Participant garazigara
Problem with ELDK 4.2 installation
We're working with ELDK 4.1, but today we've tried to install 4.2 version in other PC and the following error appears:
 Preparing...                ########################################### [100%]
   1:xenomai-ppc_4xx        ########################################### [100%]
Configuring Xenomai kernel...
  CLEAN   /opt/ELDK/4.2/ppc_4xx/usr/src/linux-2.6.24-xenomai
  CLEAN   .tmp_versions
  CLEAN   .tmp_gas_check
  CLEAN   scripts/kconfig
  CLEAN   scripts/mod
  CLEAN   include/config
  CLEAN   .config include/asm include/linux/autoconf.h include/linux/version.h include/linux/utsrelease.h
/opt/ELDK/4.2/ppc_4xx/usr/local/xenomai/kbuild/scripts/prepare-kernel.sh: line 405: patch: command not found
prepare-kernel.sh: Unable to patch kernel 2.6.24.2 with adeos-ipipe-2.6.24-powerpc-DENX-2.1-00.patch.
error: %post(xenomai-ppc_4xx-2.4.2-1.ppc) scriptlet failed, exit status 2
bmartinez@andLinux:/tmp/cdrom$
Any idea?
Thanks in advance,
Borja and Garazi
Re: Problem with ELDK 4.2 installation
I have installed the ELDK 4.2 previously without issue.
When I look at the error below, are you sure that the patch utility is available on this host where you're installing as that's the error?
You may want to get on an ELDK mailing list for this also?
Sorry I'm not more help, but I have only installed a couple times without any issue.
Thanks, we installed the xenomai patch and it worked fine.
