rdpatel55
Problem in booting PowerPC from Network on XUPV2P board
Hi Friends,
I'm trying to implement web server on XUPV2P board from digilent.
I'm using Linux 2.6.9 kernel.  I am able to boot my processor through basic filesystem on ram (initramfs). But it has some issue, hence I can't use it any more.
I want to boot my system through network filesystem(nfs). I done it with ML405, which is having on board flash.
But XUPV2P board has no onboard flash.
I don't know how to do it without flash support.
If any one have done it then, plz let me know. I'll be greatly thankful.
Raj
rdpatel55
Hi All,
The problem is identified by myself.
There was no measurre change in the approach. All that I have done, was to provide the complete network path like target IP: serverIP: GateWay : Mask in kernel configuration.
-rdpatel
rdpatel55
Hi All,
-rdpatel
