Visitor sdhunna
Qemu Axi DMA Driver Fails to Load
I have a microzed project that works on the microzed with respect to running the Xilinx AXI DMA test.
According to the petlinux guide, Qemu supports the AXI DMA IP.
I tried starting a qemu session but the linux driver failed to load:
petalinux-boot --qemu --kernel
root@MZ7020_2015_2_1:~# dmesg | grep axidma
root@MZ7020_2015_2_1:~# dmesg | grep dma
dma-pl330 f8003000.dmac: Loaded driver for PL330 DMAC-241330
dma-pl330 f8003000.dmac: DBUFF-256x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
xilinx-dma 44000000.dma: Invalid channel compatible node
xilinx-dma 44000000.dma: Probing channels failed
xilinx-dma: probe of 44000000.dma failed with error -22
I suspect this is because the kernel option doesn't include the bitstream so the driver fails to load.  Is there a way to do that?
Participant pete_128
Re: Qemu Axi DMA Driver Fails to Load
So QEMU doesn't handle bitstreams, and instead just models what it can based on your DTB. Does your DTB contain your DMA peripheral?
Visitor sdhunna
The pl.dtsi file contains it.  It got generated when I did the --get-hw-description.  I'm not sure if qemu see's the dtb file, unless there's a way to pass it during the command?
amba_pl: amba_pl {
#address-cells = <1>;
#size-cells = <1>;
compatible = "simple-bus";
ranges ;
axi_dma_0: dma@44000000 {
compatible = "xlnx,axi-dma";
interrupt-parent = <&intc>;
interrupts = <0 29 4 0 30 4>;
reg = <0x44000000 0x1000>;
xlnx,include-sg ;
dma-channel@44000000 {
compatible = "xlnx,axi-dma-mm2s-channel";
interrupts = <0 29 4>;
xlnx,datawidth = <0x20>;
xlnx,device-id = <0x0>;
dma-channel@44000030 {
compatible = "xlnx,axi-dma-s2mm-channel";
interrupts = <0 30 4>;
QEMU must be passes a dtb, otherwise it doesnt know what system to create. It may just be getting a stock PS DTS though. Does petalinux-boot --help provide an option for dtb override? You may need to roll pl.dtsi in with the PS dts and pass it all to QEMU.
Visitor sdhunna
It seems to be in there:
root@MZ7020_2015_2_1:/proc/device-tree/amba_pl# ls
#address-cells compatible name
#size-cells dma@44000000 ranges
QEMU has the capability to use separate DTBs for hw instantiation and the kernel. Can we see the full QEMU command line?
Visitor sdhunna
That's how I started it:
Yeh that will in turn call the QEMU executable which has a command line format of its own. The qemu executable is qemu-system-*.
Visitor sdhunna
Ok, I see.  Here it is:
INFO: Starting arm QEMU
INFO: qemu-system-aarch64 -L /opt/petalinux/petalinux-v2015.2.1-final/etc/qemu -M arm-generic-fdt-plnx -machine linux=on -serial /dev/null -serial mon:stdio -display none -kernel /home/user1/MicroZedBsp/MZ7020_2015_2_1/build/qemu_image.elf -gdb tcp::9000 -dtb /home/user1/MicroZedBsp/MZ7020_2015_2_1/images/linux/system.dtb -tftp /tftpboot
Ok, so it is using only one dtb which means same for software and hardware. In QEMU hit ctrl-a then C and type info qtree to see if your DMA hardware is there. If not QEMU is ignoring your dtb nodes for some reason.
Visitor sdhunna
(qemu) info qtree
bus: main-system-bus
type System
dev: a9-scu, id ""
num-cpu = 2 (0x2)
dev: arm.pl35x, id ""
x = 3 (0x3)
(qemu)
Observer edu30692
Hi, I have the same problem. Did you managed to solve it?
