Profiling Linux Applications
Has anyone any tips for the best way to profile a Linux application running on ZC702 (Linux release is 2014.2).
Based on a bit of investigation I did I would say perf is a good approach (but not an expert yet). It is in the kernel tree and builds easily even though it's not in the normal ramdisk. It seems like a newer better approach than oprofile.
My notes show I got perf to build (and run) by setting CROSS_COMPILE=arm-xilinx-linux-gnueabi- and ARCH=arm, then make works from kernel/tools/perf directory.
Some links from my notes.
http://en.wikipedia.org/wiki/Perf_(Linux)
http://www.brendangregg.com/perf.html (really good, has build instructions)
https://perf.wiki.kernel.org/index.php/Tutorial
You mean like perf?
Yes, I mean like perf/oprofile. Thanks for the information I will give it a try.
Got it built OK, but it does not seem to work! For example perf top just sits there and reports no activity is occurring. I have checked the kernel configuration and the performance counters etc. are all enabled. Can anyone shed any light on the subject.
I also can't get perf to collect any data. I've found what looks to be the relevent kernel option to enable teh perf logging but it hasn't helped.
I've also compiled up a version of valgrind, but I can't manage to sort out a debug version of libc so that valgrind will run.
There appears to be more gotchas around this than the previous posters imply.
