05-21-2010 04:21 AM
we have a problem with SMSC Phy in Linux. We are using a custom board based on the ML507, and SMSC Phy LAN8710i (MII interface, 10/100 Mbps). We are using Linux, kernel version 2.6.31, though there is already avaliable the 2.6.33, because previously we had a problem with flash booting (we decided to return to 2.6.31).
Linux boots and starts the LLTEMAC core correctly, but it cannot detect our Phy, like it is shown below:
zImage starting: loaded at 0x00400000 (sp: 0x0078ef1c)
Allocating 0x397228 bytes for kernel ...
gunzipping (0x00000000 <- 0x0040e000:0x005b3ba3)...done 0x376054 bytes
Attached initrd image at 0x005b4000-0x0078d035
initrd head: 0x1f8b0808
Linux/PowerPC load: console=ttyS0 ip=192.168.0.2 rw root=/dev/ram
Finalizing device tree... flat tree at 0x79b300
Using Xilinx Virtex440 machine description
Linux version 2.6.31 (gjuez@ubuntu) (gcc version 4.0.0 (DENX ELDK 4.1 4.0.0)) #7
3 PREEMPT Fri May 21 10:48:16 CEST 2010
Found initrd at 0xc05b4000:0xc078d035
Zone PFN ranges:
DMA 0x00000000 -> 0x00020000
Normal 0x00020000 -> 0x00020000
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
0: 0x00000000 -> 0x00020000
MMU: Allocated 1088 bytes of context maps for 255 contexts
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048
Kernel command line: console=ttyS0 ip=192.168.0.2 rw root=/dev/ram
PID hash table entries: 2048 (order: 11, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 513792k/524288k available (3368k kernel code, 10116k reserved, 152k data
, 128k bss, 172k init)
Kernel virtual memory layout:
* 0xffffe000..0xfffff000 : fixmap
* 0xfde00000..0xfe000000 : consistent mem
* 0xfde00000..0xfde00000 : early ioremap
* 0xe1000000..0xfde00000 : vmalloc & ioremap
NR_IRQS:512
clocksource: timebase mult[1400000] shift[22] registered
Console: colour dummy device 80x25
Mount-cache hash table entries: 512
PCI: Probing PCI hardware
bio: create slab <bio-0> at 0
IP route cache hash table entries: 16384 (order: 4, 65536 bytes)
TCP established hash table entries: 65536 (order: 7, 524288 bytes)
TCP bind hash table entries: 65536 (order: 6, 262144 bytes)
TCP: Hash tables configured (established 65536 bind 65536)
TCP reno registered
rootfs image is not initramfs (no cpio magic); looks like an initrd
Freeing initrd memory: 1892k freed
ROMFS MTD (C) 2007 Red Hat, Inc.
msgmni has been set to 1007
io scheduler noop registered
io scheduler anticipatory registered
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
83e00000.serial: ttyS0 at MMIO 0x83e01003 (irq = 0) is a 16550
console [ttyS0] enabled
brd: module loaded
loop: module loaded
Device Tree Probing 'ethernet'
xilinx_lltemac 81c00000.ethernet: MAC address is now 0: a:35:15:b0: 0
xilinx_lltemac 81c00000.ethernet: XLlTemac: using DMA mode.
XLlTemac: DCR address: 0x80
XLlTemac: buffer descriptor size: 32768 (0x8000)
XLlTemac: Allocating DMA descriptors with kmalloc
XLlTemac: (buffer_descriptor_init) phy: 0x1f860000, virt: 0xdf860000, size: 0x80
00
XTemac: No PHY detected. Assuming a PHY at address 0
eth0: Dropping NETIF_F_SG since no checksum feature.
xilinx_lltemac 81c00000.ethernet: eth0: Xilinx TEMAC at 0x81C00000 mapped to 0xE
1024000, irq=16
xilinx-xps-spi f3000080.xps-spi: no IRQ found
xilinx-xps-spi f1000000.xps-spi: no IRQ found
xilinx-xps-spi f6000080.xps-spi: no IRQ found
xilinx-xps-spi f2000000.xps-spi: no IRQ found
mice: PS/2 mouse device common for all mice
TCP cubic registered
eth0: XLlTemac: Options: 0x3fa
eth0: XLlTemac: allocating interrupt 18 for dma mode tx.
eth0: XLlTemac: allocating interrupt 17 for dma mode rx.
eth0: XLlTemac: We renegotiated the speed to: 100
eth0: XLlTemac: speed set to 100Mb/s
eth0: XLlTemac: Send Threshold = 24, Receive Threshold = 4
eth0: XLlTemac: Send Wait bound = 254, Receive Wait bound = 254
IP-Config: Guessing netmask 255.255.255.0
IP-Config: Complete:
device=eth0, addr=192.168.0.2, mask=255.255.255.0, gw=255.255.255.255,
host=192.168.0.2, domain=, nis-domain=(none),
bootserver=255.255.255.255, rootserver=255.255.255.255, rootpath=
RAMDISK: gzip image found at block 0
VFS: Mounted root (ext2 filesystem) on device 1:0.
Freeing unused kernel memory: 172k init
### Application running ...
root:~>
We have read a post in the forum about a person that had also a problem with the SMSC LAN8700 Phy (a bit different from ours, but from the same manufacturer):
It seems that it can be problems with Phy drivers in Linux. I am guessing if there are any new drivers for the SMSC LAN8710i.
About the Linux configuration, we have selected both Xilinx LLTEMAC PHY support (like it is shown below ) and SMSC phy support in another configuration entry of the previous menu.
Thank you in advance,
Borja
05-28-2010 07:18 AM
The code that generates that 'error' is a simple loop that counts down from 15 (I think) to 1, polling each PHY address for a response. When it finds the address (in the range of 15 to 1), then it will report it as found and using the address discovered.
If it can't find the PHY in the range 15 to 1, it reports it as an error and procedes to use 0 as the address. So, if your PHY is at address 0 (as mine is), you will always see this 'error' message.
Joshua
05-24-2010 02:39 AM - edited 05-24-2010 03:50 AM
we finally got linux 2.6.33 working with the same configuration as in the previous case 2.6.31, adding SMSC Phy support and LLTEMAC support with MARVELL or other Phy, and we get the same result:
XTemac: No Phy detected. Assuming a Phy at address 0.
It seems to be a driver problem with the SMSC LAN8710i chip, though the driver for SMSC has support for LAN8700, which is very similar to our phy.
Update: we have opened the smsc driver of 2.6.33 and in the smsc.c code there is an entry for the LAN8710:
static struct phy_driver lan8710_driver = {
.phy_id = 0x0007c0f0, /* OUI=0x00800f, Model#=0x0f */
.phy_id_mask = 0xfffffff0,
.name = "SMSC LAN8710/LAN8720",
.features = (PHY_BASIC_FEATURES | SUPPORTED_Pause
| SUPPORTED_Asym_Pause),
.flags = PHY_HAS_INTERRUPT | PHY_HAS_MAGICANEG,
/* basic functions */
.config_aneg = genphy_config_aneg,
.read_status = genphy_read_status,
.config_init = smsc_phy_config_init,
/* IRQ related */
.ack_interrupt = smsc_phy_ack_interrupt,
.config_intr = smsc_phy_config_intr,
.suspend = genphy_suspend,
.resume = genphy_resume,
.driver = { .owner = THIS_MODULE, }
Thank you,
Borja
05-25-2010 02:50 AM
we have finally discovered what the error was. There was a problem in the soldering of a ball in the FPGA (the ball corresponding to the MDC line of the SMI interface), so we had no clock in that line. We have now tried to use another pin of the FPGA for the same purpose and now ethernet is working properly (pings are getting to the destiny). However we still get:
at start-up. We don't know why but even with Ethernet working properly, the system doesn't recognize the PHY device... ¿Could still be a problem with the PHY device?
Thank you,
Borja
05-28-2010 07:18 AM
Joshua
05-28-2010 07:22 AM
Ok, solved!! Thank you very much for the help.
Borja
