tscott.phoenix
Problems with Linux/CAN on Zedboard
I'm trying to get CAN going under Linux on my Zedboard but things are not working for me.  The kernel appears to see the CAN device is present, but as soon as I try to enable things via “ifconfig can0 up” or “ip link set can0 up”, the CAN driver locks up.
I’m following the instructions listed here:
http://www.wiki.xilinx.com/Linux+CAN+driver
I'm running the kernel found here:
https://github.com/Xilinx/linux-xlnx/
The specific repo revision I'm using is 6530a9b36265deb4bcf25298ba4e1aba443f6bd4 which is the current tip of the master-next branch.
I added the following entry into my zynq-zed.dts file:
ps7_can_0: ps7-can@e0008000 {
clock-names = "ref_clk", "aper_clk";
clocks = <&clkc 19>, <&clkc 36>;
compatible = "xlnx,zynq-can-1.0";
interrupt-parent = <&ps7_scugic_0>;
interrupts = <0 28 4>;
reg = <0xe0008000 0x1000>;
I've ensured that the CAN support in the kernel is enabled and built as part of the kernel (ie. it is not a loadable module).  Here is what dmesg is reporting:
# dmesg | grep -i can
[    1.077239] vcan: Virtual CAN interface driver
[    1.081615] CAN device driver interface
[    1.089399] XILINX_CAN e0008000.ps7-can: reg_base=0xe086a000 irq=60 clock=7999999, tx fifo depth:64
[    1.418208] can: controller area network core (rev 20120528 abi 9)
[    1.428933] can: raw protocol (rev 20120528)
[    1.433223] can: broadcast manager protocol (rev 20120528 t)
[    1.439054] can: netlink gateway (rev 20130117) max_hops=1
I configure the bit timing by doing this: “ip link set can0 type can bitrate 250000".  dmesg reports:
[  101.705476] XILINX_CAN e0008000.ps7-can can0: bitrate error 0.0%
[  101.711529] XILINX_CAN e0008000.ps7-can can0: brp=8,prop=1,phase_seg1:1,phase_reg2=1,sjw=1
[  101.719921] XILINX_CAN e0008000.ps7-can can0: Setting BTR0=0x07 BTR1=0x01
[  101.726970] XILINX_CAN e0008000.ps7-can can0: BRPR=0x00000007, BTR=0x00000001
"ip link" shows:
# ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: can0: <NOARP,ECHO> mtu 16 qdisc noop state DOWN mode DEFAULT group default qlen 10
    link/can
3: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DEFAULT group default qlen 1000
    link/ether 00:0a:35:00:01:22 brd ff:ff:ff:ff:ff:ff
“ifconfig –a” shows:
# ifconfig -a
can0      Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
          NOARP  MTU:16  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:10
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
          Interrupt:60 Memory:e0008000-e0008fff
eth0      Link encap:Ethernet  HWaddr 00:0A:35:00:01:22
          inet addr:204.54.81.137  Bcast:204.54.81.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:4263 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1618 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:3880919 (3.7 MiB)  TX bytes:257849 (251.8 KiB)
          Interrupt:54 Base address:0xb000
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:12 errors:0 dropped:0 overruns:0 frame:0
          TX packets:12 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:948 (948.0 B)  TX bytes:948 (948.0 B)
When I issue “ifconfig can0 up” things hang.  After a bit of debugging, I discovered that hang is occurring in xilinx_can.c in the xcan_start() method, where it while-loops endlessly waiting for the NORMAL bit in XCAN_SR_OFFSET to get set.
One oddity that I’ve noticed is that I cannot even use U-Boot to query CAN controller registers.  If I interrupt the boot process and enter “md.l 0xe0008018 1” to read the CAN SR, U-Boot just hangs.  Other CAN registers fail similarly.  I see this behavior with both CAN0 and CAN1.
Any thoughts?
--tim
tscott.phoenix
After manually configuring those pins, I was able to get the CAN driver to correctly initialize:
"devmem 0xf8000728 32 0x1221"
"devmem 0xf800072c 32 0x1220"
"ip link set can0 up" --> This now works!
--tim
tscott.phoenix
Here's some more debugging info.  I can run "devmem 0xe0008000" when the kernel is booted up and it appears to be correctly reading from the CAN controller.  To try and make sure that I was actually reading / writing to the CAN registers I did the following experiment:
# ip link set can0 type can bitrate 250000
# devmem 0xe0008008
0x00000007
# devmem 0xe000800c
0x00000001
# devmem 0xe0008000 32 1
# devmem 0xe0008008
0x00000000
# devmem 0xe000800c
0x00000000
I set the bitrate, verified that the BRPR and BTR registers were set as expected, commanded a reset of CAN, and then finally verified that the BRPR and BTR registers were back to their reset values.  That all worked.
--tim
tscott.phoenix
I just read this in the TMR:
After the CEN bit is set to 1 the CAN controller waits for a sequence of 11 recessive bits before exiting configuration mode.
I don't have any of the MIO pins configured properly nor do I have my PHY connected to the Zedboard.  This may be this issue.
tscott.phoenix
--tim
ethanlu2
Linaro ubuntu linux can't find command devmem??
Do i need to install specific software for devman command?
tscott.phoenix
I've never used Linaro so I'm afraid I'm not going to be much help there.
FWIW, I believe I was using buildroot to generate the filesystem and related tools.  The kernel I used is mentioned in my initial post.
oabril
I think a have the same problems:
This is my config:
in pcw.dtsi:
&can0 {
status = "okay";
in zynq-7000.dtsi
can0: can@e0008000 {
status = "disabled";
clock-names = "can_clk", "pclk";
interrupt-parent = <&intc>;
tx-fifo-depth = <0x40>;
rx-fifo-depth = <0x40>;
dmesg | grep -i can
[ 1.887537] CAN device driver interface
[ 2.217030] can: controller area network core (rev 20120528 abi 9)
[ 2.228078] can: raw protocol (rev 20120528)
[ 2.232397] can: broadcast manager protocol (rev 20120528 t)
[ 2.238055] can: netlink gateway (rev 20130117) max_hops=1
ip link set can0 type can bitrate 125000
[ 35.393130] xilinx_can e0008000.can can0: bitrate error 0.0%
ifconfig can0 up
[ 41.929562] xilinx_can e0008000.can can0: timed out for correct mode
[ 41.935841] xilinx_can e0008000.can can0: xcan_chip_start failed!
ifconfig: SIOCSIFFLAGS: Connection timed out
Would you please explain me what do you mean write 0x1221 and 0x1220 to the devmem ???
If I do that ifconfig can0 up works, but if a send data with cansend nothing happens.
Do you have an idea that could be happening?
tscott.phoenix
It's been quite a while since I worked on this, but I believe the devmem operations were simply to configure the MIO pins for CAN operation.
Here are the last notes I took about this.  Hope it helps:
  • To get this going requires two updates:
    • DTS
  • /etc/network/interfaces
auto can0
iface can0 inet manual
        pre-up ip link set $IFACE type can bitrate 250000
        pre-up /sbin/devmem 0xf8000728 32 0x1621
        pre-up /sbin/devmem 0xf800072c 32 0x1620
        up /sbin/ifconfig $IFACE up
        down /sbin/ifconfig $IFACE down
--> This configures the MIO pins on the board's JE header for 3.3v / CAN operation and initializes the CAN interface
--tim
oabril
From your message: "configure the MIO pins for CAN operation."
That's something I dont understand, the way I configure the Pin-out is by Vivado (in block design), adding a CAN0 in the pins 10 and 11 in the MIO. Then after exporting my design I have everything working in my linux.
Would you explain me a little more about this values and where can I found info about that??
tscott.phoenix
You still have to configure the operation of those pins.
Look for this file: ug585-Zynq-7000-TRM.pdf and search for the address 0xF8000728 for further information about the pin configuration.
--tim
htkim40
I guess I am running into the exact same problem as you with the exact same error. Did you ever find a solution to your issue?
THanks,
Jason
