Visitor thej
Problem generating bitstream on ISE/XPS/SDK on ubuntu 10.04
Hi All
          This is my first  use of EDK tools ie XPS/ISE.I was trying to do a simple example to start of with so that i get accustomed to the EDK thing using microblaze processor.
I am using Xilinx 12.1 ISE edition.I was following steps given in EDK concepts,tools,techniques guide(12.2) to get a hold of it.
       I had created system.xmp file.After export hardware design to SDK when i double clicked generating program file in ISE(project navigator) to get the netlist and bitstream i got this error.
The project file (XMP) has changed on disk.
Xilinx Port::Process Exec Failed:2
ERROR:EDK -
   Error while running "gmake -f System.make netlist".
ERROR: synthesizing XPS module failed!
  I think it failed to synthesize and couldn't execute following steps.
  Please acn anyone  help me out and tell where i might have gone wrong.I am new to this.
 I just wanted to test a example and test using ISS(Instruction set simulator) so that i can start  doing complex stuff.I don't have board right now.
   So can i use ISS to test the stuff and see the output. ??
Thej
Re: Problem generating bitstream on ISE/XPS/SDK on ubuntu 10.04
You may want to move this another forum that's more tools on Linux.
This forum is for Embedded Linux on a Xilinx platform as opposed to running tools on a Linux host.
Participant schneemann79
the problem may be due to a not available gmake on ubuntu machines.
that is why bitstream generation works in EDK (EDK calls make), but not in ISE (ISE calls gmake)
execute the following command in a shell
sudo ln -s /usr/bin/make /usr/bin/gmake
this should solve your problem.
Visitor darshp
geting error on xilinx 12.1
ERROR:EDK -
   Error while running "gmake -f system.make netlist".
not resolved with  sudo ln -s /usr/bin/make /usr/bin/gmake
error after command
ln: failed to create symbolic link `/usr/bin/gmake': File exists
Tags (3)
