Observer fd9750
Question on Polling a Gpio pin
I have a few bits of code running on a mircozed board that I use to
    a) set up gpio pin 0  to trigger  interrupts on a rising edge.
    b) monitor the condition of gpio0 using the linux poll function.
    c) when the interrupt occurs: do something and wait till the next interrupt occurs.
This is the code to set up the gpio pin:
static int GpioPin = FPGA_GPIO_PIN;
static int GpioFileDescriptor=0;
static int PollResult;
static int poll_nr_fds = 1;
static struct pollfd GpioPoll[1];
int AllocateGpio( void )
   char buf[MAX_GPIO_BUF];
   if ( gpio_export ( GpioPin ) < 0 )
      GpioPin = -1;
      return ( -1 );
   else
      gpio_set_dir( GpioPin, GpioInput );                // set as input
      gpio_set_edge( GpioPin, "rising" );                // set as rising edge interrupt
      GpioFileDescriptor = gpio_fd_open( GpioPin );      // open the GPIO "file"
      if ( GpioFileDescriptor < 0 )
         GpioFileDescriptor = 0;
         return ( -1 );
      else
         memset( (void*)GpioPoll, 0, sizeof( GpioPoll ) );  // erase the poll structure
         GpioPoll[0].fd = GpioFileDescriptor;               // setup the poll structure (file descriptor)
         GpioPoll[0].events = POLLPRI;                      // setup the poll structure (event flags)
         read( GpioPoll[0].fd, buf, MAX_GPIO_BUF);          // initial read to prevent false interrupt report
   return ( 0 );
That bit of code is called once and works just fine. I have checked the cretaed "files" using the command shell and everything works.
This is the bit of code I use to monitor the condition and wait for an interrupt to occur:
int GpioWaitForInterrupt( void )
   int timeout = GPIO_POLL_TIMEOUT;
   read( GpioPoll[0].fd, buf, MAX_GPIO_BUF);                      // read again to clear pending interrupt report
   NetworkScanTrigger = OFF;                                      // clear to prevent pending trigger
   while ( !sInterupted )
      if ( (GpioPin >= 0) && GpioFileDescriptor )
         PollResult = poll( GpioPoll, poll_nr_fds, timeout );
         if (PollResult < 0 ) return (GPIO_WAIT_ERROR);
         if (!PollResult)
         { // timeout !
            if (NetworkScanTrigger)    // trigger via network ?
               return ( GPIO_WAIT_TRIGGER );
         else
            if (GpioPoll[0].revents & POLLPRI)     // check for interrupt
               read( GpioPoll[0].fd, buf, MAX_GPIO_BUF);          // read again to clear interrupt report
               return ( GPIO_WAIT_END);
      else
   return (GPIO_WAIT_STOP);
 The problem I have is that the first time I call the second bit of code it correctly waits for the interrupt to occur, returns GPIO_WAIT_END so that I know the exit cause is an interrupt and I can do whatever is necessary.
When I call the wait function again it exits with the same return value although I am sure there was no edge signal change on that input in the mean time.
Originally I always had an initial interrupt after setting up the gpio pin but I cured that by adding a "read" function to prevent it from happening. I thought the extra "read" functions Would prevent spurious or false interrupts but it seems I am missing something as once the first interrupt occurs I keep getting them continuously while the gpio pin never changes again.
Anyone have any suggestions or ideas as to what I am doing wrong ?
Tags (3)
Re: Question on Polling a Gpio pin
I can't say I've done what you're trying to do, but was interested in it. I didn't see you doing this below but I might have missed it.
Have you reviewed https://www.kernel.org/doc/Documentation/gpio/sysfs.txt as it shows the need to seek or close and reopen the file after an event?
John
After
		poll(2) returns, either lseek(2) to the beginning of the sysfs
		file and read the new value or close the file and re-open it
		to read the value.
John
After
		to read the value.
Observer fd9750
I am definitely not doing the lseek anywhere so that looks very promising. It might expalin why the initial read works while the others don't . I will try it tomorrow morning and post any results I find.
Thanks a lot.
Observer fd9750
Hi linnj,
Your suggestion was right on the mark. As soon as I added the approriate lseek instructions it works just great. I knew I was doing something wrong and sure enough: I overlooked the piece of info on the lseek function. Thanks a lot for pointing it out.
