Visitor andreslc47
Problem with lltemac driver of Linux using MicroBlaze
Hello everybody,
I'm using EDK 12.1 to embed Linux on the Xilinx ML505 board.
I could get the embedded linux command line in the serial interface but I couldn't get the Hard Ethernet MAC working in Linux.
I followed this tutorial:
http://xilinx.wikidot.com/microblaze-linux
My Default kernel command string is:
console=ttyUL0 root=/dev/ram ip=on
My Initramfs source file is:
initramfs_minimal.cpio.gz
Microblaze kernel configuration is:
# Definitions for MICROBLAZE0
CONFIG_KERNEL_BASE_ADDR=0X50000000
CONFIG_XILINX_MICROBLAZE0_FAMILY="virtex5"
CONFIG_XILINX_MICROBLAZE0_USE_MSR_INSTR=1
CONFIG_XILINX_MICROBLAZE0_USE_PCMP_INSTR=1
CONFIG_XILINX_MICROBLAZE0_USE_BARREL=1
CONFIG_XILINX_MICROBLAZE0_USE_DIV=1
CONFIG_XILINX_MICROBLAZE0_USE_HW_MUL=2
CONFIG_XILINX_MICROBLAZE0_USE_FPU=2
CONFIG_XILINX_MICROBLAZE0_HW_VER="7.30.a"
The boot process is:
Early console on uartlite at 0x84000000
bootconsole [earlyser0] enabled
Ramdisk addr 0x0000003f, Compiled-in FDT at 0xc028c2c0
Linux version 3.6.0-dirty (root@Workstation) (gcc version 4.6.2 20111018 (prerelease) (crosstool-NG 1.14.1) ) #9 Fri Apr 5 15:14:01 PET 2013
setup_cpuinfo: initialising
setup_cpuinfo: Using full CPU PVR support
cache: wt_msr_noirq
setup_memory: max_mapnr: 0x10000
setup_memory: min_low_pfn: 0x50000
setup_memory: max_low_pfn: 0x60000
setup_memory: max_pfn: 0x60000
Zone ranges:
  DMA      [mem 0x50000000-0x5fffffff]
  Normal   empty
Movable zone start for each node
Early memory node ranges
  node   0: [mem 0x50000000-0x5fffffff]
On node 0 totalpages: 65536
free_area_init_node: node 0, pgdat c0358fb4, node_mem_map c0500000
  DMA zone: 512 pages used for memmap
  DMA zone: 0 pages reserved
  DMA zone: 65024 pages, LIFO batch:15
early_printk_console remapping from 0x84000000 to 0xffffd000
pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
pcpu-alloc: [0] 0
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 65024
Kernel command line: console=ttyUL0 root=/dev/ram ip=192.168.1.47
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 255068k/262144k available (3320k kernel code, 7076k reserved, 110k data, 169k bss, 908k init)
Kernel virtual memory layout:
  * 0xffffe000..0xfffff000  : fixmap
  * 0xffffd000..0xffffe000  : early ioremap
  * 0xf0000000..0xffffd000  : vmalloc & ioremap
NR_IRQS:33
interrupt-controller #0 at 0xf0000000, num_irq=6, edge=0x28
No chosen timer found, using default
timer #0 at 0xf0002000, irq=3
microblaze_timer_set_mode: shutdown
microblaze_timer_set_mode: periodic
Calibrating delay loop... 61.84 BogoMIPS (lpj=309248)
pid_max: default: 4096 minimum: 301
Mount-cache hash table entries: 512
bio: create slab <bio-0> at 0
Switching to clocksource microblaze_clocksource
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP: reno registered
UDP hash table entries: 128 (order: 0, 6144 bytes)
UDP-Lite hash table entries: 128 (order: 0, 6144 bytes)
OF: no ranges; cannot translate
msgmni has been set to 498
io scheduler noop registered
84000000.serial: ttyUL0 at MMIO 0x84000000 (irq = 5) is a uartlite
console [ttyUL0] enabled, bootconsole disabled
brd: module loaded
Device Tree Probing 'ethernet'
xilinx_lltemac ethernet.2: invalid address
xilinx_lltemac: probe of ethernet.2 failed with error -22
TCP: cubic registered
NET: Registered protocol family 1wFreeing unused kernel memory: 908k freed
Starting rcS...
++ Creating device points
++ Mounting filesystem
++ Loading system loggers
++ Starting telnet daemon
rcS Complete
/bin/sh: can't access tty; job control turned off
I don't understand what cause this problem.
I tried many ways to workaround this problem like changing the "Default kernel command string" putting ip=192.168.1.10 or ip=dhcp, using the old linux kernel and applying a patch in the dts. In spite of this changes, I couldn't get the ethernet interface working correctly.
Is there someone who had a similar problem and got a solution?.
I need some help.
Andres.
Re: Problem with lltemac driver of Linux using MicroBlaze
Your device tree is probably not good.
You should post it to and maybe we can help
Visitor djungewelter
I am running in the same Problem right now with a propritary board and a Spartan3AN. I use ISE 14.7 System Suite and the tag linux-xlnx-v14.7 out of the linux-xlnx git repository
This is the kernel boot:
[    0.000000] bootconsole [earlyser0] enabled
[    0.000000] Ramdisk addr 0x0000002e,
[    0.000000] Compiled-in FDT at 0x1c32a248
[    0.000000] Oops: kernel access of bad area, sig: 11
[    0.000000] CPU: 0 PID: 0 Comm: swapper Not tainted 3.10.0 #41
[    0.000000] task: 1c40d2b8 ti: 1c402000 task.ti: 1c402000
[    0.000000]  Registers dump: mode=1C403E94
[    0.000000]  r1=1C40C000, r2=1C401AB8, r3=113FF000, r4=113FF000
[    0.000000]  r5=113FF000, r6=00000000, r7=00000FFF, r8=11400000
[    0.000000]  r9=00001000, r10=00000001, r11=00000000, r12=10000000
[    0.000000]  r13=54C72D20, r14=00001000, r15=1C3213A0, r16=00000000
[    0.000000]  r17=1C1F55F8, r18=00000000, r19=113FF000, r20=00000000
[    0.000000]  r21=00000000, r22=1C40C1C0, r23=1C40C000, r24=10000000
[    0.000000]  r25=1C32A248, r26=00000000, r27=00000000, r28=00000000
[    0.000000]  r29=00400000, r30=00000300, r31=1C40D2B8, rPC=1C1F55F8
[    0.000000]  msr=00004600, ear=113FF000, esr=000004D2, fsr=1C329E44
[    0.000000] Kernel panic - not syncing: Attempted to kill the idle task!
[    0.000000] Early console on uartlite at 0x40030000
[    0.000000] Ramdisk addr 0x00000039,
[    0.000000] Compiled-in FDT at 0x1c32ad38
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Linux version 3.10.0 (djungewelter@kahoolawe) (gcc version 4.6.4 20120924 (Xilinx 14.1 Build EDK_P.13 28 Sep 2013) (crosstool-NG 1.18.0) ) #42 Tue Sep 1 17:40:00 CEST 2015
[    0.000000] setup_cpuinfo: initialising
[    0.000000] setup_cpuinfo: Using full CPU PVR support
[    0.000000] wt_msr_noirq
[    0.000000] setup_memory: max_mapnr: 0x10000
[    0.000000] setup_memory: min_low_pfn: 0x10000
[    0.000000] setup_memory: max_low_pfn: 0x20000
[    0.000000] setup_memory: max_pfn: 0x20000
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x10000000-0x1fffffff]
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x10000000-0x1fffffff]
[    0.000000] On node 0 totalpages: 65536
[    0.000000] free_area_init_node: node 0, pgdat 1c425a38, node_mem_map 1d0ad000
[    0.000000]   DMA zone: 512 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 65536 pages, LIFO batch:15
[    0.000000] early_printk_console remapping from 0x40030000 to 0xffffd000
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 65024
[    0.000000] Kernel command line: console=ttyS0,115200n8 console=ttyUL0,115200n8 root=/dev/ram
[    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Sorting __ex_table...
[    0.000000] Memory: 242516k/262144k available (4104k kernel code, 19628k reserved, 145k data, 587k bss, 12223k init)
[    0.000000] Kernel virtual memory layout:
[    0.000000]   * 0xffffe000..0xfffff000  : fixmap
[    0.000000]   * 0xffffd000..0xffffe000  : early ioremap
[    0.000000]   * 0x4c000000..0xffffd000  : vmalloc & ioremap
[    0.000000] NR_IRQS:33
[    0.000000] /plb@0/interrupt-controller@40020000: num_irq=7, edge=0x3f
[    0.000000] /plb@0/timer@40070000: irq=1
[    0.000000] xilinx_timer_set_mode: shutdown
[    0.000000] xilinx_timer_set_mode: periodic
[    0.149139] Calibrating delay loop... 1.10 BogoMIPS (lpj=5536)
[    0.305080] pid_max: default: 32768 minimum: 301
[    0.570092] Mount-cache hash table entries: 512
[   12.597979] device: 'platform': device_add
[   12.687290] bus: 'platform': registered
[   12.773356] bus: 'cpu': registered
[   12.783440] device: 'cpu': device_add
[   12.800028] device: 'cpu0': device_add
[   12.809293] bus: 'cpu': add device cpu0
[   13.119276] bus: 'workqueue': registered
[   13.130011] device: 'workqueue': device_add
[   13.280578] NET: Registered protocol family 16
[   13.369345] device class 'bdi': registering
[   13.477150] device class 'tty': registering
[   17.086072] device: 'writeback': device_add
[   17.095523] bus: 'workqueue': add device writeback
[   17.119851] device: 'default': device_add
[   17.259994] bio: create slab <bio-0> at 0
[   17.403088] device class 'block': registering
[   17.509280] device class 'misc': registering
[   17.588575] device class 'mdio_bus': registering
[   17.744150] bus: 'mdio_bus': registered
[   17.749164] bus: 'mdio_bus': add driver Generic PHY
[   17.920108] bus: 'serio': registered
[   17.926041] device class 'input': registering
[   18.144925] device class 'net': registering
[   18.295135] device: 'lo': device_add
[   18.649990] Switching to clocksource xilinx_clocksource
[   18.786882] device class 'mem': registering
[   18.866508] device: 'mem': device_add
[   18.953278] device: 'null': device_add
[   19.035496] device: 'zero': device_add
[   19.117076] device: 'full': device_add
[   19.199906] device: 'random': device_add
[   19.284001] device: 'urandom': device_add
[   19.391259] device: 'kmsg': device_add
[   19.477418] device: 'tty': device_add
[   19.565421] device: 'console': device_add
[   19.644604] device class 'firmware': registering
[   19.907550] NET: Registered protocol family 2
[   20.376137] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[   20.440371] TCP bind hash table entries: 2048 (order: 3, 40960 bytes)
[   20.478760] TCP: Hash tables configured (established 2048 bind 2048)
[   21.017614] TCP: reno registered
[   21.024231] UDP hash table entries: 256 (order: 1, 12288 bytes)
[   21.040502] UDP-Lite hash table entries: 256 (order: 1, 12288 bytes)
[   21.296885] NET: Registered protocol family 1
[   76.412960] device: 'plb.0': device_add
[   76.422449] bus: 'platform': add device plb.0
[   76.514069] device: '40060000.mb-fpga-info': device_add
[   76.524905] bus: 'platform': add device 40060000.mb-fpga-info
[   76.613320] device: 'mpmc.1': device_add
[   76.622399] bus: 'platform': add device mpmc.1
[   76.718199] device: '40030000.serial': device_add
[   76.729434] bus: 'platform': add device 40030000.serial
[   76.823536] device: '40080000.vsc3008-3308-config-interface': device_add
[   76.836575] bus: 'platform': add device 40080000.vsc3008-3308-config-interface
[   76.935097] device: '40020000.interrupt-controller': device_add
[   76.947211] bus: 'platform': add device 40020000.interrupt-controller
[   77.043965] device: '40040000.xps-interfpga': device_add
[   77.054904] bus: 'platform': add device 40040000.xps-interfpga
[   77.155391] device: 'xps-ll-temac.2': device_add
[   77.178216] bus: 'platform': add device xps-ll-temac.2
[   77.263558] OF: no ranges; cannot translate
[   77.276606] OF: no ranges; cannot translate
[   77.286301] device: 'ethernet.3': device_add
[   77.295879] bus: 'platform': add device ethernet.3
[   77.393583] device: '20000000.flash': device_add
[   77.403619] bus: 'platform': add device 20000000.flash
[   77.501200] device: '40070000.timer': device_add
[   77.511220] bus: 'platform': add device 40070000.timer
[   77.590050] Skipping unavailable RESET gpio -2 (reset)
[   77.780300] bus: 'clocksource': registered
[   77.791352] device: 'clocksource': device_add
[   77.803660] device: 'clocksource0': device_add
[   77.813487] bus: 'clocksource': add device clocksource0
[   77.906785] bus: 'platform': add driver alarmtimer
[   77.991123] Registering platform device 'alarmtimer'. Parent at platform
[   78.001532] device: 'alarmtimer': device_add
[   78.011053] bus: 'platform': add device alarmtimer
[   78.084717] bus: 'platform': driver_probe_device: matched device alarmtimer with driver alarmtimer
[   78.097158] bus: 'platform': really_probe: probing driver alarmtimer with device alarmtimer
[   78.113044] driver: 'alarmtimer': driver_bound: bound to device 'alarmtimer'
[   78.123613] bus: 'platform': really_probe: bound device alarmtimer to driver alarmtimer
[   78.250987] audit: initializing netlink socket (disabled)
[   78.311540] type=2000 audit(696.670:1): initialized
[   79.173925] ROMFS MTD (C) 2007 Red Hat, Inc.
[   79.204867] msgmni has been set to 473
[   80.190195] io scheduler noop registered
[   80.195331] io scheduler deadline registered
[   80.216360] io scheduler cfq registered (default)
[   80.310428] bus: 'platform': add driver uartlite
[   80.338235] bus: 'platform': driver_probe_device: matched device 40030000.serial with driver uartlite
[   80.351232] bus: 'platform': really_probe: probing driver uartlite with device 40030000.serial
[   80.370749] 40030000.serial: ttyUL0 at MMIO 0x40030000 (irq = 2) is a uartlite
[   80.381838] console [ttyUL0] enabled, bootconsole disabled
[   80.402418] device: 'ttyUL0': device_add
[   80.505818] driver: '40030000.serial': driver_bound: bound to device 'uartlite'
[   80.516915] bus: 'platform': really_probe: bound device 40030000.serial to driver uartlite
[   80.644086] device: 'ttyprintk': device_add
[   81.531184] device: '1:0': device_add
[   81.612237] device: 'ram0': device_add
[   81.775266] device: '1:1': device_add
[   81.857148] device: 'ram1': device_add
[   82.007407] device: '1:2': device_add
[   82.089827] device: 'ram2': device_add
[   82.240828] device: '1:3': device_add
[   82.337109] device: 'ram3': device_add
[   82.474599] device: '1:4': device_add
[   82.570717] device: 'ram4': device_add
[   82.707883] device: '1:5': device_add
[   82.791148] device: 'ram5': device_add
[   82.942970] device: '1:6': device_add
[   83.024818] device: 'ram6': device_add
[   83.190650] device: '1:7': device_add
[   83.272472] device: 'ram7': device_add
[   83.424381] device: '1:8': device_add
[   83.506083] device: 'ram8': device_add
[   83.657826] device: '1:9': device_add
[   83.741025] device: 'ram9': device_add
[   83.892580] device: '1:10': device_add
[   84.002216] device: 'ram10': device_add
[   84.271920] device: '1:11': device_add
[   84.374091] device: 'ram11': device_add
[   84.531093] device: '1:12': device_add
[   84.614000] device: 'ram12': device_add
[   84.772231] device: '1:13': device_add
[   84.855649] device: 'ram13': device_add
[   85.012942] device: '1:14': device_add
[   85.095691] device: 'ram14': device_add
[   85.253803] device: '1:15': device_add
[   85.336859] device: 'ram15': device_add
[   85.475997] brd: module loaded
[   85.481616] device class 'mtd': registering
[   85.585897] device: 'mtd-unmap': device_add
[   85.686733] device: 'mtd-romap': device_add
[   85.773563] device: 'mtd-rwmap': device_add
[   85.882330] bus: 'mdio_bus': add driver Vitesse VSC8244
[   85.960747] bus: 'mdio_bus': add driver Vitesse VSC8221
[   86.038034] bus: 'platform': add driver xilinx_lltemac
[   86.077413] bus: 'platform': driver_probe_device: matched device ethernet.3 with driver xilinx_lltemac
[   86.090506] bus: 'platform': really_probe: probing driver xilinx_lltemac with device ethernet.3
[   86.106281] Device Tree Probing 'ethernet'
[   86.114417] OF: no ranges; cannot translate
[   86.122343] xilinx_lltemac ethernet.3: invalid address
[   86.132199] xilinx_lltemac: probe of ethernet.3 failed with error -22
[   86.212894] device class 'uio': registering
[   86.288254] Oops: kernel access of bad area, sig: 11
[   86.295500] CPU: 0 PID: 1 Comm: swapper Not tainted 3.10.0 #42
[   86.303298] task: 2b830be0 ti: 2b834000 task.ti: 2b834000
[   86.310012]  Registers dump: mode=1F835DF0
[   86.315977]  r1=00000000, r2=00000000, r3=00006502, r4=00000000
[   86.323995]  r5=1C4208F0, r6=2919A300, r7=0000006F, r8=1C40E600
[   86.331830]  r9=00000000, r10=00000000, r11=00000000, r12=00000000
[   86.340092]  r13=00000000, r14=1C01446C, r15=1C25F508, r16=00000000
[   86.348520]  r17=1C25F558, r18=7FFFFF90, r19=00000011, r20=1C321BB0
[   86.356774]  r21=00000000, r22=00000000, r23=00000002, r24=00006502
[   86.365012]  r25=00000000, r26=00000048, r27=00000000, r28=00000000
[   86.373357]  r29=00000000, r30=00000000, r31=2B830BE0, rPC=1C25F558
[   86.381721]  msr=00004600, ear=00000064, esr=000002F2, fsr=1C43C3C4
[   86.393438] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[   86.393438]
And i'm quit sure, that it's an issue of the device tree generator v2.1.0 that is unfortunatly not any longer available in any xilinx site or git repository.
I fetched it from another website... cannot remember unfortunatly.
There must be a missing argument for the ll_temac instance, but i cannot find it.
I already added a missing line "xlnx, kind-of-intr = " for the xps_timer instance. This lead into hang on Calibrating delay loop.
My questions now:
1) Am I right that it's an issue of the DTS?
2) Where/What is the newest and hopefully working device tree generator for ISE 14.7?
or at least
What is the missing argument in the DTS for ll_temac?
My DTS:
 * Device Tree Generator version: 1.3
 * (C) Copyright 2007-2008 Xilinx, Inc.
 * (C) Copyright 2007-2008 Michal Simek
 * Michal SIMEK <monstr@monstr.eu>
 * This program is free software; you can redistribute it and/or
 * modify it under the terms of the GNU General Public License as
 * published by the Free Software Foundation; either version 2 of
 * the License, or (at your option) any later version.
 * This program is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
 * GNU General Public License for more details.
 * You should have received a copy of the GNU General Public License
 * along with this program; if not, write to the Free Software
 * Foundation, Inc., 59 Temple Place, Suite 330, Boston,
 * MA 02111-1307 USA
 * CAUTION: This file is automatically generated by libgen.
 * Version: Xilinx EDK 14.7 EDK_P.20131013
 * XPS project directory: device-tree_bsp_0
/dts-v1/;
	#address-cells = <1>;
	#size-cells = <1>;
	compatible = "xlnx,microblaze";
	model = "testing";
	aliases {
		ethernet0 = &xps_ll_temac_0;
		serial0 = &rs232;
	chosen {
		bootargs = "console=ttyS0 root=/dev/ram";
		linux,stdout-path = "/plb@0/serial@40030000";
	cpus {
		#cpus = <0x1>;
		#size-cells = <0>;
		microblaze_0: cpu@0 {
			clock-frequency = <62500000>;
			compatible = "xlnx,microblaze-8.50.c";
			d-cache-line-size = <0x10>;
			d-cache-size = <0x100>;
			device_type = "cpu";
			i-cache-line-size = <0x20>;
			i-cache-size = <0x100>;
			model = "microblaze,8.50.c";
			reg = <0>;
			timebase-frequency = <62500000>;
			xlnx,addr-tag-bits = <0x0>;
			xlnx,allow-dcache-wr = <0x1>;
			xlnx,allow-icache-wr = <0x1>;
			xlnx,area-optimized = <0x0>;
			xlnx,avoid-primitives = <0x0>;
			xlnx,base-vectors = <0x0>;
			xlnx,branch-target-cache-size = <0x0>;
			xlnx,cache-byte-size = <0x100>;
			xlnx,d-axi = <0x0>;
			xlnx,d-lmb = <0x1>;
			xlnx,d-plb = <0x1>;
			xlnx,data-size = <0x20>;
			xlnx,dcache-addr-tag = <0x0>;
			xlnx,dcache-always-used = <0x1>;
			xlnx,dcache-byte-size = <0x100>;
			xlnx,dcache-data-width = <0x0>;
			xlnx,dcache-force-tag-lutram = <0x1>;
			xlnx,dcache-interface = <0x0>;
			xlnx,dcache-line-len = <0x4>;
			xlnx,dcache-use-fsl = <0x1>;
			xlnx,dcache-use-writeback = <0x0>;
			xlnx,dcache-victims = <0x0>;
			xlnx,debug-enabled = <0x1>;
			xlnx,div-zero-exception = <0x1>;
			xlnx,dynamic-bus-sizing = <0x1>;
			xlnx,ecc-use-ce-exception = <0x0>;
			xlnx,edge-is-positive = <0x1>;
			xlnx,endianness = <0x0>;
			xlnx,family = "spartan3a";
			xlnx,fault-tolerant = <0x0>;
			xlnx,fpu-exception = <0x0>;
			xlnx,freq = <0x3b9aca0>;
			xlnx,fsl-data-size = <0x20>;
			xlnx,fsl-exception = <0x0>;
			xlnx,fsl-links = <0x0>;
			xlnx,i-axi = <0x0>;
			xlnx,i-lmb = <0x1>;
			xlnx,i-plb = <0x1>;
			xlnx,icache-always-used = <0x1>;
			xlnx,icache-data-width = <0x0>;
			xlnx,icache-force-tag-lutram = <0x0>;
			xlnx,icache-interface = <0x0>;
			xlnx,icache-line-len = <0x8>;
			xlnx,icache-streams = <0x1>;
			xlnx,icache-use-fsl = <0x1>;
			xlnx,icache-victims = <0x8>;
			xlnx,ill-opcode-exception = <0x1>;
			xlnx,instance = "microblaze_0";
			xlnx,interconnect = <0x1>;
			xlnx,interconnect-m-axi-dc-read-issuing = <0x2>;
			xlnx,interconnect-m-axi-dc-write-issuing = <0x20>;
			xlnx,interconnect-m-axi-dp-read-issuing = <0x1>;
			xlnx,interconnect-m-axi-dp-write-issuing = <0x1>;
			xlnx,interconnect-m-axi-ic-read-issuing = <0x2>;
			xlnx,interconnect-m-axi-ip-read-issuing = <0x1>;
			xlnx,interrupt-is-edge = <0x0>;
			xlnx,lockstep-slave = <0x0>;
			xlnx,m-axi-d-bus-exception = <0x0>;
			xlnx,m-axi-dc-addr-width = <0x20>;
			xlnx,m-axi-dc-aruser-width = <0x5>;
			xlnx,m-axi-dc-awuser-width = <0x5>;
			xlnx,m-axi-dc-buser-width = <0x1>;
			xlnx,m-axi-dc-data-width = <0x20>;
			xlnx,m-axi-dc-exclusive-access = <0x0>;
			xlnx,m-axi-dc-protocol = "AXI4";
			xlnx,m-axi-dc-ruser-width = <0x1>;
			xlnx,m-axi-dc-supports-narrow-burst = <0x0>;
			xlnx,m-axi-dc-supports-read = <0x1>;
			xlnx,m-axi-dc-supports-threads = <0x0>;
			xlnx,m-axi-dc-supports-user-signals = <0x1>;
			xlnx,m-axi-dc-supports-write = <0x1>;
			xlnx,m-axi-dc-thread-id-width = <0x1>;
			xlnx,m-axi-dc-user-value = <0x1f>;
			xlnx,m-axi-dc-wuser-width = <0x1>;
			xlnx,m-axi-dp-addr-width = <0x20>;
			xlnx,m-axi-dp-data-width = <0x20>;
			xlnx,m-axi-dp-exclusive-access = <0x0>;
			xlnx,m-axi-dp-protocol = "AXI4LITE";
			xlnx,m-axi-dp-supports-narrow-burst = <0x0>;
			xlnx,m-axi-dp-supports-read = <0x1>;
			xlnx,m-axi-dp-supports-threads = <0x0>;
			xlnx,m-axi-dp-supports-write = <0x1>;
			xlnx,m-axi-dp-thread-id-width = <0x1>;
			xlnx,m-axi-i-bus-exception = <0x0>;
			xlnx,m-axi-ic-addr-width = <0x20>;
			xlnx,m-axi-ic-aruser-width = <0x5>;
			xlnx,m-axi-ic-awuser-width = <0x5>;
			xlnx,m-axi-ic-buser-width = <0x1>;
			xlnx,m-axi-ic-data-width = <0x20>;
			xlnx,m-axi-ic-protocol = "AXI4";
			xlnx,m-axi-ic-ruser-width = <0x1>;
			xlnx,m-axi-ic-supports-narrow-burst = <0x0>;
			xlnx,m-axi-ic-supports-read = <0x1>;
			xlnx,m-axi-ic-supports-threads = <0x0>;
			xlnx,m-axi-ic-supports-user-signals = <0x1>;
			xlnx,m-axi-ic-supports-write = <0x0>;
			xlnx,m-axi-ic-thread-id-width = <0x1>;
			xlnx,m-axi-ic-user-value = <0x1f>;
			xlnx,m-axi-ic-wuser-width = <0x1>;
			xlnx,m-axi-ip-addr-width = <0x20>;
			xlnx,m-axi-ip-data-width = <0x20>;
			xlnx,m-axi-ip-protocol = "AXI4LITE";
			xlnx,m-axi-ip-supports-narrow-burst = <0x0>;
			xlnx,m-axi-ip-supports-read = <0x1>;
			xlnx,m-axi-ip-supports-threads = <0x0>;
			xlnx,m-axi-ip-supports-write = <0x0>;
			xlnx,m-axi-ip-thread-id-width = <0x1>;
			xlnx,m0-axis-data-width = <0x20>;
			xlnx,m0-axis-protocol = "GENERIC";
			xlnx,m1-axis-data-width = <0x20>;
			xlnx,m1-axis-protocol = "GENERIC";
			xlnx,m10-axis-data-width = <0x20>;
			xlnx,m10-axis-protocol = "GENERIC";
			xlnx,m11-axis-data-width = <0x20>;
			xlnx,m11-axis-protocol = "GENERIC";
			xlnx,m12-axis-data-width = <0x20>;
			xlnx,m12-axis-protocol = "GENERIC";
			xlnx,m13-axis-data-width = <0x20>;
			xlnx,m13-axis-protocol = "GENERIC";
			xlnx,m14-axis-data-width = <0x20>;
			xlnx,m14-axis-protocol = "GENERIC";
			xlnx,m15-axis-data-width = <0x20>;
			xlnx,m15-axis-protocol = "GENERIC";
			xlnx,m2-axis-data-width = <0x20>;
			xlnx,m2-axis-protocol = "GENERIC";
			xlnx,m3-axis-data-width = <0x20>;
			xlnx,m3-axis-protocol = "GENERIC";
			xlnx,m4-axis-data-width = <0x20>;
			xlnx,m4-axis-protocol = "GENERIC";
			xlnx,m5-axis-data-width = <0x20>;
			xlnx,m5-axis-protocol = "GENERIC";
			xlnx,m6-axis-data-width = <0x20>;
			xlnx,m6-axis-protocol = "GENERIC";
			xlnx,m7-axis-data-width = <0x20>;
			xlnx,m7-axis-protocol = "GENERIC";
			xlnx,m8-axis-data-width = <0x20>;
			xlnx,m8-axis-protocol = "GENERIC";
			xlnx,m9-axis-data-width = <0x20>;
			xlnx,m9-axis-protocol = "GENERIC";
			xlnx,mmu-dtlb-size = <0x4>;
			xlnx,mmu-itlb-size = <0x2>;
			xlnx,mmu-privileged-instr = <0x0>;
			xlnx,mmu-tlb-access = <0x3>;
			xlnx,mmu-zones = <0x2>;
			xlnx,number-of-pc-brk = <0x1>;
			xlnx,number-of-rd-addr-brk = <0x0>;
			xlnx,number-of-wr-addr-brk = <0x0>;
			xlnx,opcode-0x0-illegal = <0x1>;
			xlnx,optimization = <0x0>;
			xlnx,pc-width = <0x20>;
			xlnx,pvr = <0x2>;
			xlnx,pvr-user1 = <0x0>;
			xlnx,pvr-user2 = <0x0>;
			xlnx,reset-msr = <0x0>;
			xlnx,s0-axis-data-width = <0x20>;
			xlnx,s0-axis-protocol = "GENERIC";
			xlnx,s1-axis-data-width = <0x20>;
			xlnx,s1-axis-protocol = "GENERIC";
			xlnx,s10-axis-data-width = <0x20>;
			xlnx,s10-axis-protocol = "GENERIC";
			xlnx,s11-axis-data-width = <0x20>;
			xlnx,s11-axis-protocol = "GENERIC";
			xlnx,s12-axis-data-width = <0x20>;
			xlnx,s12-axis-protocol = "GENERIC";
			xlnx,s13-axis-data-width = <0x20>;
			xlnx,s13-axis-protocol = "GENERIC";
			xlnx,s14-axis-data-width = <0x20>;
			xlnx,s14-axis-protocol = "GENERIC";
			xlnx,s15-axis-data-width = <0x20>;
			xlnx,s15-axis-protocol = "GENERIC";
			xlnx,s2-axis-data-width = <0x20>;
			xlnx,s2-axis-protocol = "GENERIC";
			xlnx,s3-axis-data-width = <0x20>;
			xlnx,s3-axis-protocol = "GENERIC";
			xlnx,s4-axis-data-width = <0x20>;
			xlnx,s4-axis-protocol = "GENERIC";
			xlnx,s5-axis-data-width = <0x20>;
			xlnx,s5-axis-protocol = "GENERIC";
			xlnx,s6-axis-data-width = <0x20>;
			xlnx,s6-axis-protocol = "GENERIC";
			xlnx,s7-axis-data-width = <0x20>;
			xlnx,s7-axis-protocol = "GENERIC";
			xlnx,s8-axis-data-width = <0x20>;
			xlnx,s8-axis-protocol = "GENERIC";
			xlnx,s9-axis-data-width = <0x20>;
			xlnx,s9-axis-protocol = "GENERIC";
			xlnx,sco = <0x0>;
			xlnx,stream-interconnect = <0x0>;
			xlnx,unaligned-exceptions = <0x1>;
			xlnx,use-barrel = <0x1>;
			xlnx,use-branch-target-cache = <0x0>;
			xlnx,use-dcache = <0x0>;
			xlnx,use-div = <0x1>;
			xlnx,use-ext-brk = <0x1>;
			xlnx,use-ext-nm-brk = <0x1>;
			xlnx,use-extended-fsl-instr = <0x0>;
			xlnx,use-fpu = <0x0>;
			xlnx,use-hw-mul = <0x1>;
			xlnx,use-icache = <0x0>;
			xlnx,use-interrupt = <0x1>;
			xlnx,use-mmu = <0x3>;
			xlnx,use-msr-instr = <0x1>;
			xlnx,use-pcmp-instr = <0x1>;
			xlnx,use-reorder-instr = <0x1>;
			xlnx,use-stack-protection = <0x0>;
	mb_plb: plb@0 {
		#size-cells = <1>;
		compatible = "xlnx,plb-v46-1.05.a", "xlnx,plb-v46-1.00.a", "simple-bus";
		ranges ;
		mb_fpga_info_0: mb-fpga-info@40060000 {
			compatible = "xlnx,mb-fpga-info-1.00.a";
			reg = < 0x40060000 0x10000 >;
			xlnx,include-dphase-timer = <0x0>;
		mpmc@10000000 {
			#size-cells = <1>;
			compatible = "xlnx,mpmc-6.06.a";
			ranges ;
			PIM1: sdma@40050080 {
				compatible = "xlnx,ll-dma-1.00.a";
				interrupt-parent = <&xps_intc_0>;
				interrupts = < 6 2 5 2 >;
				reg = < 0x40050080 0x80 >;
		rs232: serial@40030000 {
			compatible = "xlnx,xps-uartlite-1.02.a", "xlnx,xps-uartlite-1.00.a";
			current-speed = <115200>;
			device_type = "serial";
			interrupts = < 2 0 >;
			port-number = <0>;
			reg = < 0x40030000 0x10000 >;
			xlnx,baudrate = <0x1c200>;
			xlnx,data-bits = <0x8>;
			xlnx,odd-parity = <0x0>;
			xlnx,use-parity = <0x0>;
		vsc3008_3308_config_interface_0: vsc3008-3308-config-interface@40080000 {
			compatible = "xlnx,vsc3008-3308-config-interface-1.00.a";
			reg = < 0x40080000 0x10000 >;
			xlnx,num-crosspoints = <0x10>;
			xlnx,vitesse = "VSC3308";
		xps_intc_0: interrupt-controller@40020000 {
			#interrupt-cells = <0x2>;
			compatible = "xlnx,xps-intc-2.01.a", "xlnx,xps-intc-1.00.a";
			interrupt-controller ;
			reg = < 0x40020000 0x10000 >;
			xlnx,kind-of-intr = <0x3F>;
			xlnx,num-intr-inputs = <0x7>;
		xps_interfpga_0: xps-interfpga@40040000 {
			compatible = "xlnx,xps-interfpga-1.00.a";
			reg = < 0x40040000 0x10000 >;
			xlnx,include-crc = "TRUE";
			xlnx,include-dphase-timer = <0x1>;
			xlnx,include-right-if = "FALSE";
			xlnx,include-top-if = "FALSE";
			xlnx,mplb-awidth = <0x20>;
			xlnx,mplb-clk-period-ps = <0x3e80>;
			xlnx,mplb-dwidth = <0x20>;
			xlnx,mplb-native-dwidth = <0x20>;
			xlnx,mplb-p2p = <0x0>;
			xlnx,mplb-smallest-slave = <0x20>;
		xps_ll_temac_0: xps-ll-temac@80000000 {
			#size-cells = <1>;
			compatible = "xlnx,compound";
			ethernet@80000000 {
				compatible = "xlnx,xps-ll-temac-2.03.a", "xlnx,xps-ll-temac-1.00.a";
				device_type = "network";
				interrupts = < 1 2 >;
				llink-connected = <&PIM1>;
				local-mac-address = [ 00 0a 35 00 00 00 ];
				reg = < 0x80000000 0x40 >;
				xlnx,avb = <0x0>;
				xlnx,bus2core-clk-ratio = <0x1>;
				xlnx,mcast-extend = <0x0>;
				xlnx,phy-type = <0x1>;
				xlnx,phyaddr = <0x1>;
				xlnx,rxcsum = <0x1>;
				xlnx,rxfifo = <0x800>;
				xlnx,rxvlan-strp = <0x0>;
				xlnx,rxvlan-tag = <0x0>;
				xlnx,rxvlan-tran = <0x0>;
				xlnx,stats = <0x0>;
				xlnx,temac-type = <0x2>;
				xlnx,txcsum = <0x1>;
				xlnx,txfifo = <0x800>;
				xlnx,txvlan-strp = <0x0>;
				xlnx,txvlan-tag = <0x0>;
				xlnx,txvlan-tran = <0x0>;
		xps_mch_emc_0: flash@20000000 {
			bank-width = <2>;
			compatible = "xlnx,xps-mch-emc-3.01.a", "cfi-flash";
			reg = < 0x20000000 0x8000000 >;
			xlnx,include-datawidth-matching-0 = <0x1>;
			xlnx,include-datawidth-matching-1 = <0x1>;
			xlnx,include-datawidth-matching-2 = <0x1>;
			xlnx,include-datawidth-matching-3 = <0x1>;
			xlnx,include-negedge-ioregs = <0x0>;
			xlnx,include-plb-ipif = <0x1>;
			xlnx,include-wrbuf = <0x1>;
			xlnx,max-mem-width = <0x10>;
			xlnx,mch-native-dwidth = <0x20>;
			xlnx,mch-splb-awidth = <0x20>;
			xlnx,mch-splb-clk-period-ps = <0x3e80>;
			xlnx,mch0-accessbuf-depth = <0x10>;
			xlnx,mch0-protocol = <0x0>;
			xlnx,mch0-rddatabuf-depth = <0x10>;
			xlnx,mch1-accessbuf-depth = <0x10>;
			xlnx,mch1-protocol = <0x0>;
			xlnx,mch1-rddatabuf-depth = <0x10>;
			xlnx,mch2-accessbuf-depth = <0x10>;
			xlnx,mch2-protocol = <0x0>;
			xlnx,mch2-rddatabuf-depth = <0x10>;
			xlnx,mch3-accessbuf-depth = <0x10>;
			xlnx,mch3-protocol = <0x0>;
			xlnx,mch3-rddatabuf-depth = <0x10>;
			xlnx,mem0-width = <0x10>;
			xlnx,mem1-width = <0x10>;
			xlnx,mem2-width = <0x10>;
			xlnx,mem3-width = <0x10>;
			xlnx,num-banks-mem = <0x1>;
			xlnx,num-channels = <0x0>;
			xlnx,pagemode-flash-0 = <0x1>;
			xlnx,pagemode-flash-1 = <0x1>;
			xlnx,pagemode-flash-2 = <0x0>;
			xlnx,pagemode-flash-3 = <0x1>;
			xlnx,priority-mode = <0x0>;
			xlnx,synch-mem-0 = <0x0>;
			xlnx,synch-mem-1 = <0x1>;
			xlnx,synch-mem-2 = <0x1>;
			xlnx,synch-mem-3 = <0x1>;
			xlnx,synch-pipedelay-0 = <0x1>;
			xlnx,synch-pipedelay-1 = <0x2>;
			xlnx,synch-pipedelay-2 = <0x2>;
			xlnx,synch-pipedelay-3 = <0x2>;
			xlnx,tavdv-ps-mem-0 = <0x17318>;
			xlnx,tavdv-ps-mem-1 = <0x3a98>;
			xlnx,tavdv-ps-mem-2 = <0x3a98>;
			xlnx,tavdv-ps-mem-3 = <0x3a98>;
			xlnx,tcedv-ps-mem-0 = <0x17318>;
			xlnx,tcedv-ps-mem-1 = <0x3a98>;
			xlnx,tcedv-ps-mem-2 = <0x3a98>;
			xlnx,tcedv-ps-mem-3 = <0x3a98>;
			xlnx,thzce-ps-mem-0 = <0x4e20>;
			xlnx,thzce-ps-mem-1 = <0x1b58>;
			xlnx,thzce-ps-mem-2 = <0x1b58>;
			xlnx,thzce-ps-mem-3 = <0x1b58>;
			xlnx,thzoe-ps-mem-0 = <0x3a98>;
			xlnx,thzoe-ps-mem-1 = <0x1b58>;
			xlnx,thzoe-ps-mem-2 = <0x1b58>;
			xlnx,thzoe-ps-mem-3 = <0x1b58>;
			xlnx,tlzwe-ps-mem-0 = <0x0>;
			xlnx,tlzwe-ps-mem-1 = <0x0>;
			xlnx,tlzwe-ps-mem-2 = <0x0>;
			xlnx,tlzwe-ps-mem-3 = <0x0>;
			xlnx,tpacc-ps-flash-0 = <0x61a8>;
			xlnx,tpacc-ps-flash-1 = <0x61a8>;
			xlnx,tpacc-ps-flash-2 = <0x61a8>;
			xlnx,tpacc-ps-flash-3 = <0x61a8>;
			xlnx,twc-ps-mem-0 = <0x11170>;
			xlnx,twc-ps-mem-1 = <0x3a98>;
			xlnx,twc-ps-mem-2 = <0x3a98>;
			xlnx,twc-ps-mem-3 = <0x3a98>;
			xlnx,twp-ps-mem-0 = <0xc350>;
			xlnx,twp-ps-mem-1 = <0x2ee0>;
			xlnx,twp-ps-mem-2 = <0x2ee0>;
			xlnx,twp-ps-mem-3 = <0x2ee0>;
			xlnx,xcl0-linesize = <0x4>;
			xlnx,xcl0-writexfer = <0x1>;
			xlnx,xcl1-linesize = <0x4>;
			xlnx,xcl1-writexfer = <0x1>;
			xlnx,xcl2-linesize = <0x4>;
			xlnx,xcl2-writexfer = <0x1>;
			xlnx,xcl3-linesize = <0x4>;
			xlnx,xcl3-writexfer = <0x1>;
		xps_timer_0: timer@40070000 {
			compatible = "xlnx,xps-timer-1.02.a", "xlnx,xps-timer-1.00.a";
			interrupts = < 0 0 >;
			reg = < 0x40070000 0x10000 >;
			xlnx,count-width = <0x20>;
			xlnx,gen0-assert = <0x1>;
			xlnx,gen1-assert = <0x1>;
			xlnx,one-timer-only = <0x0>;
			xlnx,trig0-assert = <0x1>;
			xlnx,trig1-assert = <0x1>;
	mpmc_0: memory@10000000 {
		device_type = "memory";
		reg = < 0x10000000 0x10000000 >;
