dlwalter
Problems booting the pre-built petalinux images in 2016.2
I am attempting to follow the workflow in UG977 as well as in the Xilinx wiki
When I create a new project using
petalinux-create --type project --template zynq --name MyProject
I cd to that directory but the files are config.project, and two folders hw-description and subsystems.
The next step in the Xilinx wiki is to run the following command
petalinux-boot --qemu --prebuilt 3
Which failes with
ERROR: Failed to setup zImage \'home/user/XilinxWorkspace/MyProject/pre-built/linux/images/zImage\' to boot.  Image doesn't exist.
Which makes sense since petalinux-create did not include the pre-built image folder into the project.
Am I missing a step or does the Wiki and manual need to be updated?
achutha
@dlwalter
You can download the required BSP for 2016.2 from the link http://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/embedded-design-tools.html
Follow the instructions in UG1144 starting pages 17 & 34. This will allow you to extract the BSP and boot image on QEMU using pre-built images.
Achutha
smarell
Community Manager
Community Manager
Please use the command- petalinux-create --type project -s <location of HW boards BSPs in PetaLinux Install directory>. This will create a prebuilt image.
achutha
@dlwalter
Achutha
dlwalter
Yes, thank you. Neither the workflow tutorial (UG 1156) nor the Xilinx wiki page give a link to the BSP downloads like UG1144 does.
I was searching the zedboard.org site for the bsp, I didn't realize they were available on xilinx.com.
