Visitor mwedret
Prebuilt BOOT.BIN
I am working with Ultrascale.  Will the pre-built FSBL and u-boot work correctly with the my compiled petalinux kernel?  I build the image.ub and BOOT.BIN.  The BOOT.BIN is wrong so the firmware team is suggesting I just use the prebuilt BOOT.BIN.  The prebuilt BOOT.BIN is created when the project is created based on the bsp.  Will the prebuilt BOOT.BIN work with my compiled image.ub?
Re: Prebuilt BOOT.BIN
HI @mwedret
Yes , this BSP prebuild BOOT.BIN will work with your image.ub, if you are not interested to change anything in fsbl or u-boot.
Is this custom board or zcu102 Eval board, if it is custom board & if it ia having any design diffrences then it may not work.
Thanks & eragdrs
Aarvind
HI @mwedret
Thanks & eragdrs
Aarvind
