keshava7887
QSPI boot
I am trying to boot my custom board based zynq-mpsoc zu4eg device  using QSPI mode,
I am Generating BOOT.BIN using below command.
petalinux-package --boot --fsbl images/linux/zynqmp_fsbl.elf --atf images/linux/bl31.elf --u-boot images/linux/u-boot.elf --fpga ssdtest.bit.
I am able to boot the board in jtag mode.
I have copied BOOT.bin to mtd partition using flashcp -v ./BOOT.BIN /dev/mtd0
I have copied image.ub to mtd partition using flashcp -v ./image /dev/mtd2
When I tried to boot board in  QSPI  mode, device stops at uboot with following error.
"Hit any key to stop autoboot: 0
SF: Detected mx66u2g45g with page size 256 Bytes, erase size 64 KiB, total 256 MiB
device 0 offset 0x3e80000, size 0x80000
SF: 524288 bytes @ 0x3e80000 Read: OK
## Executing script at 20000000
Wrong image format for "source" command
SCRIPT FAILED: continuing...
No MMC device available
SCRIPT FAILED: continuing... "
Linux qspi memory partition.
[ 3.300564] spi-nor spi0.0: mx66u2g45g (262144 Kbytes)
[ 3.305709] 3 fixed-partitions partitions found on MTD device spi0.0
[ 3.312052] Creating 3 MTD partitions on "spi0.0":
[ 3.316836] 0x000000000000-0x000000ec0000 : "boot"
[ 3.322323] 0x000000ec0000-0x000000f00000 : "bootenv"
[ 3.327969] 0x000000f00000-0x000005500000 : "kernel"
 I am loading my image.ub at different location in flash  but uboot script is looking for image.ub at different location.
Can anyone guide me how to fix uboot to correctly read boot image.ub location and tell me if I am doing something wrong in generating binaries.
Or state out if I am missing any steps.
I have tested my image.ub in same uboot by copying image.ub from vitis IDE XSCT command  using this command 'dow -data image.ub 0x10000000' then 'bootm 0x10000000' in uboot, linux boots with this settings.
And also suggest me document which tell how to boot from QSPI for zcu106 board.
patocarr
Hi @keshava7887
  You will need an extra partition in QSPI to hold the boot.scr script. I've posted about this in my blog U-Boot-changes-to-distro-boot for more details.
-Pat
Give kudos if helpful. Accept as solution if it solves your problem.
https://tuxengineering.com/blog
keshava7887
I am using petalinux 2020.1 tools.
jrhtech
In 2020 you also need to put the Uboot boot script, boot.scr, in the flash also.
jeff
keshava7887
Thanks jrhtech,
Can you tell how to load and were to place boot.scr in the flash.
jrhtech
Sorry for the delayed response; however, I do not know the specific answer. I boot from QSPI->eMCC and my eMCC just has a filesystem that I copy the boot.scr and image.ub onto. I know you need to write the files at a specific address that u-boot needs to read from but I'm not sure where you set that up.
jeff
patocarr
Hi @keshava7887
-Pat
keshava7887
Hi Patocarr,
Thanks for your help.
Keshava murthy p
