01-09-2020 07:55 PM
ERROR: pmu-firmware-2019.1+gitAUTOINC+26c14d9861-r0 do_configure: Function failed: do_configure (log file is located at /home/joris/PYNQ/sdbuild/build/Ultra96/petalinux_project/build/tmp/work/ultra96_zynqmp-xilinx-linux/pmu-firmware/2019.1+gitAUTOINC+26c14d9861-r0/temp/log.do_configure.9244) ERROR: Logfile of failure stored in: /home/joris/PYNQ/sdbuild/build/Ultra96/petalinux_project/build/tmp/work/ultra96_zynqmp-xilinx-linux/pmu-firmware/2019.1+gitAUTOINC+26c14d9861-r0/temp/log.do_configure.9244 Log data follows: | DEBUG: Executing shell function do_configure | MISC_ARG is -yamlconf /home/joris/PYNQ/sdbuild/build/Ultra96/petalinux_project/build/tmp/work/ultra96_zynqmp-xilinx-linux/pmu-firmware/2019.1+gitAUTOINC+26c14d9861-r0/pmu-firmware.yaml | APP_ARG is -app "ZynqMP PMU Firmware" | Using xsct from: /opt/petalinux-2019.1/tools/xsct/bin/xsct | cmd is: xsct -sdx -nodisp /home/joris/PYNQ/sdbuild/build/Ultra96/petalinux_project/build/tmp/work/ultra96_zynqmp-xilinx-linux/pmu-firmware/2019.1+gitAUTOINC+26c14d9861-r0/app.tcl -ws /home/joris/PYNQ/sdbuild/build/Ultra96/petalinux_project/build/tmp/work/ultra96_zynqmp-xilinx-linux/pmu-firmware/2019.1+gitAUTOINC+26c14d9861-r0/build -pname pmu-firmware -rp /home/joris/PYNQ/sdbuild/build/Ultra96/petalinux_project/build/tmp/work/ultra96_zynqmp-xilinx-linux/pmu-firmware/2019.1+gitAUTOINC+26c14d9861-r0/git -processor psu_pmu_0 -hdf /home/joris/PYNQ/sdbuild/build/Ultra96/petalinux_project/build/tmp/deploy/images/ultra96-zynqmp/Xilinx-ultra96-zynqmp.dsa -arch 32 -app "ZynqMP PMU Firmware" -yamlconf /home/joris/PYNQ/sdbuild/build/Ultra96/petalinux_project/build/tmp/work/ultra96_zynqmp-xilinx-linux/pmu-firmware/2019.1+gitAUTOINC+26c14d9861-r0/pmu-firmware.yaml | INFO: [Hsi 55-1698] elapsed time for repository loading 0 seconds | INFO: Update hw pmu-firmware_plat project | Loading the sw platform from /home/joris/PYNQ/sdbuild/build/Ultra96/petalinux_project/build/tmp/work/ultra96_zynqmp-xilinx-linux/pmu-firmware/2019.1+gitAUTOINC+26c14d9861-r0/build/pmu-firmware_plat/platform.spr | Reading the platform : "pmu-firmware_plat" | Opening the hardware design, this may take few seconds. | App name | Description | ERROR:set_bsp_conf set dt_overlay TRUE: Cannot set Property "dt_overlay" with TRUE | | ERROR: Could not find the bsp config parameter. | to get the list of valida parameters on "os" run "bsp listparams -os" | to get the list of valida parameters on "processor" instance run "bsp listparams -proc" | to get the list of valida parameters on "library" run "bsp listparams -lib <libraryname>" | Error in copy exception raised, while copying /opt/petalinux/tools/xsct/scripts/xsct/data/scw/generic.readme To /home/joris/PYNQ/sdbuild/build/Ultra96/petalinux_project/build/tmp/work/ultra96_zynqmp-xilinx-linux/pmu-firmware/2019.1+gitAUTOINC+26c14d9861-r0/build/pmu-firmware_plat/export/pmu-firmware_plat/sw/sysconfig1/boot | Exception Message boost::filesystem::copy_file: No such file or directory: "/opt/petalinux/tools/xsct/scripts/xsct/data/scw/generic.readme", "/home/joris/PYNQ/sdbuild/build/Ultra96/petalinux_project/build/tmp/work/ultra96_zynqmp-xilinx-linux/pmu-firmware/2019.1+gitAUTOINC+26c14d9861-r0/build/pmu-firmware_plat/export/pmu-firmware_plat/sw/sysconfig1/boot/generic.readme" | INFO: create bsp using pmu-firmware_domain | App name | Description | Creating app at: /home/joris/PYNQ/sdbuild/build/Ultra96/petalinux_project/build/tmp/work/ultra96_zynqmp-xilinx-linux/pmu-firmware/2019.1+gitAUTOINC+26c14d9861-r0/build | App name | Description | Note: updating the existing app sources with modified platform. | /opt/petalinux/tools/xsct/gnu/microblaze/lin | ERROR: [Common 17-39] 'hsi::generate_app' failed due to earlier errors. | | while executing | "::hsi::generate_app -app $hsitemplate" | (procedure "app" line 346) | invoked from within | "app create -name $params(pname) -lang c -template $params(app) -plnx" | invoked from within | "if { $params(ws) ne "" } { | #Local Work Space available | if { $params(pname) ne "" } { | # hwpname/bspname is empty then default it to pname+_hwproj/b..." | (file "/home/joris/PYNQ/sdbuild/build/Ultra96/petalinux_project/build/tmp/work/ultra96_zynqmp-xilinx-linux/pmu-firmware/2019.1+gitAUTOINC+26c14d9861-r0/app.t..." line 139) | WARNING: exit code 1 from a shell command. | ERROR: Function failed: do_configure (log file is located at /home/joris/PYNQ/sdbuild/build/Ultra96/petalinux_project/build/tmp/work/ultra96_zynqmp-xilinx-linux/pmu-firmware/2019.1+gitAUTOINC+26c14d9861-r0/temp/log.do_configure.9244) ERROR: Task (/opt/petalinux-2019.1/components/yocto/source/aarch64/layers/meta-xilinx-tools/recipes-bsp/pmu-firmware/pmu-firmware_git.bb:do_configure) failed with exit code '1' NOTE: Tasks Summary: Attempted 613 tasks of which 612 didn't need to be rerun and 1 failed.
I am trying to build the Pynq image for ultra96-v2. I checked out the image_v2.5 branch of both pynq repo and ultra96 repo and set up the symlinks as described in the u96 repo.
01-10-2020 05:35 PM
yes I do, I am not sure what the issue was maybe my environment was bad. I closed everything and sourced again and now it works fine.
01-10-2020 12:02 AM
Looks like xsct isnt getting invoked. Do you have the SDK tools installed?
01-10-2020 05:35 PM
