Visitor avanthi_84
Problem with APU Interface on ML403 PPC running Linux 2.4
Hi all,
I have designed one Xilinx EDK(version 10.1) project which has UART16550, SYSACE with interrupts and added Tripple DES core(From Impulse Co-developer) with APU interface. This has worked fine in the standalone environment. So i have generated BSP from this project and Configured the linux kernel. Linux is booting successfully with the combined bitstream.
I am trying to test the compiled (GCC PowerPC cross compiler) impulse C software executable in the linux environment.
When i try to run my software , Processor hanged after the 15th character in the first printf statement as shown below.
@#./3DES
Impulse C 3DES D
 all other programs working fine.
Please see the Software main() function  below...
int main(int argc, char *argv[])
unsigned char * key = (unsigned char *) "Gflk jqo40978J0dmm$%@878"; /* 24 bytes */
co_architecture my_arch;
printf("Impulse C 3DES DEMO\n\r");
des3key(Ks, key, 0); /* Create a keyschedule for encryption */
printf("Running encryption test on FPGA ...\n\r");
my_arch = co_initialize((void *)Iterations);
co_execute(my_arch);
printf("Running encryption test on CPU ...\n\r");
des_c();
IF_SIM(printf("Press Enter key to continue...\n");)
IF_SIM(c=getc(stdin);)
return(0)
What could be the problem.
Any help would be appreciated
Reddy
