.linux -rw-r--r-- 1 user user 2.7M Oct 26 16:29 u-boot.elf -rw-r--r-- 1 user user 9.0M Oct 26 16:29 zImage -rw-r--r-- 1 user user 146K Oct 26 16:29 zynq_fsbl.elf
Most tutorials state that BOOT.BIN is the only image I need to flash. But I don't believe this since it obviously bigger than u-boot and zImage, even though zImage is already compiled.
Could someone explain what the different files are (specifically boot.bin, *.dtb, *.linux)?
There's a custom flash chip present on the board to which I need to flash the zImage, since the standard flash is not big enough right?
10-30-2017 12:00 AM
hi,
As rightly pointed out by Jeff,
Boot.bin contains fsbl, bitstream and uboot
And this is a bootable image , which should be copied to your flash media like, qspi or sd
After you switch to the required boot mode settings on your board, you should be able to get the uboot prompt on the serial console.
So, your first stage and second stage boot loader are now UP
From uboot, inorder to bring Linux , you need
Root file system, device tree (.dtb) and your Linux image
FIT image is one, which contains all the three in the form of image.ub
Otherwise , each of these needs to be copied to ddr or tftp and then copy to your flash using uboot commands
Wiki provides a clean explanations to these
http://www.wiki.xilinx.com/Zynq2017.3+Release
Madhubala
10-27-2017 10:21 AM
the boot.bin will contain the fsbl, bit file and u-boot. If on ultrascale it will also have pmu and atf files in it. zimage is the compressed kernel and the dtb is the device tree for the kernel. Some of the file in your directory are just for reference, for example u-boot is already in the boot.bin.
I'm not sure what directory you are looking at but I don't see a rootfs file unless you have a FIT image which combines the kernel and rootfs. However, those usually have a .ub suffix. I would expect to see a cpio or gz file for the rootfs.
jeff
10-30-2017 12:00 AM
hi,
Madhubala
10-31-2017 09:00 AM
Thank you both! Helped me a lot.
I found more images in images/linux
-rw-r--r-- 1 user user 2083850 Oct 31 16:17 project_wrapper.bit -rw-rw-r-- 1 user user 14622936 Oct 31 16:27 BOOT.BIN -rw-r--r-- 1 user user 9248984 Oct 31 16:26 image.ub -rw-r--r-- 1 user user 11412480 Oct 31 16:26 rootfs.cpio -rw-r--r-- 1 user user 5486731 Oct 31 16:26 rootfs.cpio.gz -rw-r--r-- 1 user user 5499538 Oct 31 16:26 rootfs.tar.gz -rw-r--r-- 1 user user 18427 Oct 31 16:18 system.dtb -rw-r--r-- 1 user user 2166859 Oct 31 16:21 System.map.linux -rw-r--r-- 1 user user 343172 Oct 31 16:19 u-boot.bin -rw-r--r-- 1 user user 2794712 Oct 31 16:19 u-boot.elf -rw-r--r-- 1 user user 11359540 Oct 31 16:21 vmlinux -rw-r--r-- 1 user user 9205704 Oct 31 16:21 zImage -rw-r--r-- 1 user user 149068 Oct 31 09:26 zynq_fsbl.elf
What's included is very clear to me now.
Also I'm now using petalinux-package --boot --fpga --u-boot --kernel to create a single bin file containing all components. I'm using the flash utility of the XSDK 2015.4 (since 2017 asks for a separate FSBL file, and fails on the verifying step) to flash the bin file successfully.
