Problem booting SP605, ISE 13.1 AXI4 reference design from SPI flash
I'm trying to follow/modify the procedure from XAPP1146; Embedded Platform Software and Hardware In-the-Field Upgrade Using Linux; to boot the ISE 13.1 AXI4 reference design from SPI flash and linux is not mounting the /dev/mtd partitions.  I need help from someone with more than my very limited experience.
Steve
I've attatched the modified dts file which has the mtdparts in the bootargs section added.
Here is the console output,
early_printk_console is enabled at 0x84001000
Ramdisk addr 0x00000003, Compiled-in FDT at 0xc021b188
Linux version 2.6.37-00715-gf5f5376-dirty (shoaf@xray-vm-rhel6.aps.anl.gov) (gcc
 version 4.1.2) #23 Fri Jul 1 09:27:38 CDT 2011
setup_cpuinfo: initialising
setup_cpuinfo: Using full CPU PVR support
cache: wt_msr_noirq
setup_memory: max_mapnr: 0x8000
setup_memory: min_low_pfn: 0x40000
setup_memory: max_low_pfn: 0x48000
On node 0 totalpages: 32768
free_area_init_node: node 0, pgdat c02a3894, node_mem_map c0441000
  Normal zone: 256 pages used for memmap
  Normal zone: 0 pages reserved
  Normal zone: 32512 pages, LIFO batch:7
pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
pcpu-alloc: [0] 0
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 32512
Kernel command line: console=ttyS0 ip=192.168.1.10 mtdparts=spi32766.0:1452k(bit
s),6612k(zImage),128k(loader)
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 125416k/131072k available
NR_IRQS:32
xlnx,xps-intc-1.00.a #0 at 0xc8000000, num_irq=7, edge=0x8
xlnx,xps-timer-1.00.a #0 at 0xc8004000, irq=3
microblaze_timer_set_mode: shutdown
microblaze_timer_set_mode: periodic
Calibrating delay loop... 98.04 BogoMIPS (lpj=196096)
Mount-cache hash table entries: 512
XGpio: /axi@1/gpio@81440000: registered
XGpio: /axi@1/gpio@81420000: registered
XGpio: /axi@1/gpio@81400000: registered
Switching to clocksource microblaze_clocksource
microblaze_timer_set_mode: oneshot
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Skipping unavailable RESET gpio -2 (reset)
GPIO pin is already allocated
JFFS2 version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
msgmni has been set to 244
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
84000000.serial: ttyS0 at MMIO 0x84001000 (irq = 6) is a 16550
console [ttyS0] enabled
48000000.flash: Found 1 x16 devices at 0x0 in 16-bit bank. Manufacturer ID 0x000
089 Chip ID 0x008919
Intel/Sharp Extended Query Table at 0x010A
Using buffer write method
Using auto-unlock on power-up/resume
cfi_cmdset_0001: Erase suspend on write enabled
erase region 0: offset=0x0,size=0x20000,blocks=255
erase region 1: offset=0x1fe0000,size=0x8000,blocks=4
RedBoot partition parsing not available
m25p80 spi32766.0: found s25fl064k, expected m25p80
m25p80 spi32766.0: s25fl064k (8192 Kbytes)
3 cmdlinepart partitions found on MTD device spi32766.0
Creating 3 MTD partitions on "spi32766.0":
0x000000000000-0x00000016b000 : "bits"
0x00000016b000-0x0000007e0000 : "zImage"
0x0000007e0000-0x000000800000 : "loader"
xilinx_spi 83400000.spi: at 0x83400000 mapped to 0xc80c0000, irq=4
Xilinx Axi Ethernet MDIO: probed
Device Tree Probing 'i2c'
xilinx-iic #0 at 0x81600000 mapped to 0xCA120000, irq=5
at24 0-0054: 1024 byte 24c08 EEPROM (writable)
TCP cubic registered
Freeing unused kernel memory: 1566k freed
Starting rcS...
++ Mounting filesystem
++ Starting telnet daemon
rcS Complete
/bin/sh: can't access tty; job control turned off
/ # cat /proc/mtd
dev:    size   erasesize  name
mtd0: 02000000 00020000 "48000000.flash"
mtd1: 0016b000 00001000 "bits"
mtd2: 00675000 00001000 "zImage"
mtd3: 00020000 00001000 "loader"
/ # flash_eraseall /dev/mtd1
flash_eraseall: can't open '/dev/mtd1': No such file or directory
/ # ls /dev
console  mem      ptyp0    ram      tty0     tty3     ttyUL0   ttyp2
i2c      null     ptyp1    random   tty1     tty4     ttyp0    xsa1
loop     ptmx     ptyp2    tty      tty2     ttyS0    ttyp1    zero
