Problem booting kernel when migrating from arch=ppc to arch=powerpc
 for a long time we have had an 2.6.24-rc3 based ml403 product working flawlessly. Now, in order to be able to use newer versions of the kernel and IP cores from Xilinx we are trying to migrate to arch=powerpc, but we are having some problems. First, after checking that OPB and the hard_temac core have been deprecated we have decided to go purely to PLBv4.6 and we are trying to put a basic ml403 ( systemace, ethernetlite) up and running with the stable git of linux-2.6-xlnx ( xilinx.wikidot.com ) .
 I have created the .dts with the current "device-tree" gen and I have compared with the reference virtex405-ml405.dts from the kernel tree and I have added some boot parameters while making sure the stdoutput goes to the uarlite core. This is what it says:
/dts-v1/;
#address-cells = <1>;
#size-cells = <1>;
compatible = "xlnx,virtex405", "xlnx,virtex";
model = "testing";
DDR_SDRAM: memory@0 {
device_type = "memory";
reg = < 0x0 0x4000000 >;
alias {
ethernet0 = &Ethernet_MAC;
serial0 = &RS232_Uart;
chosen {
bootargs = "console=ttyUL0 root=/dev/xsa2 noinitrd rootfstype=ext3 rw";
linux,stdout-path = "/plb@0/serial@84000000";
cpus {
#cpus = <0x1>;
#size-cells = <0>;
ppc405_0: cpu@0 {
clock-frequency = <300000000>;
compatible = "PowerPC,405", "ibm,ppc405";
d-cache-line-size = <0x20>;
d-cache-size = <0x4000>;
dcr-access-method = "native";
dcr-controller ;
device_type = "cpu";
i-cache-line-size = <0x20>;
i-cache-size = <0x4000>;
model = "PowerPC,405";
reg = <0>;
timebase-frequency = <300000000>;
xlnx,apu-control = <0xde00>;
xlnx,apu-udi-1 = <0xa18983>;
xlnx,apu-udi-2 = <0xa38983>;
xlnx,apu-udi-3 = <0xa589c3>;
xlnx,apu-udi-4 = <0xa789c3>;
xlnx,apu-udi-5 = <0xa98c03>;
xlnx,apu-udi-6 = <0xab8c03>;
xlnx,apu-udi-7 = <0xad8c43>;
xlnx,apu-udi-8 = <0xaf8c43>;
xlnx,deterministic-mult = <0x0>;
xlnx,disable-operand-forwarding = <0x1>;
xlnx,fastest-plb-clock = "DPLB0";
xlnx,generate-plb-timespecs = <0x1>;
xlnx,mmu-enable = <0x1>;
xlnx,pvr-high = <0x0>;
xlnx,pvr-low = <0x0>;
plb: plb@0 {
#size-cells = <1>;
compatible = "xlnx,plb-v46-1.03.a", "simple-bus";
ranges ;
Ethernet_MAC: ethernet@81000000 {
compatible = "xlnx,xps-ethernetlite-2.00.b", "xlnx,xps-ethernetlite-1.00.a";
device_type = "network";
interrupt-parent = <&xps_intc_0>;
interrupts = < 1 0 >;
local-mac-address = [ 02 00 00 00 00 00 ];
reg = < 0x81000000 0x10000 >;
xlnx,duplex = <0x1>;
xlnx,family = "virtex4";
xlnx,rx-ping-pong = <0x0>;
xlnx,tx-ping-pong = <0x0>;
LEDs_4Bit: gpio@81440000 {
compatible = "xlnx,xps-gpio-1.00.a";
reg = < 0x81440000 0x10000 >;
xlnx,all-inputs = <0x0>;
xlnx,all-inputs-2 = <0x0>;
xlnx,dout-default = <0x0>;
xlnx,dout-default-2 = <0x0>;
xlnx,gpio-width = <0x4>;
xlnx,interrupt-present = <0x0>;
xlnx,is-bidir = <0x1>;
xlnx,is-bidir-2 = <0x1>;
xlnx,is-dual = <0x0>;
xlnx,tri-default = <0xffffffff>;
xlnx,tri-default-2 = <0xffffffff>;
LEDs_Positions: gpio@81400000 {
reg = < 0x81400000 0x10000 >;
xlnx,gpio-width = <0x5>;
Push_Buttons_Position: gpio@81420000 {
interrupts = < 3 2 >;
reg = < 0x81420000 0x10000 >;
xlnx,all-inputs = <0x1>;
xlnx,interrupt-present = <0x1>;
RS232_Uart: serial@84000000 {
clock-frequency = <100000000>;
compatible = "xlnx,xps-uartlite-1.00.a";
current-speed = <57600>;
device_type = "serial";
port-number = <0>;
reg = < 0x84000000 0x10000 >;
xlnx,baudrate = <0xe100>;
xlnx,data-bits = <0x8>;
xlnx,odd-parity = <0x0>;
xlnx,use-parity = <0x0>;
SysACE_CompactFlash: sysace@83600000 {
compatible = "xlnx,xps-sysace-1.00.a";
interrupts = < 2 2 >;
reg = < 0x83600000 0x10000 >;
xlnx,mem-width = <0x10>;
xps_bram_if_cntlr_1: xps-bram-if-cntlr@ffffe000 {
compatible = "xlnx,xps-bram-if-cntlr-1.00.a";
reg = < 0xffffe000 0x2000 >;
xps_intc_0: interrupt-controller@81800000 {
#interrupt-cells = <0x2>;
compatible = "xlnx,xps-intc-1.00.a";
interrupt-controller ;
reg = < 0x81800000 0x10000 >;
xlnx,num-intr-inputs = <0x4>;
ppc405_0_dplb1: plb@1 {
#size-cells = <1>;
ranges ;
mpmc@0 {
#size-cells = <1>;
compatible = "xlnx,mpmc-4.03.a";
My problem is that the kernel gets stuck where you can see below:
zImage starting: loaded at 0x00400000 (sp: 0x005a5eb0)
Allocating 0x42a111 bytes for kernel ...
gunzipping (0x00000000 <- 0x0040d000:0x005a4363)...done 0x388520 bytes
Linux/PowerPC load: console=ttyUL0 root=/dev/xsa2 noinitrd rootfstype=ext3 rw
Finalizing device tree... flat tree at 0x5b2300
[ 0.000000] Using Xilinx Virtex machine description
[ 0.000000] Linux version 2.6.29 (d@d) (gcc version 4.2.2) #18 PREEMPT Wed Jun 10 15:30:24 CEST 2009
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000000 -> 0x00004000
[ 0.000000] Normal 0x00004000 -> 0x00004000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[1] active PFN ranges
[ 0.000000] 0: 0x00000000 -> 0x00004000
[ 0.000000] MMU: Allocated 1088 bytes of context maps for 255 contexts
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: console=ttyUL0 root=/dev/xsa2 noinitrd rootfstype=ext3 rw
[ 0.000000] Xilinx intc at 0x81800000 mapped to 0xfdfff000
[ 0.000000] PID hash table entries: 256 (order: 8, 1024 bytes)
[ 0.000000] clocksource: timebase mult[d55555] shift[22] registered
[256667460.357834] Console: colour dummy device 80x25
[256667460.358192] console [ttyUL0] enabled
[256667460.533049] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[256667460.547603] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[256667460.588076] Memory: 60608k/65536k available (3408k kernel code, 4864k reserved, 184k data, 644k bss, 184k init)
[256667460.613504] Calibrating delay loop... 589.82 BogoMIPS (lpj=294912)
[256667460.648414] Mount-cache hash table entries: 512
[256667460.679456] ftrace: allocating 8776 entries in 44 pages
[256667460.752639] net_namespace: 588 bytes
[256667460.764120] NET: Registered protocol family 16
[256667460.960232] bio: create slab <bio-0> at 0
[256667460.975899] XGpio: /plb@0/gpio@81440000: registered
[256667460.988676] XGpio: /plb@0/gpio@81400000: registered
[256667461.001743] XGpio: /plb@0/gpio@81420000: registered
[256667461.114898] NET: Registered protocol family 2
[256667461.126041] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[256667461.152116] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[256667461.165868] TCP bind hash table entries: 2048 (order: 3, 40960 bytes)
[256667461.179036] TCP: Hash tables configured (established 2048 bind 2048)
[256667461.191370] TCP reno registered
[256667461.202703] NET: Registered protocol family 1
[256667461.329204] fuse init (API version 7.11)
[256667461.342066] msgmni has been set to 118
[256667461.351835] io scheduler noop registered
[256667461.358087] io scheduler anticipatory registered
[256667461.367912] io scheduler deadline registered (default)
[256667461.379271] io scheduler cfq registered
[256667465.125701] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[256667465.181295] 84000000.serial: ttyUL0 at MMIO 0x84000003 (irq = 0) is a uartlite
[256667465.414372] brd: module loaded
[256667465.518012] loop: module loaded
[256667465.525294] xsysace 83600000.sysace: Xilinx SystemACE revision 1.0.12
[256667465.538169] xsysace 83600000.sysace: capacity: 4001760 sectors
[256667465.552078] xsa: xsa1 xsa2 xsa3
[256667465.599850] Xilinx SystemACE device driver, major=254
[256667465.658341] mice: PS/2 mouse device common for all mice
[256667465.679140] i2c /dev entries driver
[256667465.708344] TCP cubic registered
[256667465.713263] NET: Registered protocol family 17
[256667465.742985] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[256667472.160340] kjournald starting. Commit interval 5 seconds
[256667472.179211] EXT3 FS on xsa2, internal journal
[256667472.186246] EXT3-fs: recovery complete.
[256667472.207833] EXT3-fs: mounted filesystem with ordered data mode.
[256667472.218891] VFS: Mounted root (ext3 filesystem) on device 254:2.
[256667472.232134] Freeing unused kernel memory: 184k init
[256667504.420724] Data machine check in kernel mode.
 I have tried by adding init=/bin/sh without much success. When I do that I obtain(with debug):
[737410499.485115] EXT3 FS on xsa2, internal journal
[737410499.492186] EXT3-fs: mounted filesystem with ordered data mode.
[737410499.505400] VFS: Mounted root (ext3 filesystem) on device 254:2.
[737410499.518594] Freeing unused kernel memory: 184k init
[737410501.930204] Kernel panic - not syncing: Attempted to kill init!
[737410501.940424] Rebooting in 180 seconds..<3>BUG: sleeping function called from invalid context at arch/powerpc/math-emu/math.c:227
[737410682.747295] in_atomic(): 1, irqs_disabled(): 0, pid: 1, name: sh
[737410682.759894] Call Trace:
[737410682.765480] [c3849cb0] [c0007ee4] show_stack+0x84/0x184 (unreliable)
[737410682.778749] [c3849cf0] [c0008010] dump_stack+0x2c/0x44
[737410682.789655] [c3849d00] [c002fe60] __might_sleep+0xe8/0x11c
[737410682.801211] [c3849d10] [c001b8b8] do_mathemu+0x38/0x8a4
[737410682.812274] [c3849d30] [c000ed88] program_check_exception+0x98/0x5c0
[737410682.825590] [c3849d70] [c0011930] ret_from_except_full+0x0/0x4c
[737410682.838027] Oops: Exception in kernel mode, sig: 11 [#1]
[737410682.849229] PREEMPT Xilinx Virtex
[737410682.856487] Modules linked in:
[737410682.863233] **bleep**: c3845a90 LR: c000c9a0 CTR: c0390000
[737410682.873783] REGS: c3849d80 TRAP: c000c9f4 Not tainted (2.6.29)
[737410682.886556] MSR: 00000001 <> CR: c0390000 XER: 00029030
[737410682.897968] TASK = c3845a90[1] 'sh' THREAD: c3848000
[737410682.908157] GPR00: c3849e40 c001197c c0390000 c3849e50 000052e0 c3849e40 c3845a90 000493e0
[737410682.925436] GPR08: 00000000 00000000 c01d6120 00000030 c038c8b0 df41fc2d 00035da8 c3849e60
[737410682.942716] GPR16: c0367bb8 c0367ba4 c034bf20 c0350000 c3849eb8 c0387000 c0372c74 c3848000
[737410682.959996] GPR24: 24004022 c0367ba4 c034bf20 c0350000 c3849eb8 c0387000 c0372c74 c3848000
[737410682.977634] **bleep** [c3845a90] 0xc3845a90
[737410682.985607] LR [c000c9a0] __delay+0x40/0x64
[737410682.994555] Call Trace:
[737410683.000085] Instruction dump:
[737410683.006654] XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX
[737410683.022720] XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX
[737410683.038819] ---[ end trace 1daa707f7cc8808e ]---
[737410683.048648] Fixing recursive fault but reboot is needed!
[737410683.059885] BUG: scheduling while atomic: sh/1/0x00000002
[737410683.071278] Modules linked in:
[737410683.078016] Call Trace:
[737410683.083574] [c3849b10] [c0007ee4] show_stack+0x84/0x184 (unreliable)
[737410683.096869] [c3849b50] [c0008010] dump_stack+0x2c/0x44
[737410683.107775] [c3849b60] [c0031e7c] __schedule_bug+0x68/0x80
[737410683.119342] [c3849b70] [c029125c] schedule+0xe4/0x6dc
[737410683.130057] [c3849bc0] [c003d6d0] do_exit+0x7cc/0x888
[737410683.140761] [c3849c20] [c000e620] kernel_bad_stack+0x0/0x64
[737410683.152508] [c3849c40] [c000e944] _exception+0x148/0x1a4
[737410683.163743] [c3849d30] [c000f120] program_check_exception+0x430/0x5c0
[737410683.177225] [c3849d70] [c0011930] ret_from_except_full+0x0/0x4c
 I have even tried deactivating math-emu, ethernetlite and with other combinations of init parameters without much success.By the way, I am trying to use my previous ELDK 4.2 based compact flash image which works with our previous system.
 Any ideas of what could be happening?
 Thx!
Ok, I have found the problem. In fact, the kernel was not hanging but it was losing the console. Strangely, if the uartlite is not configured interrupt-based, it will work only until the point I noted above. When I added the interrupt support it worked all the way. Then the ramdisk was loaded correctly.
I don't know if that can be added anywhere in the wiki, but I think it would definitively avoid some headaches. In fact, I think that a ML403 dts for the reference system won't do any bad.
Thx John for your help!
Have you been able to use our ramdisk that we provide on the wiki site (http://xilinx.wikidot.com) as this is the best baseline?
It definitely looks like your root file system is hosed to me, so knowing that our ram disk works 1st is important in the transition.
You could try putting your own helloworld app on the root file system and using init=/helloworld as sometimes that helps me debug the problem.
When I have these problems I tend to want to par back to something really simple on the root file system to understand the issue.
It looks like the system ace is happy.  You could also use the ramdisk as the root file system then try to mount the system ace file system and
what you get (maybe you've already done that).
-- John
 I already had tried to check the compact flash for errors and it boots ok with my previous .ace (2.6.24-r3 ppc edk9.1 eldk4.2). I have tried your ramdisk w/o much succes though. This is what I get when trying to run busybox (/linuxrc).
zImage starting: loaded at 0x00400000 (sp: 0x0071beb0)
Allocating 0x382994 bytes for kernel ...
gunzipping (0x00000000 <- 0x0040d000:0x005a3298)...done 0x35fb30 bytes
Attached initrd image at 0x005a4000-0x0071af32
initrd head: 0x1f8b0808
Linux/PowerPC load: console=ttyUL0 root=/dev/ram init=/linuxrc
Finalizing device tree... flat tree at 0x728300
[ 0.000000] Linux version 2.6.29 (d@d) (gcc version 4.2.2) #7 PREEMPT Wed Jun 10 18:05:05 CEST 2009
[ 0.000000] Found initrd at 0xc05a4000:0xc071af32
[ 0.000000] Kernel command line: console=ttyUL0 root=/dev/ram init=/linuxrc
[256676594.321450] Console: colour dummy device 80x25
[256676594.321669] console [ttyUL0] enabled
[256676594.502965] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[256676594.517520] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[256676594.549192] Memory: 59784k/65536k available (3320k kernel code, 5692k reserved, 112k data, 138k bss, 172k init)
[256676594.568711] Calibrating delay loop... 595.96 BogoMIPS (lpj=297984)
[256676594.600967] Mount-cache hash table entries: 512
[256676594.619239] net_namespace: 520 bytes
[256676594.626411] NET: Registered protocol family 16
[256676594.690870] bio: create slab <bio-0> at 0
[256676594.698374] XGpio: /plb@0/gpio@81440000: registered
[256676594.707662] XGpio: /plb@0/gpio@81400000: registered
[256676594.717946] XGpio: /plb@0/gpio@81420000: registered
[256676594.754261] NET: Registered protocol family 2
[256676594.762899] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[256676594.779951] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[256676594.792711] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[256676594.805752] TCP: Hash tables configured (established 2048 bind 2048)
[256676594.818857] TCP reno registered
[256676594.827114] NET: Registered protocol family 1
[256676594.837146] checking if image is initramfs...it isn't (no cpio magic); looks like an initrd
[256676595.657924] Freeing initrd memory: 1499k freed
[256676595.695556] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[256676595.708824] fuse init (API version 7.11)
[256676595.717054] msgmni has been set to 119
[256676595.724665] io scheduler noop registered
[256676595.731569] io scheduler anticipatory registered
[256676595.741431] io scheduler deadline registered
[256676595.750789] io scheduler cfq registered (default)
[256676597.162727] 84000000.serial: ttyUL0 at MMIO 0x84000003 (irq = 0) is a uartlite
[256676597.228078] brd: module loaded
[256676597.256508] loop: module loaded
[256676597.262084] xsysace 83600000.sysace: Xilinx SystemACE revision 1.0.12
[256676597.274998] xsysace 83600000.sysace: capacity: 4001760 sectors
[256676597.287597] xsa: xsa1 xsa2 xsa3
[256676597.304479] Xilinx SystemACE device driver, major=254
[256676597.314534] xilinx_emaclite 81000000.ethernet: Device Tree Probing 'ethernet'
[256676597.328042] xilinx_emaclite 81000000.ethernet: MAC address is now 2: 0: 0: 0: 0: 0
[256676597.343592] xilinx_emaclite 81000000.ethernet: using fifo mode.
[256676597.356111] eth0 (): not using net_device_ops yet
[256676597.370871] xilinx_emaclite 81000000.ethernet: Xilinx EMACLite at 0x81000000 mapped to 0xC5060000, irq=17
[256676597.396914] mice: PS/2 mouse device common for all mice
[256676597.409123] i2c /dev entries driver
[256676597.423037] TCP cubic registered
[256676597.427776] NET: Registered protocol family 17
[256676597.439631] RPC: Registered udp transport module.
[256676597.447361] RPC: Registered tcp transport module.
[256676597.465941] RAMDISK: Compressed image found at block 0
[256676598.709895] VFS: Mounted root (ext2 filesystem) readonly on device 1:0.
[256676598.721788] Freeing unused kernel memory: 172k init
And gets stuck there without responding. I have tried to run my own test application, but it failed to execute it:
[256676498.505197] Freeing unused kernel memory: 172k init
[256676498.519598] Failed to execute /test. Attempting defaults...
[256676498.529200] Kernel panic - not syncing: No init found. Try passing init= option to kernel.
[256676498.546424] Rebooting in 180 seconds..
 Even when I had checked permissions and everything. This how my .config looks like ( copied from virtex4_config and modified ).
# Automatically generated make config: don't edit
# Linux kernel version: 2.6.29
# Wed Jun 10 18:04:42 2009
# CONFIG_PPC64 is not set
# Processor support
# CONFIG_6xx is not set
# CONFIG_PPC_85xx is not set
# CONFIG_PPC_8xx is not set
CONFIG_40x=y
# CONFIG_44x is not set
# CONFIG_E200 is not set
CONFIG_4xx=y
CONFIG_PPC_MMU_NOHASH=y
# CONFIG_PPC_MM_SLICES is not set
CONFIG_NOT_COHERENT_CACHE=y
CONFIG_PPC32=y
CONFIG_WORD_SIZE=32
# CONFIG_ARCH_PHYS_ADDR_T_64BIT is not set
CONFIG_MMU=y
CONFIG_GENERIC_CMOS_UPDATE=y
CONFIG_GENERIC_TIME=y
CONFIG_GENERIC_TIME_VSYSCALL=y
CONFIG_GENERIC_CLOCKEVENTS=y
CONFIG_GENERIC_HARDIRQS=y
# CONFIG_HAVE_SETUP_PER_CPU_AREA is not set
CONFIG_IRQ_PER_CPU=y
CONFIG_STACKTRACE_SUPPORT=y
CONFIG_HAVE_LATENCYTOP_SUPPORT=y
CONFIG_LOCKDEP_SUPPORT=y
CONFIG_RWSEM_XCHGADD_ALGORITHM=y
CONFIG_ARCH_HAS_ILOG2_U32=y
CONFIG_GENERIC_HWEIGHT=y
CONFIG_GENERIC_CALIBRATE_DELAY=y
CONFIG_GENERIC_FIND_NEXT_BIT=y
CONFIG_GENERIC_GPIO=y
# CONFIG_ARCH_NO_VIRT_TO_BUS is not set
CONFIG_PPC=y
CONFIG_EARLY_PRINTK=y
CONFIG_GENERIC_NVRAM=y
CONFIG_SCHED_OMIT_FRAME_POINTER=y
CONFIG_ARCH_MAY_HAVE_PC_FDC=y
CONFIG_PPC_OF=y
CONFIG_OF=y
CONFIG_PPC_UDBG_16550=y
# CONFIG_GENERIC_TBSYNC is not set
CONFIG_AUDIT_ARCH=y
CONFIG_GENERIC_BUG=y
# CONFIG_DEFAULT_UIMAGE is not set
CONFIG_PPC_DCR_NATIVE=y
CONFIG_PPC_DCR_MMIO=y
CONFIG_PPC_DCR=y
CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config"
# General setup
CONFIG_EXPERIMENTAL=y
CONFIG_BROKEN_ON_SMP=y
CONFIG_LOCK_KERNEL=y
CONFIG_INIT_ENV_ARG_LIMIT=32
CONFIG_LOCALVERSION=""
# CONFIG_LOCALVERSION_AUTO is not set
CONFIG_SWAP=y
CONFIG_SYSVIPC=y
CONFIG_SYSVIPC_SYSCTL=y
CONFIG_POSIX_MQUEUE=y
# CONFIG_BSD_PROCESS_ACCT is not set
# CONFIG_TASKSTATS is not set
# CONFIG_AUDIT is not set
# RCU Subsystem
CONFIG_CLASSIC_RCU=y
# CONFIG_TREE_RCU is not set
# CONFIG_PREEMPT_RCU is not set
# CONFIG_TREE_RCU_TRACE is not set
# CONFIG_PREEMPT_RCU_TRACE is not set
CONFIG_IKCONFIG=y
CONFIG_IKCONFIG_PROC=y
CONFIG_LOG_BUF_SHIFT=14
# CONFIG_GROUP_SCHED is not set
# CONFIG_CGROUPS is not set
CONFIG_SYSFS_DEPRECATED=y
CONFIG_SYSFS_DEPRECATED_V2=y
# CONFIG_RELAY is not set
CONFIG_NAMESPACES=y
# CONFIG_UTS_NS is not set
# CONFIG_IPC_NS is not set
# CONFIG_USER_NS is not set
# CONFIG_PID_NS is not set
# CONFIG_NET_NS is not set
CONFIG_BLK_DEV_INITRD=y
CONFIG_INITRAMFS_SOURCE=""
# CONFIG_CC_OPTIMIZE_FOR_SIZE is not set
CONFIG_SYSCTL=y
CONFIG_ANON_INODES=y
# CONFIG_EMBEDDED is not set
CONFIG_SYSCTL_SYSCALL=y
CONFIG_KALLSYMS=y
# CONFIG_KALLSYMS_EXTRA_PASS is not set
CONFIG_HOTPLUG=y
CONFIG_PRINTK=y
CONFIG_BUG=y
CONFIG_ELF_CORE=y
CONFIG_BASE_FULL=y
CONFIG_FUTEX=y
CONFIG_EPOLL=y
CONFIG_SIGNALFD=y
CONFIG_TIMERFD=y
CONFIG_EVENTFD=y
CONFIG_SHMEM=y
CONFIG_AIO=y
CONFIG_VM_EVENT_COUNTERS=y
CONFIG_COMPAT_BRK=y
CONFIG_SLAB=y
# CONFIG_SLUB is not set
# CONFIG_SLOB is not set
# CONFIG_PROFILING is not set
CONFIG_HAVE_OPROFILE=y
# CONFIG_KPROBES is not set
CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS=y
CONFIG_HAVE_IOREMAP_PROT=y
CONFIG_HAVE_KPROBES=y
CONFIG_HAVE_KRETPROBES=y
CONFIG_HAVE_ARCH_TRACEHOOK=y
# CONFIG_HAVE_GENERIC_DMA_COHERENT is not set
CONFIG_SLABINFO=y
CONFIG_RT_MUTEXES=y
CONFIG_BASE_SMALL=0
CONFIG_MODULES=y
# CONFIG_MODULE_FORCE_LOAD is not set
CONFIG_MODULE_UNLOAD=y
CONFIG_MODULE_FORCE_UNLOAD=y
CONFIG_MODVERSIONS=y
# CONFIG_MODULE_SRCVERSION_ALL is not set
CONFIG_BLOCK=y
# CONFIG_LBD is not set
# CONFIG_BLK_DEV_IO_TRACE is not set
# CONFIG_BLK_DEV_BSG is not set
# CONFIG_BLK_DEV_INTEGRITY is not set
# IO Schedulers
CONFIG_IOSCHED_NOOP=y
CONFIG_IOSCHED_AS=y
CONFIG_IOSCHED_DEADLINE=y
CONFIG_IOSCHED_CFQ=y
# CONFIG_DEFAULT_AS is not set
# CONFIG_DEFAULT_DEADLINE is not set
CONFIG_DEFAULT_CFQ=y
# CONFIG_DEFAULT_NOOP is not set
CONFIG_DEFAULT_IOSCHED="cfq"
# CONFIG_FREEZER is not set
# Platform support
# CONFIG_PPC_CELL is not set
# CONFIG_PPC_CELL_NATIVE is not set
# CONFIG_PQ2ADS is not set
# CONFIG_PPC4xx_GPIO is not set
# CONFIG_ACADIA is not set
# CONFIG_EP405 is not set
# CONFIG_HCU4 is not set
# CONFIG_KILAUEA is not set
# CONFIG_MAKALU is not set
# CONFIG_WALNUT is not set
CONFIG_XILINX_VIRTEX_GENERIC_BOARD=y
# CONFIG_PPC40x_SIMPLE is not set
CONFIG_XILINX_VIRTEX_II_PRO=y
CONFIG_XILINX_VIRTEX_4_FX=y
CONFIG_IBM405_ERR77=y
CONFIG_IBM405_ERR51=y
# CONFIG_IPIC is not set
# CONFIG_MPIC is not set
# CONFIG_MPIC_WEIRD is not set
# CONFIG_PPC_I8259 is not set
# CONFIG_PPC_RTAS is not set
# CONFIG_MMIO_NVRAM is not set
# CONFIG_PPC_MPC106 is not set
# CONFIG_PPC_970_NAP is not set
# CONFIG_PPC_INDIRECT_IO is not set
# CONFIG_GENERIC_IOMAP is not set
# CONFIG_CPU_FREQ is not set
# CONFIG_FSL_ULI1575 is not set
CONFIG_XILINX_VIRTEX=y
# CONFIG_SIMPLE_GPIO is not set
# Kernel options
# CONFIG_HIGHMEM is not set
CONFIG_TICK_ONESHOT=y
# CONFIG_NO_HZ is not set
CONFIG_HIGH_RES_TIMERS=y
CONFIG_GENERIC_CLOCKEVENTS_BUILD=y
# CONFIG_HZ_100 is not set
# CONFIG_HZ_250 is not set
# CONFIG_HZ_300 is not set
CONFIG_HZ_1000=y
CONFIG_HZ=1000
CONFIG_SCHED_HRTICK=y
# CONFIG_PREEMPT_NONE is not set
# CONFIG_PREEMPT_VOLUNTARY is not set
CONFIG_PREEMPT=y
CONFIG_BINFMT_ELF=y
# CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS is not set
# CONFIG_HAVE_AOUT is not set
CONFIG_BINFMT_MISC=y
CONFIG_MATH_EMULATION=y
# CONFIG_IOMMU_HELPER is not set
CONFIG_PPC_NEED_DMA_SYNC_OPS=y
CONFIG_ARCH_ENABLE_MEMORY_HOTPLUG=y
CONFIG_ARCH_HAS_WALK_MEMORY=y
CONFIG_ARCH_ENABLE_MEMORY_HOTREMOVE=y
CONFIG_ARCH_FLATMEM_ENABLE=y
CONFIG_ARCH_POPULATES_NODE_MAP=y
CONFIG_SELECT_MEMORY_MODEL=y
CONFIG_FLATMEM_MANUAL=y
# CONFIG_DISCONTIGMEM_MANUAL is not set
# CONFIG_SPARSEMEM_MANUAL is not set
CONFIG_FLATMEM=y
CONFIG_FLAT_NODE_MEM_MAP=y
CONFIG_PAGEFLAGS_EXTENDED=y
CONFIG_SPLIT_PTLOCK_CPUS=4
CONFIG_MIGRATION=y
# CONFIG_PHYS_ADDR_T_64BIT is not set
CONFIG_ZONE_DMA_FLAG=1
CONFIG_BOUNCE=y
CONFIG_VIRT_TO_BUS=y
CONFIG_UNEVICTABLE_LRU=y
CONFIG_PPC_4K_PAGES=y
# CONFIG_PPC_16K_PAGES is not set
# CONFIG_PPC_64K_PAGES is not set
CONFIG_FORCE_MAX_ZONEORDER=11
CONFIG_PROC_DEVICETREE=y
CONFIG_CMDLINE_BOOL=y
CONFIG_CMDLINE=""
CONFIG_EXTRA_TARGETS="simpleImage.virtex405-ml403 simpleImage.initrd.virtex405-ml403"
# CONFIG_PM is not set
CONFIG_SECCOMP=y
# CONFIG_COMPRESSED_DEVICE_TREE is not set
CONFIG_ISA_DMA_API=y
# Bus options
CONFIG_ZONE_DMA=y
CONFIG_4xx_SOC=y
CONFIG_PPC_PCI_CHOICE=y
# CONFIG_PCI is not set
# CONFIG_PCI_DOMAINS is not set
# CONFIG_PCI_SYSCALL is not set
# CONFIG_ARCH_SUPPORTS_MSI is not set
# CONFIG_PCCARD is not set
# CONFIG_HAS_RAPIDIO is not set
# Advanced setup
# CONFIG_ADVANCED_OPTIONS is not set
# Default settings for advanced configuration options are used
CONFIG_LOWMEM_SIZE=0x30000000
CONFIG_PAGE_OFFSET=0xc0000000
CONFIG_KERNEL_START=0xc0000000
CONFIG_PHYSICAL_START=0x00000000
CONFIG_TASK_SIZE=0xc0000000
CONFIG_CONSISTENT_START=0xff100000
CONFIG_CONSISTENT_SIZE=0x00200000
CONFIG_NET=y
# Networking options
CONFIG_COMPAT_NET_DEV_OPS=y
CONFIG_PACKET=y
# CONFIG_PACKET_MMAP is not set
CONFIG_UNIX=y
CONFIG_XFRM=y
# CONFIG_XFRM_USER is not set
# CONFIG_XFRM_SUB_POLICY is not set
# CONFIG_XFRM_MIGRATE is not set
# CONFIG_XFRM_STATISTICS is not set
# CONFIG_NET_KEY is not set
CONFIG_INET=y
CONFIG_IP_MULTICAST=y
# CONFIG_IP_ADVANCED_ROUTER is not set
CONFIG_IP_FIB_HASH=y
CONFIG_IP_PNP=y
CONFIG_IP_PNP_DHCP=y
CONFIG_IP_PNP_BOOTP=y
# CONFIG_IP_PNP_RARP is not set
# CONFIG_NET_IPIP is not set
# CONFIG_NET_IPGRE is not set
# CONFIG_IP_MROUTE is not set
# CONFIG_ARPD is not set
# CONFIG_SYN_COOKIES is not set
# CONFIG_INET_AH is not set
# CONFIG_INET_ESP is not set
# CONFIG_INET_IPCOMP is not set
# CONFIG_INET_XFRM_TUNNEL is not set
# CONFIG_INET_TUNNEL is not set
CONFIG_INET_XFRM_MODE_TRANSPORT=y
CONFIG_INET_XFRM_MODE_TUNNEL=y
CONFIG_INET_XFRM_MODE_BEET=y
# CONFIG_INET_LRO is not set
CONFIG_INET_DIAG=y
CONFIG_INET_TCP_DIAG=y
# CONFIG_TCP_CONG_ADVANCED is not set
CONFIG_TCP_CONG_CUBIC=y
CONFIG_DEFAULT_TCP_CONG="cubic"
# CONFIG_TCP_MD5SIG is not set
# CONFIG_IPV6 is not set
# CONFIG_NETWORK_SECMARK is not set
# CONFIG_NETFILTER is not set
# CONFIG_IP_DCCP is not set
# CONFIG_IP_SCTP is not set
# CONFIG_TIPC is not set
# CONFIG_ATM is not set
# CONFIG_BRIDGE is not set
# CONFIG_NET_DSA is not set
# CONFIG_VLAN_8021Q is not set
# CONFIG_DECNET is not set
# CONFIG_LLC2 is not set
# CONFIG_IPX is not set
# CONFIG_ATALK is not set
# CONFIG_X25 is not set
# CONFIG_LAPB is not set
# CONFIG_ECONET is not set
# CONFIG_WAN_ROUTER is not set
# CONFIG_NET_SCHED is not set
# CONFIG_DCB is not set
# Network testing
# CONFIG_NET_PKTGEN is not set
# CONFIG_HAMRADIO is not set
# CONFIG_CAN is not set
# CONFIG_IRDA is not set
# CONFIG_BT is not set
# CONFIG_AF_RXRPC is not set
# CONFIG_PHONET is not set
# CONFIG_WIRELESS is not set
# CONFIG_WIMAX is not set
# CONFIG_RFKILL is not set
# CONFIG_NET_9P is not set
# Device Drivers
# Generic Driver Options
CONFIG_UEVENT_HELPER_PATH="/sbin/hotplug"
CONFIG_STANDALONE=y
CONFIG_PREVENT_FIRMWARE_BUILD=y
CONFIG_FW_LOADER=y
CONFIG_FIRMWARE_IN_KERNEL=y
CONFIG_EXTRA_FIRMWARE=""
# CONFIG_SYS_HYPERVISOR is not set
# CONFIG_CONNECTOR is not set
# CONFIG_MTD is not set
CONFIG_OF_DEVICE=y
CONFIG_OF_GPIO=y
CONFIG_OF_I2C=y
# CONFIG_PARPORT is not set
CONFIG_BLK_DEV=y
# CONFIG_BLK_DEV_FD is not set
# CONFIG_BLK_DEV_COW_COMMON is not set
CONFIG_BLK_DEV_LOOP=y
# CONFIG_BLK_DEV_CRYPTOLOOP is not set
# CONFIG_BLK_DEV_NBD is not set
CONFIG_BLK_DEV_RAM=y
CONFIG_BLK_DEV_RAM_COUNT=16
CONFIG_BLK_DEV_RAM_SIZE=8192
# CONFIG_BLK_DEV_XIP is not set
# CONFIG_CDROM_PKTCDVD is not set
# CONFIG_ATA_OVER_ETH is not set
CONFIG_XILINX_SYSACE=y
# CONFIG_XILINX_SYSACE_OLD is not set
# CONFIG_BLK_DEV_HD is not set
CONFIG_MISC_DEVICES=y
# CONFIG_ICS932S401 is not set
# CONFIG_ENCLOSURE_SERVICES is not set
# CONFIG_C2PORT is not set
# EEPROM support
# CONFIG_EEPROM_AT24 is not set
# CONFIG_EEPROM_LEGACY is not set
# CONFIG_EEPROM_93CX6 is not set
CONFIG_XILINX_DRIVERS=y
CONFIG_NEED_XILINX_IPIF=y
CONFIG_HAVE_IDE=y
# CONFIG_IDE is not set
# SCSI device support
# CONFIG_RAID_ATTRS is not set
# CONFIG_SCSI is not set
# CONFIG_SCSI_DMA is not set
# CONFIG_SCSI_NETLINK is not set
# CONFIG_ATA is not set
# CONFIG_MD is not set
# CONFIG_MACINTOSH_DRIVERS is not set
CONFIG_NETDEVICES=y
# CONFIG_DUMMY is not set
# CONFIG_BONDING is not set
# CONFIG_MACVLAN is not set
# CONFIG_EQUALIZER is not set
# CONFIG_TUN is not set
# CONFIG_VETH is not set
CONFIG_PHYLIB=y
# MII PHY device drivers
# CONFIG_MARVELL_PHY is not set
# CONFIG_DAVICOM_PHY is not set
# CONFIG_QSEMI_PHY is not set
# CONFIG_LXT_PHY is not set
# CONFIG_CICADA_PHY is not set
# CONFIG_VITESSE_PHY is not set
# CONFIG_SMSC_PHY is not set
# CONFIG_BROADCOM_PHY is not set
# CONFIG_ICPLUS_PHY is not set
# CONFIG_REALTEK_PHY is not set
# CONFIG_NATIONAL_PHY is not set
# CONFIG_STE10XP is not set
# CONFIG_LSI_ET1011C_PHY is not set
# CONFIG_FIXED_PHY is not set
# CONFIG_MDIO_BITBANG is not set
CONFIG_NET_ETHERNET=y
CONFIG_MII=y
# CONFIG_DNET is not set
# CONFIG_IBM_NEW_EMAC is not set
# CONFIG_IBM_NEW_EMAC_ZMII is not set
# CONFIG_IBM_NEW_EMAC_RGMII is not set
# CONFIG_IBM_NEW_EMAC_TAH is not set
# CONFIG_IBM_NEW_EMAC_EMAC4 is not set
# CONFIG_IBM_NEW_EMAC_NO_FLOW_CTRL is not set
# CONFIG_IBM_NEW_EMAC_MAL_CLR_ICINTSTAT is not set
# CONFIG_IBM_NEW_EMAC_MAL_COMMON_ERR is not set
# CONFIG_B44 is not set
# CONFIG_XILINX_EMAC is not set
CONFIG_XILINX_EMACLITE=y
# CONFIG_NETDEV_1000 is not set
# CONFIG_NETDEV_10000 is not set
# Wireless LAN
# CONFIG_WLAN_PRE80211 is not set
# CONFIG_WLAN_80211 is not set
# CONFIG_IWLWIFI_LEDS is not set
# Enable WiMAX (Networking options) to see the WiMAX drivers
# CONFIG_WAN is not set
# CONFIG_PPP is not set
# CONFIG_SLIP is not set
# CONFIG_NETCONSOLE is not set
# CONFIG_NETPOLL is not set
# CONFIG_NET_POLL_CONTROLLER is not set
# CONFIG_ISDN is not set
# CONFIG_PHONE is not set
# Input device support
CONFIG_INPUT=y
# CONFIG_INPUT_FF_MEMLESS is not set
# CONFIG_INPUT_POLLDEV is not set
# Userland interfaces
CONFIG_INPUT_MOUSEDEV=y
CONFIG_INPUT_MOUSEDEV_PSAUX=y
CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024
CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768
# CONFIG_INPUT_JOYDEV is not set
# CONFIG_INPUT_EVDEV is not set
# CONFIG_INPUT_EVBUG is not set
# Input Device Drivers
CONFIG_INPUT_KEYBOARD=y
CONFIG_KEYBOARD_ATKBD=y
# CONFIG_KEYBOARD_SUNKBD is not set
# CONFIG_KEYBOARD_LKKBD is not set
# CONFIG_KEYBOARD_XTKBD is not set
# CONFIG_KEYBOARD_NEWTON is not set
# CONFIG_KEYBOARD_STOWAWAY is not set
# CONFIG_KEYBOARD_GPIO is not set
CONFIG_INPUT_MOUSE=y
CONFIG_MOUSE_PS2=y
CONFIG_MOUSE_PS2_ALPS=y
CONFIG_MOUSE_PS2_LOGIPS2PP=y
CONFIG_MOUSE_PS2_SYNAPTICS=y
CONFIG_MOUSE_PS2_TRACKPOINT=y
# CONFIG_MOUSE_PS2_ELANTECH is not set
# CONFIG_MOUSE_PS2_TOUCHKIT is not set
# CONFIG_MOUSE_SERIAL is not set
# CONFIG_MOUSE_VSXXXAA is not set
# CONFIG_MOUSE_GPIO is not set
# CONFIG_INPUT_JOYSTICK is not set
# CONFIG_INPUT_TABLET is not set
# CONFIG_INPUT_TOUCHSCREEN is not set
# CONFIG_INPUT_MISC is not set
# Hardware I/O ports
CONFIG_SERIO=y
# CONFIG_SERIO_I8042 is not set
CONFIG_SERIO_SERPORT=y
CONFIG_SERIO_LIBPS2=y
# CONFIG_SERIO_XILINXPS2 is not set
# CONFIG_SERIO_XILINX_XPS_PS2 is not set
# CONFIG_SERIO_RAW is not set
# CONFIG_GAMEPORT is not set
# Character devices
CONFIG_VT=y
CONFIG_CONSOLE_TRANSLATIONS=y
CONFIG_VT_CONSOLE=y
CONFIG_HW_CONSOLE=y
# CONFIG_VT_HW_CONSOLE_BINDING is not set
CONFIG_DEVKMEM=y
# CONFIG_SERIAL_NONSTANDARD is not set
# Serial drivers
# CONFIG_SERIAL_8250 is not set
# Non-8250 serial port support
CONFIG_SERIAL_UARTLITE=y
CONFIG_SERIAL_UARTLITE_CONSOLE=y
CONFIG_SERIAL_CORE=y
CONFIG_SERIAL_CORE_CONSOLE=y
# CONFIG_SERIAL_OF_PLATFORM_NWPSERIAL is not set
CONFIG_UNIX98_PTYS=y
# CONFIG_DEVPTS_MULTIPLE_INSTANCES is not set
CONFIG_LEGACY_PTYS=y
CONFIG_LEGACY_PTY_COUNT=256
# CONFIG_HVC_UDBG is not set
# CONFIG_IPMI_HANDLER is not set
CONFIG_HW_RANDOM=y
# CONFIG_NVRAM is not set
# CONFIG_GEN_RTC is not set
CONFIG_XILINX_HWICAP=y
# CONFIG_R3964 is not set
# CONFIG_RAW_DRIVER is not set
# CONFIG_TCG_TPM is not set
CONFIG_I2C=y
CONFIG_I2C_BOARDINFO=y
CONFIG_I2C_CHARDEV=y
CONFIG_I2C_HELPER_AUTO=y
# I2C Hardware Bus support
# I2C system bus drivers (mostly embedded / system-on-chip)
# CONFIG_I2C_GPIO is not set
# CONFIG_I2C_IBM_IIC is not set
# CONFIG_I2C_MPC is not set
# CONFIG_I2C_OCORES is not set
# CONFIG_I2C_SIMTEC is not set
# External I2C/SMBus adapter drivers
# CONFIG_I2C_PARPORT_LIGHT is not set
# CONFIG_I2C_TAOS_EVM is not set
# Other I2C/SMBus bus drivers
# CONFIG_I2C_PCA_PLATFORM is not set
# CONFIG_I2C_STUB is not set
# Miscellaneous I2C Chip support
# CONFIG_DS1682 is not set
# CONFIG_SENSORS_PCF8574 is not set
# CONFIG_PCF8575 is not set
# CONFIG_SENSORS_PCA9539 is not set
# CONFIG_SENSORS_PCF8591 is not set
# CONFIG_SENSORS_MAX6875 is not set
# CONFIG_SENSORS_TSL2550 is not set
CONFIG_I2C_DEBUG_CORE=y
CONFIG_I2C_DEBUG_ALGO=y
# CONFIG_I2C_DEBUG_BUS is not set
# CONFIG_I2C_DEBUG_CHIP is not set
# CONFIG_SPI is not set
CONFIG_ARCH_WANT_OPTIONAL_GPIOLIB=y
CONFIG_GPIOLIB=y
# CONFIG_GPIO_SYSFS is not set
# Memory mapped GPIO expanders:
CONFIG_GPIO_XILINX=y
# I2C GPIO expanders:
# CONFIG_GPIO_MAX732X is not set
# CONFIG_GPIO_PCA953X is not set
# CONFIG_GPIO_PCF857X is not set
# PCI GPIO expanders:
# SPI GPIO expanders:
# CONFIG_W1 is not set
# CONFIG_POWER_SUPPLY is not set
# CONFIG_HWMON is not set
# CONFIG_THERMAL is not set
# CONFIG_THERMAL_HWMON is not set
# CONFIG_WATCHDOG is not set
CONFIG_SSB_POSSIBLE=y
# Sonics Silicon Backplane
# CONFIG_SSB is not set
# Multifunction device drivers
# CONFIG_MFD_CORE is not set
# CONFIG_MFD_SM501 is not set
# CONFIG_HTC_PASIC3 is not set
# CONFIG_TPS65010 is not set
# CONFIG_TWL4030_CORE is not set
# CONFIG_MFD_TMIO is not set
# CONFIG_PMIC_DA903X is not set
# CONFIG_MFD_WM8400 is not set
# CONFIG_MFD_WM8350_I2C is not set
# CONFIG_MFD_PCF50633 is not set
# CONFIG_REGULATOR is not set
# Multimedia devices
# Multimedia core support
# CONFIG_VIDEO_DEV is not set
# CONFIG_DVB_CORE is not set
# CONFIG_VIDEO_MEDIA is not set
# Multimedia drivers
# CONFIG_DAB is not set
# Graphics support
# CONFIG_VGASTATE is not set
# CONFIG_VIDEO_OUTPUT_CONTROL is not set
CONFIG_FB=y
# CONFIG_FIRMWARE_EDID is not set
# CONFIG_FB_DDC is not set
# CONFIG_FB_BOOT_VESA_SUPPORT is not set
CONFIG_FB_CFB_FILLRECT=y
CONFIG_FB_CFB_COPYAREA=y
CONFIG_FB_CFB_IMAGEBLIT=y
# CONFIG_FB_CFB_REV_PIXELS_IN_BYTE is not set
# CONFIG_FB_SYS_FILLRECT is not set
# CONFIG_FB_SYS_COPYAREA is not set
# CONFIG_FB_SYS_IMAGEBLIT is not set
# CONFIG_FB_FOREIGN_ENDIAN is not set
# CONFIG_FB_SYS_FOPS is not set
# CONFIG_FB_SVGALIB is not set
# CONFIG_FB_MACMODES is not set
# CONFIG_FB_BACKLIGHT is not set
# CONFIG_FB_MODE_HELPERS is not set
# CONFIG_FB_TILEBLITTING is not set
# Frame buffer hardware drivers
# CONFIG_FB_OF is not set
# CONFIG_FB_VGA16 is not set
# CONFIG_FB_S1D13XXX is not set
# CONFIG_FB_IBM_GXT4500 is not set
CONFIG_FB_XILINX=y
# CONFIG_FB_VIRTUAL is not set
# CONFIG_FB_METRONOME is not set
# CONFIG_FB_MB862XX is not set
# CONFIG_BACKLIGHT_LCD_SUPPORT is not set
# Display device support
# CONFIG_DISPLAY_SUPPORT is not set
# Console display driver support
CONFIG_DUMMY_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE=y
# CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY is not set
# CONFIG_FRAMEBUFFER_CONSOLE_ROTATION is not set
CONFIG_FONTS=y
CONFIG_FONT_8x8=y
CONFIG_FONT_8x16=y
# CONFIG_FONT_6x11 is not set
# CONFIG_FONT_7x14 is not set
# CONFIG_FONT_PEARL_8x8 is not set
# CONFIG_FONT_ACORN_8x8 is not set
# CONFIG_FONT_MINI_4x6 is not set
# CONFIG_FONT_SUN8x16 is not set
# CONFIG_FONT_SUN12x22 is not set
# CONFIG_FONT_10x18 is not set
CONFIG_LOGO=y
CONFIG_LOGO_LINUX_MONO=y
CONFIG_LOGO_LINUX_VGA16=y
CONFIG_LOGO_LINUX_CLUT224=y
# CONFIG_SOUND is not set
# CONFIG_HID_SUPPORT is not set
# CONFIG_USB_SUPPORT is not set
# CONFIG_MMC is not set
# CONFIG_MEMSTICK is not set
# CONFIG_NEW_LEDS is not set
# CONFIG_ACCESSIBILITY is not set
# CONFIG_EDAC is not set
# CONFIG_RTC_CLASS is not set
# CONFIG_DMADEVICES is not set
CONFIG_XILINX_EDK=y
CONFIG_UIO=y
CONFIG_UIO_PDRV=y
CONFIG_UIO_PDRV_GENIRQ=y
# CONFIG_UIO_SMX is not set
# CONFIG_UIO_SERCOS3 is not set
# CONFIG_STAGING is not set
# File systems
CONFIG_EXT2_FS=y
CONFIG_EXT2_FS_XATTR=y
# CONFIG_EXT2_FS_POSIX_ACL is not set
# CONFIG_EXT2_FS_SECURITY is not set
# CONFIG_EXT2_FS_XIP is not set
CONFIG_EXT3_FS=y
CONFIG_EXT3_FS_XATTR=y
# CONFIG_EXT3_FS_POSIX_ACL is not set
# CONFIG_EXT3_FS_SECURITY is not set
# CONFIG_EXT4_FS is not set
CONFIG_JBD=y
CONFIG_FS_MBCACHE=y
# CONFIG_REISERFS_FS is not set
# CONFIG_JFS_FS is not set
# CONFIG_FS_POSIX_ACL is not set
CONFIG_FILE_LOCKING=y
# CONFIG_XFS_FS is not set
# CONFIG_OCFS2_FS is not set
# CONFIG_BTRFS_FS is not set
CONFIG_DNOTIFY=y
CONFIG_INOTIFY=y
CONFIG_INOTIFY_USER=y
# CONFIG_QUOTA is not set
CONFIG_AUTOFS_FS=y
CONFIG_AUTOFS4_FS=y
CONFIG_FUSE_FS=y
# CD-ROM/DVD Filesystems
# CONFIG_ISO9660_FS is not set
# CONFIG_UDF_FS is not set
# DOS/FAT/NT Filesystems
CONFIG_FAT_FS=y
CONFIG_MSDOS_FS=y
CONFIG_VFAT_FS=y
CONFIG_FAT_DEFAULT_CODEPAGE=437
CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
# CONFIG_NTFS_FS is not set
# Pseudo filesystems
CONFIG_PROC_FS=y
# CONFIG_PROC_KCORE is not set
CONFIG_PROC_SYSCTL=y
CONFIG_PROC_PAGE_MONITOR=y
CONFIG_SYSFS=y
CONFIG_TMPFS=y
# CONFIG_TMPFS_POSIX_ACL is not set
# CONFIG_HUGETLB_PAGE is not set
# CONFIG_CONFIGFS_FS is not set
CONFIG_MISC_FILESYSTEMS=y
# CONFIG_ADFS_FS is not set
# CONFIG_AFFS_FS is not set
# CONFIG_HFS_FS is not set
# CONFIG_HFSPLUS_FS is not set
# CONFIG_BEFS_FS is not set
# CONFIG_BFS_FS is not set
# CONFIG_EFS_FS is not set
CONFIG_CRAMFS=y
# CONFIG_SQUASHFS is not set
# CONFIG_VXFS_FS is not set
# CONFIG_MINIX_FS is not set
# CONFIG_OMFS_FS is not set
# CONFIG_HPFS_FS is not set
# CONFIG_QNX4FS_FS is not set
CONFIG_ROMFS_FS=y
# CONFIG_SYSV_FS is not set
# CONFIG_UFS_FS is not set
CONFIG_NETWORK_FILESYSTEMS=y
CONFIG_NFS_FS=y
CONFIG_NFS_V3=y
# CONFIG_NFS_V3_ACL is not set
# CONFIG_NFS_V4 is not set
CONFIG_ROOT_NFS=y
CONFIG_NFSD=y
CONFIG_NFSD_V3=y
# CONFIG_NFSD_V3_ACL is not set
# CONFIG_NFSD_V4 is not set
CONFIG_LOCKD=y
CONFIG_LOCKD_V4=y
CONFIG_EXPORTFS=y
CONFIG_NFS_COMMON=y
CONFIG_SUNRPC=y
# CONFIG_SUNRPC_REGISTER_V4 is not set
# CONFIG_RPCSEC_GSS_KRB5 is not set
# CONFIG_RPCSEC_GSS_SPKM3 is not set
CONFIG_SMB_FS=y
# CONFIG_SMB_NLS_DEFAULT is not set
# CONFIG_CIFS is not set
# CONFIG_NCP_FS is not set
# CONFIG_CODA_FS is not set
# CONFIG_AFS_FS is not set
# Partition Types
# CONFIG_PARTITION_ADVANCED is not set
CONFIG_MSDOS_PARTITION=y
CONFIG_NLS=y
CONFIG_NLS_DEFAULT="iso8859-1"
CONFIG_NLS_CODEPAGE_437=y
# CONFIG_NLS_CODEPAGE_737 is not set
# CONFIG_NLS_CODEPAGE_775 is not set
# CONFIG_NLS_CODEPAGE_850 is not set
# CONFIG_NLS_CODEPAGE_852 is not set
# CONFIG_NLS_CODEPAGE_855 is not set
# CONFIG_NLS_CODEPAGE_857 is not set
# CONFIG_NLS_CODEPAGE_860 is not set
# CONFIG_NLS_CODEPAGE_861 is not set
# CONFIG_NLS_CODEPAGE_862 is not set
# CONFIG_NLS_CODEPAGE_863 is not set
# CONFIG_NLS_CODEPAGE_864 is not set
# CONFIG_NLS_CODEPAGE_865 is not set
# CONFIG_NLS_CODEPAGE_866 is not set
# CONFIG_NLS_CODEPAGE_869 is not set
# CONFIG_NLS_CODEPAGE_936 is not set
# CONFIG_NLS_CODEPAGE_950 is not set
# CONFIG_NLS_CODEPAGE_932 is not set
# CONFIG_NLS_CODEPAGE_949 is not set
# CONFIG_NLS_CODEPAGE_874 is not set
# CONFIG_NLS_ISO8859_8 is not set
# CONFIG_NLS_CODEPAGE_1250 is not set
# CONFIG_NLS_CODEPAGE_1251 is not set
CONFIG_NLS_ASCII=y
CONFIG_NLS_ISO8859_1=y
# CONFIG_NLS_ISO8859_2 is not set
# CONFIG_NLS_ISO8859_3 is not set
# CONFIG_NLS_ISO8859_4 is not set
# CONFIG_NLS_ISO8859_5 is not set
# CONFIG_NLS_ISO8859_6 is not set
# CONFIG_NLS_ISO8859_7 is not set
# CONFIG_NLS_ISO8859_9 is not set
# CONFIG_NLS_ISO8859_13 is not set
# CONFIG_NLS_ISO8859_14 is not set
# CONFIG_NLS_ISO8859_15 is not set
# CONFIG_NLS_KOI8_R is not set
# CONFIG_NLS_KOI8_U is not set
CONFIG_NLS_UTF8=y
# CONFIG_DLM is not set
# Library routines
CONFIG_BITREVERSE=y
CONFIG_GENERIC_FIND_LAST_BIT=y
CONFIG_CRC_CCITT=y
# CONFIG_CRC16 is not set
# CONFIG_CRC_T10DIF is not set
# CONFIG_CRC_ITU_T is not set
CONFIG_CRC32=y
# CONFIG_CRC7 is not set
# CONFIG_LIBCRC32C is not set
CONFIG_ZLIB_INFLATE=y
CONFIG_PLIST=y
CONFIG_HAS_IOMEM=y
CONFIG_HAS_IOPORT=y
CONFIG_HAS_DMA=y
CONFIG_HAVE_LMB=y
# Kernel hacking
CONFIG_PRINTK_TIME=y
CONFIG_ENABLE_WARN_DEPRECATED=y
CONFIG_ENABLE_MUST_CHECK=y
CONFIG_FRAME_WARN=1024
# CONFIG_MAGIC_SYSRQ is not set
# CONFIG_UNUSED_SYMBOLS is not set
# CONFIG_DEBUG_FS is not set
# CONFIG_HEADERS_CHECK is not set
# CONFIG_DEBUG_KERNEL is not set
CONFIG_DEBUG_BUGVERBOSE=y
CONFIG_DEBUG_MEMORY_INIT=y
# CONFIG_RCU_CPU_STALL_DETECTOR is not set
# CONFIG_LATENCYTOP is not set
CONFIG_SYSCTL_SYSCALL_CHECK=y
CONFIG_HAVE_FUNCTION_TRACER=y
CONFIG_HAVE_DYNAMIC_FTRACE=y
CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y
# Tracers
# CONFIG_DYNAMIC_PRINTK_DEBUG is not set
# CONFIG_SAMPLES is not set
CONFIG_HAVE_ARCH_KGDB=y
CONFIG_PRINT_STACK_DEPTH=64
# CONFIG_IRQSTACKS is not set
# CONFIG_PPC_EARLY_DEBUG is not set
# Security options
# CONFIG_KEYS is not set
# CONFIG_SECURITY is not set
# CONFIG_SECURITYFS is not set
# CONFIG_SECURITY_FILE_CAPABILITIES is not set
CONFIG_CRYPTO=y
# Crypto core or helper
# CONFIG_CRYPTO_FIPS is not set
# CONFIG_CRYPTO_MANAGER is not set
# CONFIG_CRYPTO_MANAGER2 is not set
# CONFIG_CRYPTO_GF128MUL is not set
# CONFIG_CRYPTO_NULL is not set
# CONFIG_CRYPTO_CRYPTD is not set
# CONFIG_CRYPTO_AUTHENC is not set
# CONFIG_CRYPTO_TEST is not set
# Authenticated Encryption with Associated Data
# CONFIG_CRYPTO_CCM is not set
# CONFIG_CRYPTO_GCM is not set
# CONFIG_CRYPTO_SEQIV is not set
# Block modes
# CONFIG_CRYPTO_CBC is not set
# CONFIG_CRYPTO_CTR is not set
# CONFIG_CRYPTO_CTS is not set
# CONFIG_CRYPTO_ECB is not set
# CONFIG_CRYPTO_LRW is not set
# CONFIG_CRYPTO_PCBC is not set
# CONFIG_CRYPTO_XTS is not set
# Hash modes
# CONFIG_CRYPTO_HMAC is not set
# CONFIG_CRYPTO_XCBC is not set
# Digest
# CONFIG_CRYPTO_CRC32C is not set
# CONFIG_CRYPTO_MD4 is not set
# CONFIG_CRYPTO_MD5 is not set
# CONFIG_CRYPTO_MICHAEL_MIC is not set
# CONFIG_CRYPTO_RMD128 is not set
# CONFIG_CRYPTO_RMD160 is not set
# CONFIG_CRYPTO_RMD256 is not set
# CONFIG_CRYPTO_RMD320 is not set
# CONFIG_CRYPTO_SHA1 is not set
# CONFIG_CRYPTO_SHA256 is not set
# CONFIG_CRYPTO_SHA512 is not set
# CONFIG_CRYPTO_TGR192 is not set
# CONFIG_CRYPTO_WP512 is not set
# Ciphers
# CONFIG_CRYPTO_AES is not set
# CONFIG_CRYPTO_ANUBIS is not set
# CONFIG_CRYPTO_ARC4 is not set
# CONFIG_CRYPTO_BLOWFISH is not set
# CONFIG_CRYPTO_CAMELLIA is not set
# CONFIG_CRYPTO_CAST5 is not set
# CONFIG_CRYPTO_CAST6 is not set
# CONFIG_CRYPTO_DES is not set
# CONFIG_CRYPTO_FCRYPT is not set
# CONFIG_CRYPTO_KHAZAD is not set
# CONFIG_CRYPTO_SALSA20 is not set
# CONFIG_CRYPTO_SEED is not set
# CONFIG_CRYPTO_SERPENT is not set
# CONFIG_CRYPTO_TEA is not set
# CONFIG_CRYPTO_TWOFISH is not set
# Compression
# CONFIG_CRYPTO_DEFLATE is not set
# CONFIG_CRYPTO_LZO is not set
# Random Number Generation
# CONFIG_CRYPTO_ANSI_CPRNG is not set
CONFIG_CRYPTO_HW=y
# CONFIG_PPC_CLOCK is not set
# CONFIG_VIRTUALIZATION is not set
If the ramdisk is not working then I wouldn't even start with system ace.
I'm not sure why you're putting init=/linuxrc on the command for the ramdisk as you shouldn't need it.
Did you specify init= on the command line for your application when it didn't run?
I'm assuming you're building the initrd kernel image and loading it as it seems to be finding the ramdisk.  The kernel config has initrd turned on also which looks good.
-- John
I had in mind that I didn't need the init=/linuxrc but when it didn't work the first time I made it explicit. So I did for my test app init=/test . The way I load the image is through the xmd ( platform cable usb). This is exactly what it says there:
Downloading Program -- linux-2.6-xlnx_powerpc/linux-2.6-xlnx/arch/powerpc/boot/simpleImage.initrd.virtex405-ml403.elf section, .text: 0x00400000-0x00408d33 section, .data: 0x00409000-0x0040abdf section, __builtin_cmdline: 0x0040abe0-0x0040addf section, .kernel:dtb: 0x0040ade0-0x0040c1c5 section, .kernel:vmlinux.strip: 0x0040d000-0x005a3297 section, .kernel:initrd: 0x005a4000-0x0071af31 section, .bss: 0x0071b000-0x00727ddb Setting PC with Program Start Address 0x00400000 XMD% XMD% run Info:Processor started. Type "stop" to stop processor RUNNING> XMD%
 I have lost a day so far in this. I am a bit desperate and I don't know exactly where to look exactly. Plus, I had to remove the debug options from the kernel which caused the image to be too big to be initialized (>4MB?).
Assuming you're using our ramdisk and not getting it to work, I would then add init=/bin/sh on the command line.  Are you using our ramdisk and not your own?
For your test, are you sure your ramdisk was good after you altered it with adding your test?
I realize these are somewhat redundant questions, but getting a baseline is important.  Have you diffed your kernel config and device tree against the ones we provide in our tree as those are typically the problems found.
-- John
I notice that you're building with ELDK 4.1.2 and we use 4.1.1.  That shouldn't make a difference just an observation.
I am using the uClibc tools from the ELDK as there's seperate ISOs I believe.
-- John
Just as a frame of reference I just quickly built the kernel on the ML405 (same board, smaller FPGA) and here's the output using our ramdisk.
Linux/PowerPC load: console=ttyS0 root=/dev/ram
Finalizing device tree... flat tree at 0x86f300
Linux version 2.6.29 (linnj@xaqlinnj41) (gcc version 4.0.0 (DENX ELDK 4.1 4.0.0)) #74 PREEMPT Wed Jun 10 11:27
:49 MDT 2009
Found initrd at 0xc059c000:0xc08610b7
Zone PFN ranges:
  DMA      0x00000000 -> 0x00008000
  Normal   0x00008000 -> 0x00008000
    0: 0x00000000 -> 0x00008000
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 32512
Kernel command line: console=ttyS0 root=/dev/ram
PID hash table entries: 512 (order: 9, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 123388k/131072k available (3244k kernel code, 7536k reserved, 132k data, 138k bss, 180k init)
Calibrating delay loop... 598.01 BogoMIPS (lpj=1196032)
net_namespace: 880 bytes
PCI: Probing PCI hardware
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
Freeing initrd memory: 2836k freed
msgmni has been set to 246
83e00000.serial: ttyS0 at MMIO 0x83e01003 (irq = 16) is a 16550A
console [ttyS0] enabled
brd: module loaded
loop: module loaded
xilinx_lltemac 81c00000.ethernet: MAC address is now  2: 0: 0: 0: 0: 1
xilinx_lltemac 81c00000.ethernet: XLlTemac: using DMA mode.
XLlTemac: Dma base address: phy: 0x84600100, virt: 0xc9018100
XLlTemac: buffer descriptor size: 32768 (0x8000)
XLlTemac: Allocating DMA descriptors with kmalloc<6>XLlTemac: (buffer_descriptor_init) phy: 0x7888000, virt: 0
xc7888000, size: 0x8000
XTemac: No PHY detected.  Assuming a PHY at address 0
eth0: Dropping NETIF_F_SG since no checksum feature.
xilinx_lltemac 81c00000.ethernet: eth0: Xilinx TEMAC at 0x81C00000 mapped to 0xC9012000, irq=17
Freeing unused kernel memory: 180k init
Running rcS...
Starting system loggers
Configuring loopback interface
Starting inetd
sh: can't access tty; job control turned off
Hi John,
 thanks again for all your suggestions.  I tried again using an untouched copy of the ramdisk directly downloaded from your wiki with the same results. I also had tried the init=/bin/sh previously and retried just again. I get the same together with this:
[256737186.450862] Kernel panic - not syncing: Attempted to kill init!
[256737186.460967] Rebooting in 180 seconds..
The kernel config, I had copied it from the "virtex4_defconfig" and I had added some stuff. The > diff -uN .config virtex4_config gives the following:
--- .config 2009-06-10 18:04:42.541090552 +0200
+++ arch/powerpc/configs/40x/virtex4_defconfig 2009-06-08 12:14:22.564587314 +0200
@@ -1,7 +1,7 @@
-# Linux kernel version: 2.6.29
-# Wed Jun 10 18:04:42 2009
+# Linux kernel version: 2.6.27-rc4
+# Thu Aug 21 09:05:51 2008
@@ -15,12 +15,11 @@
CONFIG_4xx=y
-CONFIG_PPC_MMU_NOHASH=y
CONFIG_PPC32=y
CONFIG_WORD_SIZE=32
-# CONFIG_ARCH_PHYS_ADDR_T_64BIT is not set
+CONFIG_PPC_MERGE=y
CONFIG_MMU=y
@@ -37,12 +36,11 @@
-CONFIG_GENERIC_GPIO=y
CONFIG_PPC=y
-CONFIG_SCHED_OMIT_FRAME_POINTER=y
+CONFIG_SCHED_NO_NO_OMIT_FRAME_POINTER=y
CONFIG_PPC_OF=y
CONFIG_OF=y
@@ -72,20 +70,11 @@
-# RCU Subsystem
-CONFIG_CLASSIC_RCU=y
-# CONFIG_TREE_RCU is not set
-# CONFIG_PREEMPT_RCU is not set
-# CONFIG_TREE_RCU_TRACE is not set
-# CONFIG_PREEMPT_RCU_TRACE is not set
CONFIG_IKCONFIG=y
-# CONFIG_GROUP_SCHED is not set
+# CONFIG_GROUP_SCHED is not set
@@ -94,12 +83,10 @@
-# CONFIG_NET_NS is not set
CONFIG_SYSCTL=y
-CONFIG_ANON_INODES=y
CONFIG_KALLSYMS=y
@@ -108,20 +95,21 @@
CONFIG_PRINTK=y
CONFIG_BUG=y
CONFIG_ELF_CORE=y
+CONFIG_COMPAT_BRK=y
CONFIG_BASE_FULL=y
CONFIG_FUTEX=y
+CONFIG_ANON_INODES=y
CONFIG_EPOLL=y
CONFIG_SIGNALFD=y
CONFIG_TIMERFD=y
CONFIG_EVENTFD=y
CONFIG_SHMEM=y
-CONFIG_AIO=y
-CONFIG_COMPAT_BRK=y
CONFIG_SLAB=y
+# CONFIG_MARKERS is not set
@@ -129,9 +117,14 @@
+# CONFIG_HAVE_DMA_ATTRS is not set
+# CONFIG_USE_GENERIC_SMP_HELPERS is not set
+# CONFIG_HAVE_CLK is not set
+CONFIG_PROC_PAGE_MONITOR=y
CONFIG_SLABINFO=y
CONFIG_RT_MUTEXES=y
+# CONFIG_TINY_SHMEM is not set
CONFIG_BASE_SMALL=0
CONFIG_MODULES=y
@@ -139,9 +132,11 @@
+CONFIG_KMOD=y
CONFIG_BLOCK=y
+# CONFIG_LSF is not set
@@ -157,7 +152,8 @@
-# CONFIG_FREEZER is not set
+CONFIG_CLASSIC_RCU=y
+# CONFIG_PPC4xx_PCI_EXPRESS is not set
# Platform support
@@ -165,15 +161,11 @@
-# CONFIG_PPC4xx_GPIO is not set
-# CONFIG_ACADIA is not set
-# CONFIG_HCU4 is not set
-# CONFIG_PPC40x_SIMPLE is not set
@@ -191,32 +183,29 @@
-# CONFIG_SIMPLE_GPIO is not set
# Kernel options
-CONFIG_TICK_ONESHOT=y
+# CONFIG_TICK_ONESHOT is not set
-CONFIG_HIGH_RES_TIMERS=y
+# CONFIG_HIGH_RES_TIMERS is not set
-# CONFIG_HZ_250 is not set
+CONFIG_HZ_250=y
-CONFIG_HZ_1000=y
-CONFIG_HZ=1000
-CONFIG_SCHED_HRTICK=y
+# CONFIG_HZ_1000 is not set
+CONFIG_HZ=250
+# CONFIG_SCHED_HRTICK is not set
CONFIG_PREEMPT=y
+# CONFIG_PREEMPT_RCU is not set
CONFIG_BINFMT_ELF=y
-# CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS is not set
-# CONFIG_HAVE_AOUT is not set
-CONFIG_BINFMT_MISC=y
+# CONFIG_BINFMT_MISC is not set
-CONFIG_PPC_NEED_DMA_SYNC_OPS=y
@@ -228,22 +217,20 @@
CONFIG_FLATMEM=y
+# CONFIG_SPARSEMEM_STATIC is not set
+# CONFIG_SPARSEMEM_VMEMMAP_ENABLE is not set
CONFIG_MIGRATION=y
-# CONFIG_PHYS_ADDR_T_64BIT is not set
+CONFIG_RESOURCES_64BIT=y
CONFIG_BOUNCE=y
-CONFIG_UNEVICTABLE_LRU=y
-CONFIG_PPC_4K_PAGES=y
-# CONFIG_PPC_16K_PAGES is not set
-# CONFIG_PPC_64K_PAGES is not set
CONFIG_CMDLINE=""
-CONFIG_EXTRA_TARGETS="simpleImage.virtex405-ml403 simpleImage.initrd.virtex405-ml403"
+CONFIG_EXTRA_TARGETS="simpleImage.virtex405-ml405 simpleImage.initrd.virtex405-ml405"
CONFIG_SECCOMP=y
@@ -253,13 +240,18 @@
# Bus options
CONFIG_ZONE_DMA=y
+CONFIG_PPC_INDIRECT_PCI=y
CONFIG_4xx_SOC=y
-# CONFIG_PCI is not set
-# CONFIG_PCI_DOMAINS is not set
-# CONFIG_PCI_SYSCALL is not set
-# CONFIG_ARCH_SUPPORTS_MSI is not set
+CONFIG_PCI=y
+CONFIG_PCI_DOMAINS=y
+CONFIG_PCI_SYSCALL=y
+# CONFIG_PCIEPORTBUS is not set
+CONFIG_ARCH_SUPPORTS_MSI=y
+# CONFIG_PCI_MSI is not set
+CONFIG_PCI_LEGACY=y
+# CONFIG_HOTPLUG_PCI is not set
@@ -282,7 +274,6 @@
-CONFIG_COMPAT_NET_DEV_OPS=y
CONFIG_PACKET=y
CONFIG_UNIX=y
@@ -309,7 +300,7 @@
-# CONFIG_INET_TUNNEL is not set
+CONFIG_INET_TUNNEL=m
@@ -320,15 +311,100 @@
-# CONFIG_IPV6 is not set
+# CONFIG_IP_VS is not set
+CONFIG_IPV6=m
+# CONFIG_IPV6_PRIVACY is not set
+# CONFIG_IPV6_ROUTER_PREF is not set
+# CONFIG_IPV6_OPTIMISTIC_DAD is not set
+# CONFIG_INET6_AH is not set
+# CONFIG_INET6_ESP is not set
+# CONFIG_INET6_IPCOMP is not set
+# CONFIG_IPV6_MIP6 is not set
+# CONFIG_INET6_XFRM_TUNNEL is not set
+# CONFIG_INET6_TUNNEL is not set
+CONFIG_INET6_XFRM_MODE_TRANSPORT=m
+CONFIG_INET6_XFRM_MODE_TUNNEL=m
+CONFIG_INET6_XFRM_MODE_BEET=m
+# CONFIG_INET6_XFRM_MODE_ROUTEOPTIMIZATION is not set
+CONFIG_IPV6_SIT=m
+CONFIG_IPV6_NDISC_NODETYPE=y
+# CONFIG_IPV6_TUNNEL is not set
+# CONFIG_IPV6_MULTIPLE_TABLES is not set
+# CONFIG_IPV6_MROUTE is not set
-# CONFIG_NETFILTER is not set
+CONFIG_NETFILTER=y
+# CONFIG_NETFILTER_DEBUG is not set
+CONFIG_NETFILTER_ADVANCED=y
+# Core Netfilter Configuration
+# CONFIG_NETFILTER_NETLINK_QUEUE is not set
+# CONFIG_NETFILTER_NETLINK_LOG is not set
+# CONFIG_NF_CONNTRACK is not set
+CONFIG_NETFILTER_XTABLES=m
+# CONFIG_NETFILTER_XT_TARGET_CLASSIFY is not set
+# CONFIG_NETFILTER_XT_TARGET_DSCP is not set
+# CONFIG_NETFILTER_XT_TARGET_MARK is not set
+# CONFIG_NETFILTER_XT_TARGET_NFQUEUE is not set
+# CONFIG_NETFILTER_XT_TARGET_NFLOG is not set
+# CONFIG_NETFILTER_XT_TARGET_RATEEST is not set
+# CONFIG_NETFILTER_XT_TARGET_TCPMSS is not set
+# CONFIG_NETFILTER_XT_TARGET_TCPOPTSTRIP is not set
+# CONFIG_NETFILTER_XT_MATCH_COMMENT is not set
+# CONFIG_NETFILTER_XT_MATCH_DCCP is not set
+# CONFIG_NETFILTER_XT_MATCH_DSCP is not set
+# CONFIG_NETFILTER_XT_MATCH_ESP is not set
+# CONFIG_NETFILTER_XT_MATCH_IPRANGE is not set
+# CONFIG_NETFILTER_XT_MATCH_LENGTH is not set
+# CONFIG_NETFILTER_XT_MATCH_LIMIT is not set
+# CONFIG_NETFILTER_XT_MATCH_MAC is not set
+# CONFIG_NETFILTER_XT_MATCH_MARK is not set
+# CONFIG_NETFILTER_XT_MATCH_OWNER is not set
+# CONFIG_NETFILTER_XT_MATCH_POLICY is not set
+# CONFIG_NETFILTER_XT_MATCH_MULTIPORT is not set
+# CONFIG_NETFILTER_XT_MATCH_PKTTYPE is not set
+# CONFIG_NETFILTER_XT_MATCH_QUOTA is not set
+# CONFIG_NETFILTER_XT_MATCH_RATEEST is not set
+# CONFIG_NETFILTER_XT_MATCH_REALM is not set
+# CONFIG_NETFILTER_XT_MATCH_SCTP is not set
+# CONFIG_NETFILTER_XT_MATCH_STATISTIC is not set
+# CONFIG_NETFILTER_XT_MATCH_STRING is not set
+# CONFIG_NETFILTER_XT_MATCH_TCPMSS is not set
+# CONFIG_NETFILTER_XT_MATCH_TIME is not set
+# CONFIG_NETFILTER_XT_MATCH_U32 is not set
+# CONFIG_NETFILTER_XT_MATCH_HASHLIMIT is not set
+# IP: Netfilter Configuration
+# CONFIG_IP_NF_QUEUE is not set
+CONFIG_IP_NF_IPTABLES=m
+# CONFIG_IP_NF_MATCH_RECENT is not set
+# CONFIG_IP_NF_MATCH_ECN is not set
+# CONFIG_IP_NF_MATCH_AH is not set
+# CONFIG_IP_NF_MATCH_TTL is not set
+# CONFIG_IP_NF_MATCH_ADDRTYPE is not set
+CONFIG_IP_NF_FILTER=m
+# CONFIG_IP_NF_TARGET_REJECT is not set
+# CONFIG_IP_NF_TARGET_LOG is not set
+# CONFIG_IP_NF_TARGET_ULOG is not set
+CONFIG_IP_NF_MANGLE=m
+# CONFIG_IP_NF_TARGET_ECN is not set
+# CONFIG_IP_NF_TARGET_TTL is not set
+# CONFIG_IP_NF_RAW is not set
+# CONFIG_IP_NF_ARPTABLES is not set
+# IPv6: Netfilter Configuration
+# CONFIG_IP6_NF_QUEUE is not set
+# CONFIG_IP6_NF_IPTABLES is not set
-# CONFIG_NET_DSA is not set
@@ -339,7 +415,6 @@
-# CONFIG_DCB is not set
# Network testing
@@ -350,9 +425,14 @@
-# CONFIG_PHONET is not set
-# CONFIG_WIRELESS is not set
-# CONFIG_WIMAX is not set
+# Wireless
+# CONFIG_CFG80211 is not set
+# CONFIG_WIRELESS_EXT is not set
+# CONFIG_MAC80211 is not set
+# CONFIG_IEEE80211 is not set
@@ -373,37 +453,37 @@
CONFIG_OF_DEVICE=y
-CONFIG_OF_GPIO=y
CONFIG_OF_I2C=y
CONFIG_BLK_DEV=y
+# CONFIG_BLK_CPQ_DA is not set
+# CONFIG_BLK_CPQ_CISS_DA is not set
+# CONFIG_BLK_DEV_DAC960 is not set
+# CONFIG_BLK_DEV_UMEM is not set
+# CONFIG_BLK_DEV_SX8 is not set
-CONFIG_XILINX_SYSACE=y
+# CONFIG_XILINX_SYSACE is not set
-# CONFIG_ICS932S401 is not set
-# CONFIG_ENCLOSURE_SERVICES is not set
-# CONFIG_C2PORT is not set
-# EEPROM support
-# CONFIG_EEPROM_AT24 is not set
-# CONFIG_EEPROM_LEGACY is not set
+# CONFIG_PHANTOM is not set
+# CONFIG_SGI_IOC4 is not set
+# CONFIG_TIFM_CORE is not set
+# CONFIG_ENCLOSURE_SERVICES is not set
+# CONFIG_HP_ILO is not set
-CONFIG_NEED_XILINX_IPIF=y
+CONFIG_NEED_XILINX_LLDMA=y
CONFIG_HAVE_IDE=y
@@ -416,6 +496,18 @@
+# CONFIG_FUSION is not set
+# IEEE 1394 (FireWire) support
+# Enable only one of the two stacks, unless you know what you are doing
+# CONFIG_FIREWIRE is not set
+# CONFIG_IEEE1394 is not set
+# CONFIG_I2O is not set
CONFIG_NETDEVICES=y
@@ -424,42 +516,52 @@
-CONFIG_PHYLIB=y
-# MII PHY device drivers
-# CONFIG_MARVELL_PHY is not set
-# CONFIG_DAVICOM_PHY is not set
-# CONFIG_QSEMI_PHY is not set
-# CONFIG_LXT_PHY is not set
-# CONFIG_CICADA_PHY is not set
-# CONFIG_VITESSE_PHY is not set
-# CONFIG_SMSC_PHY is not set
-# CONFIG_BROADCOM_PHY is not set
-# CONFIG_ICPLUS_PHY is not set
-# CONFIG_REALTEK_PHY is not set
-# CONFIG_NATIONAL_PHY is not set
-# CONFIG_STE10XP is not set
-# CONFIG_LSI_ET1011C_PHY is not set
-# CONFIG_FIXED_PHY is not set
-# CONFIG_MDIO_BITBANG is not set
+# CONFIG_ARCNET is not set
+# CONFIG_PHYLIB is not set
CONFIG_MII=y
-# CONFIG_DNET is not set
+# CONFIG_HAPPYMEAL is not set
+# CONFIG_SUNGEM is not set
+# CONFIG_CASSINI is not set
+# CONFIG_NET_VENDOR_3COM is not set
+# CONFIG_NET_TULIP is not set
+# CONFIG_HP100 is not set
-# CONFIG_IBM_NEW_EMAC_NO_FLOW_CTRL is not set
-# CONFIG_IBM_NEW_EMAC_MAL_CLR_ICINTSTAT is not set
-# CONFIG_IBM_NEW_EMAC_MAL_COMMON_ERR is not set
+# CONFIG_NET_PCI is not set
-CONFIG_XILINX_EMACLITE=y
-# CONFIG_NETDEV_1000 is not set
+# CONFIG_XILINX_EMACLITE is not set
+CONFIG_NETDEV_1000=y
+# CONFIG_ACENIC is not set
+# CONFIG_DL2K is not set
+# CONFIG_E1000 is not set
+# CONFIG_E1000E is not set
+# CONFIG_IP1000 is not set
+# CONFIG_IGB is not set
+# CONFIG_NS83820 is not set
+# CONFIG_HAMACHI is not set
+# CONFIG_YELLOWFIN is not set
+# CONFIG_R8169 is not set
+# CONFIG_SIS190 is not set
+# CONFIG_SKGE is not set
+# CONFIG_SKY2 is not set
+# CONFIG_VIA_VELOCITY is not set
+# CONFIG_TIGON3 is not set
+# CONFIG_BNX2 is not set
+# CONFIG_QLA3XXX is not set
+# CONFIG_ATL1 is not set
+# CONFIG_XILINX_TEMAC is not set
+# CONFIG_ATL1E is not set
+CONFIG_XILINX_LLTEMAC=y
+# CONFIG_XILINX_LLTEMAC_MARVELL_88E1111_RGMII is not set
+CONFIG_XILINX_LLTEMAC_MARVELL_88E1111_GMII=y
+# CONFIG_XILINX_LLTEMAC_MARVELL_88E1111_MII is not set
+# CONFIG_TR is not set
# Wireless LAN
@@ -467,11 +569,9 @@
-# Enable WiMAX (Networking options) to see the WiMAX drivers
+# CONFIG_FDDI is not set
+# CONFIG_HIPPI is not set
@@ -508,18 +608,16 @@
-# CONFIG_KEYBOARD_GPIO is not set
CONFIG_MOUSE_PS2=y
+CONFIG_MOUSE_PS2_LIFEBOOK=y
-# CONFIG_MOUSE_PS2_ELANTECH is not set
-# CONFIG_MOUSE_GPIO is not set
@@ -531,6 +629,7 @@
CONFIG_SERIO=y
+# CONFIG_SERIO_PCIPS2 is not set
@@ -547,33 +646,40 @@
CONFIG_DEVKMEM=y
+# CONFIG_NOZOMI is not set
# Serial drivers
-# CONFIG_SERIAL_8250 is not set
+CONFIG_SERIAL_8250=y
+CONFIG_SERIAL_8250_CONSOLE=y
+CONFIG_SERIAL_8250_PCI=y
+CONFIG_SERIAL_8250_NR_UARTS=4
+CONFIG_SERIAL_8250_RUNTIME_UARTS=4
+# CONFIG_SERIAL_8250_EXTENDED is not set
-CONFIG_SERIAL_UARTLITE=y
-CONFIG_SERIAL_UARTLITE_CONSOLE=y
+# CONFIG_SERIAL_UARTLITE is not set
-# CONFIG_SERIAL_OF_PLATFORM_NWPSERIAL is not set
+# CONFIG_SERIAL_JSM is not set
+CONFIG_SERIAL_OF_PLATFORM=y
-# CONFIG_DEVPTS_MULTIPLE_INSTANCES is not set
-# CONFIG_HVC_UDBG is not set
-CONFIG_HW_RANDOM=y
+CONFIG_HW_RANDOM=m
+# CONFIG_XILINX_GPIO is not set
+# CONFIG_APPLICOM is not set
+CONFIG_DEVPORT=y
CONFIG_I2C=y
@@ -584,9 +690,26 @@
+# PC SMBus host controller drivers
+# CONFIG_I2C_ALI1535 is not set
+# CONFIG_I2C_ALI1563 is not set
+# CONFIG_I2C_ALI15X3 is not set
+# CONFIG_I2C_AMD756 is not set
+# CONFIG_I2C_AMD8111 is not set
+# CONFIG_I2C_I801 is not set
+# CONFIG_I2C_ISCH is not set
+# CONFIG_I2C_PIIX4 is not set
+# CONFIG_I2C_NFORCE2 is not set
+# CONFIG_I2C_SIS5595 is not set
+# CONFIG_I2C_SIS630 is not set
+# CONFIG_I2C_SIS96X is not set
+# CONFIG_I2C_VIA is not set
+# CONFIG_I2C_VIAPRO is not set
-# CONFIG_I2C_GPIO is not set
@@ -599,6 +722,11 @@
+# Graphics adapter I2C/DDC channel drivers
+# CONFIG_I2C_VOODOO3 is not set
@@ -608,6 +736,8 @@
+# CONFIG_AT24 is not set
+# CONFIG_SENSORS_EEPROM is not set
@@ -620,39 +750,18 @@
-CONFIG_GPIOLIB=y
-# CONFIG_GPIO_SYSFS is not set
-# Memory mapped GPIO expanders:
-CONFIG_GPIO_XILINX=y
-# I2C GPIO expanders:
-# CONFIG_GPIO_MAX732X is not set
-# CONFIG_GPIO_PCA953X is not set
-# CONFIG_GPIO_PCF857X is not set
-# PCI GPIO expanders:
-# SPI GPIO expanders:
+# CONFIG_GPIOLIB is not set
-CONFIG_SSB_POSSIBLE=y
+CONFIG_SSB_POSSIBLE=y
@@ -661,14 +770,7 @@
-# CONFIG_TPS65010 is not set
-# CONFIG_TWL4030_CORE is not set
-# CONFIG_PMIC_DA903X is not set
-# CONFIG_MFD_WM8400 is not set
-# CONFIG_MFD_WM8350_I2C is not set
-# CONFIG_MFD_PCF50633 is not set
-# CONFIG_REGULATOR is not set
@@ -689,12 +791,13 @@
# Graphics support
+# CONFIG_AGP is not set
+# CONFIG_DRM is not set
CONFIG_FB=y
-# CONFIG_FB_BOOT_VESA_SUPPORT is not set
@@ -713,14 +816,36 @@
+# CONFIG_FB_CIRRUS is not set
+# CONFIG_FB_PM2 is not set
+# CONFIG_FB_CYBER2000 is not set
+# CONFIG_FB_CT65550 is not set
+# CONFIG_FB_ASILIANT is not set
+# CONFIG_FB_IMSTT is not set
+# CONFIG_FB_NVIDIA is not set
+# CONFIG_FB_RIVA is not set
+# CONFIG_FB_MATROX is not set
+# CONFIG_FB_RADEON is not set
+# CONFIG_FB_ATY128 is not set
+# CONFIG_FB_ATY is not set
+# CONFIG_FB_S3 is not set
+# CONFIG_FB_SAVAGE is not set
+# CONFIG_FB_SIS is not set
+# CONFIG_FB_NEOMAGIC is not set
+# CONFIG_FB_KYRO is not set
+# CONFIG_FB_3DFX is not set
+# CONFIG_FB_VOODOO1 is not set
+# CONFIG_FB_VT8623 is not set
+# CONFIG_FB_TRIDENT is not set
+# CONFIG_FB_ARK is not set
+# CONFIG_FB_PM3 is not set
+# CONFIG_FB_CARMINE is not set
CONFIG_FB_XILINX=y
-# CONFIG_FB_METRONOME is not set
-# CONFIG_FB_MB862XX is not set
@@ -757,46 +882,34 @@
+# CONFIG_INFINIBAND is not set
CONFIG_XILINX_EDK=y
-CONFIG_UIO=y
-CONFIG_UIO_PDRV=y
-CONFIG_UIO_PDRV_GENIRQ=y
-# CONFIG_UIO_SMX is not set
-# CONFIG_UIO_SERCOS3 is not set
-# CONFIG_STAGING is not set
+# CONFIG_XILINX_LLDMA_USE_DCR is not set
+# CONFIG_UIO is not set
# File systems
CONFIG_EXT2_FS=y
-CONFIG_EXT2_FS_XATTR=y
-# CONFIG_EXT2_FS_POSIX_ACL is not set
-# CONFIG_EXT2_FS_SECURITY is not set
+# CONFIG_EXT2_FS_XATTR is not set
-CONFIG_EXT3_FS=y
-CONFIG_EXT3_FS_XATTR=y
-# CONFIG_EXT3_FS_POSIX_ACL is not set
-# CONFIG_EXT3_FS_SECURITY is not set
-# CONFIG_EXT4_FS is not set
-CONFIG_JBD=y
-CONFIG_FS_MBCACHE=y
+# CONFIG_EXT3_FS is not set
+# CONFIG_EXT4DEV_FS is not set
-CONFIG_FILE_LOCKING=y
-# CONFIG_BTRFS_FS is not set
CONFIG_DNOTIFY=y
CONFIG_INOTIFY=y
CONFIG_AUTOFS_FS=y
CONFIG_AUTOFS4_FS=y
-CONFIG_FUSE_FS=y
+CONFIG_FUSE_FS=m
@@ -820,13 +933,15 @@
CONFIG_PROC_FS=y
-CONFIG_PROC_PAGE_MONITOR=y
CONFIG_SYSFS=y
CONFIG_TMPFS=y
-CONFIG_MISC_FILESYSTEMS=y
+# Miscellaneous filesystems
@@ -835,7 +950,6 @@
CONFIG_CRAMFS=y
-# CONFIG_SQUASHFS is not set
@@ -859,7 +973,6 @@
CONFIG_EXPORTFS=y
CONFIG_NFS_COMMON=y
CONFIG_SUNRPC=y
-# CONFIG_SUNRPC_REGISTER_V4 is not set
CONFIG_SMB_FS=y
@@ -899,8 +1012,8 @@
-CONFIG_NLS_ASCII=y
-CONFIG_NLS_ISO8859_1=y
+CONFIG_NLS_ASCII=m
+CONFIG_NLS_ISO8859_1=m
@@ -913,14 +1026,14 @@
-CONFIG_NLS_UTF8=y
+CONFIG_NLS_UTF8=m
# Library routines
CONFIG_BITREVERSE=y
-CONFIG_GENERIC_FIND_LAST_BIT=y
+# CONFIG_GENERIC_FIND_FIRST_BIT is not set
CONFIG_CRC_CCITT=y
@@ -938,7 +1051,7 @@
# Kernel hacking
-CONFIG_PRINTK_TIME=y
+# CONFIG_PRINTK_TIME is not set
@@ -949,20 +1062,16 @@
-# CONFIG_RCU_CPU_STALL_DETECTOR is not set
-CONFIG_HAVE_FUNCTION_TRACER=y
+CONFIG_HAVE_FTRACE=y
-CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y
-# Tracers
-# CONFIG_DYNAMIC_PRINTK_DEBUG is not set
+# CONFIG_FTRACE is not set
+# CONFIG_PREEMPT_TRACER is not set
+# CONFIG_SCHED_TRACER is not set
+# CONFIG_CONTEXT_SWITCH_TRACER is not set
-CONFIG_PRINT_STACK_DEPTH=64
@@ -971,16 +1080,13 @@
-# CONFIG_SECURITYFS is not set
CONFIG_CRYPTO=y
-# CONFIG_CRYPTO_FIPS is not set
-# CONFIG_CRYPTO_MANAGER2 is not set
@@ -1052,11 +1158,7 @@
-# Random Number Generation
-# CONFIG_CRYPTO_ANSI_CPRNG is not set
CONFIG_CRYPTO_HW=y
+# CONFIG_CRYPTO_DEV_HIFN_795X is not set
 My .dts against the ml405 one says the following:
diff -uN dts/virtex405-ml403.dts dts/virtex405-ml405.dts
--- dts/virtex405-ml403.dts 2009-06-11 10:49:34.996589806 +0200
+++ dts/virtex405-ml405.dts 2009-06-08 12:14:21.676623385 +0200
@@ -1,68 +1,45 @@
- * Device Tree Generator version: 1.2
+ * This file supports the Xilinx ML405 board with the 405 processor.
+ * A reference design for the FPGA is provided at http://git.xilinx.com.
- * (C) Copyright 2007-2008 Xilinx, Inc.
- * (C) Copyright 2007-2008 Michal Simek
+ * (C) Copyright 2008 Xilinx, Inc.
- * Michal SIMEK <monstr@monstr.eu>
- * This program is free software; you can redistribute it and/or
- * modify it under the terms of the GNU General Public License as
- * published by the Free Software Foundation; either version 2 of
- * the License, or (at your option) any later version.
- * This program is distributed in the hope that it will be useful,
- * but WITHOUT ANY WARRANTY; without even the implied warranty of
- * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
- * GNU General Public License for more details.
- * You should have received a copy of the GNU General Public License
- * along with this program; if not, write to the Free Software
- * Foundation, Inc., 59 Temple Place, Suite 330, Boston,
- * MA 02111-1307 USA
- * CAUTION: This file is automatically generated by libgen.
- * Version: Xilinx EDK 10.1.03 EDK_K_SP3.6
- * XPS project directory: robotplatformPLB_3.1_ISE10.1
+ * This file is licensed under the terms of the GNU General Public License
+ * version 2. This program is licensed "as is" without any warranty of any
+ * kind, whether express or implied.
/dts-v1/;
#address-cells = <1>;
#size-cells = <1>;
- compatible = "xlnx,virtex405", "xlnx,virtex";
+ compatible = "xlnx,virtex405";
model = "testing";
DDR_SDRAM: memory@0 {
device_type = "memory";
- reg = < 0x0 0x4000000 >;
- alias {
- ethernet0 = &Ethernet_MAC;
- serial0 = &RS232_Uart;
+ reg = < 0 0x8000000 >;
chosen {
-/* bootargs = "console=ttyUL0 root=/dev/xsa2 noinitrd rootfstype=ext3 rw";*/
- bootargs = "console=ttyUL0 root=/dev/ram init=/bin/sh";
- linux,stdout-path = "/plb@0/serial@84000000";
+ bootargs = "console=ttyS0 ip=on root=/dev/ram";
+ linux,stdout-path = "/plb@0/serial@83e00000";
cpus {
- #cpus = <0x1>;
+ #cpus = <1>;
#size-cells = <0>;
ppc405_0: cpu@0 {
- clock-frequency = <300000000>;
+ clock-frequency = <0x11e1a300>;
compatible = "PowerPC,405", "ibm,ppc405";
d-cache-line-size = <0x20>;
d-cache-size = <0x4000>;
- dcr-access-method = "native";
- dcr-controller ;
device_type = "cpu";
i-cache-line-size = <0x20>;
i-cache-size = <0x4000>;
model = "PowerPC,405";
reg = <0>;
- timebase-frequency = <300000000>;
+ timebase-frequency = <0x11e1a300>;
xlnx,apu-control = <0xde00>;
xlnx,apu-udi-1 = <0xa18983>;
xlnx,apu-udi-2 = <0xa38983>;
@@ -72,125 +49,123 @@
xlnx,apu-udi-6 = <0xab8c03>;
xlnx,apu-udi-7 = <0xad8c43>;
xlnx,apu-udi-8 = <0xaf8c43>;
- xlnx,deterministic-mult = <0x0>;
- xlnx,disable-operand-forwarding = <0x1>;
+ xlnx,deterministic-mult = <0>;
+ xlnx,disable-operand-forwarding = <1>;
xlnx,fastest-plb-clock = "DPLB0";
- xlnx,generate-plb-timespecs = <0x1>;
- xlnx,mmu-enable = <0x1>;
- xlnx,pvr-high = <0x0>;
- xlnx,pvr-low = <0x0>;
+ xlnx,generate-plb-timespecs = <1>;
+ xlnx,mmu-enable = <1>;
+ xlnx,pvr-high = <0>;
+ xlnx,pvr-low = <0>;
plb: plb@0 {
#size-cells = <1>;
- compatible = "xlnx,plb-v46-1.03.a", "simple-bus";
+ compatible = "xlnx,plb-v46-1.02.a", "simple-bus";
ranges ;
- Ethernet_MAC: ethernet@81000000 {
- compatible = "xlnx,xps-ethernetlite-2.00.b", "xlnx,xps-ethernetlite-1.00.a";
- device_type = "network";
+ IIC_EEPROM: i2c@81600000 {
+ compatible = "xlnx,xps-iic-2.00.a";
interrupt-parent = <&xps_intc_0>;
- interrupts = < 1 0 >;
- local-mac-address = [ 02 00 00 00 00 00 ];
- reg = < 0x81000000 0x10000 >;
- xlnx,duplex = <0x1>;
- xlnx,family = "virtex4";
- xlnx,rx-ping-pong = <0x0>;
- xlnx,tx-ping-pong = <0x0>;
+ interrupts = < 4 2 >;
+ reg = < 0x81600000 0x10000 >;
+ xlnx,clk-freq = <0x5f5e100>;
+ xlnx,family = "virtex4";
+ xlnx,gpo-width = <1>;
+ xlnx,iic-freq = <0x186a0>;
+ xlnx,scl-inertial-delay = <0>;
+ xlnx,sda-inertial-delay = <0>;
+ xlnx,ten-bit-adr = <0>;
- LEDs_4Bit: gpio@81440000 {
- compatible = "xlnx,xps-gpio-1.00.a";
- reg = < 0x81440000 0x10000 >;
- xlnx,all-inputs = <0x0>;
- xlnx,all-inputs-2 = <0x0>;
- xlnx,dout-default = <0x0>;
- xlnx,dout-default-2 = <0x0>;
- xlnx,gpio-width = <0x4>;
- xlnx,interrupt-present = <0x0>;
- xlnx,is-bidir = <0x1>;
- xlnx,is-bidir-2 = <0x1>;
- xlnx,is-dual = <0x0>;
- xlnx,tri-default = <0xffffffff>;
- xlnx,tri-default-2 = <0xffffffff>;
- LEDs_Positions: gpio@81400000 {
- reg = < 0x81400000 0x10000 >;
- xlnx,gpio-width = <0x5>;
- Push_Buttons_Position: gpio@81420000 {
+ LEDs_4Bit: gpio@81400000 {
- interrupts = < 3 2 >;
- reg = < 0x81420000 0x10000 >;
- xlnx,all-inputs = <0x1>;
- xlnx,interrupt-present = <0x1>;
+ interrupts = < 5 2 >;
+ reg = < 0x81400000 0x10000 >;
+ xlnx,all-inputs = <0>;
+ xlnx,all-inputs-2 = <0>;
+ xlnx,dout-default = <0>;
+ xlnx,dout-default-2 = <0>;
+ xlnx,gpio-width = <4>;
+ xlnx,interrupt-present = <1>;
+ xlnx,is-bidir = <1>;
+ xlnx,is-bidir-2 = <1>;
+ xlnx,is-dual = <0>;
- RS232_Uart: serial@84000000 {
- clock-frequency = <100000000>;
- compatible = "xlnx,xps-uartlite-1.00.a";
- current-speed = <57600>;
+ RS232_Uart: serial@83e00000 {
+ compatible = "ns16550";
device_type = "serial";
- port-number = <0>;
- reg = < 0x84000000 0x10000 >;
- xlnx,baudrate = <0xe100>;
- xlnx,data-bits = <0x8>;
- xlnx,odd-parity = <0x0>;
- xlnx,use-parity = <0x0>;
+ interrupt-parent = <&xps_intc_0>;
+ interrupts = < 6 2 >;
+ reg = < 0x83e00000 0x10000 >;
+ reg-offset = <0x1003>;
+ reg-shift = <2>;
+ clock-frequency = <0x05f5e100>;
+ xlnx,has-external-rclk = <0>;
+ xlnx,has-external-xin = <0>;
+ xlnx,is-a-16550 = <1>;
SysACE_CompactFlash: sysace@83600000 {
compatible = "xlnx,xps-sysace-1.00.a";
- interrupts = < 2 2 >;
+ interrupts = < 3 2 >;
reg = < 0x83600000 0x10000 >;
xlnx,mem-width = <0x10>;
+ TriMode_MAC_GMII: xps-ll-temac@81c00000 {
+ #address-cells = <1>;
+ #size-cells = <1>;
+ compatible = "xlnx,compound";
+ ethernet@81c00000 {
+ compatible = "xlnx,xps-ll-temac-1.01.a";
+ device_type = "network";
+ interrupts = < 2 2 >;
+ llink-connected = <&PIM2>;
+ local-mac-address = [ 02 00 00 00 00 01 ];
+ reg = < 0x81c00000 0x40 >;
+ xlnx,bus2core-clk-ratio = <1>;
+ xlnx,phy-type = <1>;
+ xlnx,phyaddr = <1>;
+ xlnx,rxcsum = <0>;
+ xlnx,rxfifo = <0x1000>;
+ xlnx,temac-type = <1>;
+ xlnx,txcsum = <0>;
+ xlnx,txfifo = <0x1000>;
+ mpmc@0 {
+ compatible = "xlnx,mpmc-4.00.a";
+ PIM2: sdma@84600100 {
+ compatible = "xlnx,ll-dma-1.00.a";
+ interrupts = < 1 2 0 2 >;
+ reg = < 0x84600100 0x80 >;
xps_bram_if_cntlr_1: xps-bram-if-cntlr@ffffe000 {
compatible = "xlnx,xps-bram-if-cntlr-1.00.a";
reg = < 0xffffe000 0x2000 >;
xps_intc_0: interrupt-controller@81800000 {
- #interrupt-cells = <0x2>;
+ #interrupt-cells = <2>;
compatible = "xlnx,xps-intc-1.00.a";
interrupt-controller ;
reg = < 0x81800000 0x10000 >;
- xlnx,num-intr-inputs = <0x4>;
+ xlnx,num-intr-inputs = <7>;
ppc405_0_dplb1: plb@1 {
#size-cells = <1>;
ranges ;
- mpmc@0 {
- #address-cells = <1>;
- #size-cells = <1>;
- compatible = "xlnx,mpmc-4.03.a";
  And I generated with the latest device-tree from your git.
 And by the way, the ELDK version I am using is ELDK 4.2 (gcc 4.2.2)  which I believe is not uCLibc anymore but glibc. Howerver, I was using that previously with no problem with arch=ppc.
Just a little point, I think that the ML405 is slightly different in some terms. More ram ( 256 vs 64 MB DDR ), bigger FPGA ( fx20 in ml405 vs fx12 in ml403) and something extra like sata. I don't think any of those should matter except the RAM, but I believe the problem must be somewhere else as you point.
 Thanks anyway for the ml405 boot log, I'll try to play a bit with the config in order to get it working.
PS: Sorry for the long posts...
Just a little update to this. I have tried with exactly the same config as virtex4_defconfig with the only add of the uartlite driver. No success, hangs in the same point...
