zan_zhan@amat.com
Quad SPI's C_FIFO_DEPTH doesn't match the definition in TCL script of IP generation
All,
I am using below tcl to generate a quad spi ctrl which is used to work with STARTUPE3 to access external qspi flash.
create_ip -name axi_quad_spi -vendor xilinx.com -library ip -version 3.2 -module_name axi_quad_spi_0
set_property -dict [list CONFIG.C_SPI_MEMORY {3} CONFIG.C_USE_STARTUP {1} CONFIG.C_USE_STARTUP_INT {0} CONFIG.C_SPI_MODE {2} CONFIG.C_NUM_SS_BITS {1} CONFIG.C_SCK_RATIO {2} CONFIG.C_FIFO_DEPTH {256} CONFIG.C_XIP_MODE {0} CONFIG.C_TYPE_OF_AXI4_INTERFACE {0}] [get_ips axi_quad_spi_0]
generate_target {instantiation_template} [get_files ./my_vivado_cores/my_vivado_cores.srcs/sources_1/ip/axi_quad_spi_0/axi_quad_spi_0.xci]
generate_target all [get_files ./my_vivado_cores/my_vivado_cores.srcs/sources_1/ip/axi_quad_spi_0/axi_quad_spi_0.xci]
create_ip_run [get_files -of_objects [get_fileset sources_1] ./my_vivado_cores/my_vivado_cores.srcs/sources_1/ip/axi_quad_spi_0/axi_quad_spi_0.xci]
launch_runs -jobs 16 axi_quad_spi_0_synth_1
set ip_files [get_files -compile_order sources -used_in simulation -of_objects [get_files axi_quad_spi_0.xci]]
foreach file $ip_files {
puts "[get_property LIBRARY $file] $file"
In generated data files, I can observe the parameters as shown below.
spirit:referenceId="BUSIFPARAM_VALUE.SPI_CLK.FREQ_HZ">100000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.SPI_CLK.PHASE">0.000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.Async_Clk">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_DUAL_QUAD_MODE">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_FAMILY">kintexuplus</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_FIFO_DEPTH">256</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_INSTANCE">axi_quad_spi_inst</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_LSB_STUP">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_NUM_SS_BITS">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_NUM_TRANSFER_BITS">8</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_SCK_RATIO">2</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_SELECT_XPM">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_SHARED_STARTUP">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_SPI_MEMORY">3</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_SPI_MEM_ADDR_BITS">24</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_SPI_MODE">2</spirit:configurableElementValue>
After finishing whole design's synthesis, I found the different C_FIFO_DEPTH (Depth = 16 instead of 256) of this SPI IP in Vivado.
Question1:
Why FIFO depth of IP in Vivado Gui is different from the definition of Tcl script and .xci file?
Question2:
In my tcl script and the generated .xci file, I saw C_SPI_MEMORY = 3, but can not find the explanation in pg153.
What does C_SPI_MEMORY = 3 mean?
What does C_SPI_MEMORY = 2 mean?
What does C_SPI_MEMORY = 1 mean?
What does C_SPI_MEMORY = 0 mean?
Thank you very much in advance!
Yours Sincerely,
