hkarimmgc
RCU stall on using WiFi PCIe card on ZCU102 with Petalinux 2018.02
  1. Wifi module model is WPEA-121N/W. I enabled required kernel configurations.
    root@xilinx-zcu102-2018_2:~# zcat /proc/config.gz | grep ATH9
    CONFIG_ATH9K_HW=m
    CONFIG_ATH9K_COMMON=m
    CONFIG_ATH9K_COMMON_DEBUG=y
    CONFIG_ATH9K_BTCOEX_SUPPORT=y
    CONFIG_ATH9K=m
    CONFIG_ATH9K_PCI=y
    # CONFIG_ATH9K_AHB is not set
    CONFIG_ATH9K_DEBUGFS=y
    # CONFIG_ATH9K_STATION_STATISTICS is not set
    # CONFIG_ATH9K_TX99 is not set
    # CONFIG_ATH9K_DFS_CERTIFIED is not set
    # CONFIG_ATH9K_DYNACK is not set
    # CONFIG_ATH9K_WOW is not set
    CONFIG_ATH9K_RFKILL=y
    # CONFIG_ATH9K_CHANNEL_CONTEXT is not set
    CONFIG_ATH9K_PCOEM=y
    # CONFIG_ATH9K_HTC is not set
  2. When i go for scanning wifi devices, I get RCU stall on CPU0.
root@xilinx-zcu102-2018_2:~# ./iwlist wlan0 scan
[  446.916350] INFO: rcu_sched detected stalls on CPUs/tasks:
[  446.921764]  0-...: (1 GPs behind) idle=1ee/140000000000001/0 softirq=8193/8195 fqs=1552
[  446.929915]  (detected by 2, t=5254 jiffies, g=5116, c=5115, q=4)
[  446.935990] Task dump for CPU 0:
[  446.939200] iwlist          R  running task        0  2325   2295 0x00000002
[  446.946233] Call trace:
[  446.948670] [<ffffff8008085878>] __switch_to+0x98/0xb0
[  446.953786] [<0000000000008b0b>] 0x8b0b
[  509.940345] INFO: rcu_sched detected stalls on CPUs/tasks:
[  509.945753]  0-...: (1 GPs behind) idle=1ee/140000000000001/0 softirq=8193/8195 fqs=4256
[  509.953910]  (detected by 2, t=21010 jiffies, g=5116, c=5115, q=5)
[  509.960071] Task dump for CPU 0:
[  509.963282] iwlist          R  running task        0  2325   2295 0x00000002
[  509.970315] Call trace:
[  509.972748] [<ffffff8008085878>] __switch_to+0x98/0xb0
[  509.977868] [<0000000000008b0b>] 0x8b0b
[  572.964343] INFO: rcu_sched detected stalls on CPUs/tasks:
[  572.969748]  0-...: (1 GPs behind) idle=1ee/140000000000001/0 softirq=8193/8195 fqs=4934
[  572.977905]  (detected by 2, t=36766 jiffies, g=5116, c=5115, q=5)
[  572.984067] Task dump for CPU 0:
[  572.987277] iwlist          R  running task        0  2325   2295 0x00000002
[  572.994310] Call trace:
[  572.996742] [<ffffff8008085878>] __switch_to+0x98/0xb0
[  573.001863] [<0000000000008b0b>] 0x8b0b
[  635.988342] INFO: rcu_sched detected stalls on CPUs/tasks:
[  635.993743]  0-...: (1 GPs behind) idle=1ee/140000000000001/0 softirq=8193/8195 fqs=5607
[  636.001900]  (detected by 2, t=52522 jiffies, g=5116, c=5115, q=5)
[  636.008062] Task dump for CPU 0:
[  636.011272] iwlist          R  running task        0  2325   2295 0x00000002
[  636.018305] Call trace:
[  636.020737] [<ffffff8008085878>] __switch_to+0x98/0xb0
[  636.025858] [<0000000000008b0b>] 0x8b0b
[  699.012341] INFO: rcu_sched detected stalls on CPUs/tasks:
[  699.017748]  0-...: (1 GPs behind) idle=1ee/140000000000001/0 softirq=8193/8195 fqs=6256
[  699.025904]  (detected by 1, t=68278 jiffies, g=5116, c=5115, q=15)
[  699.032153] Task dump for CPU 0:
[  699.035363] iwlist          R  running task        0  2325   2295 0x00000002
[  699.042396] Call trace:
[  699.044828] [<ffffff8008085878>] __switch_to+0x98/0xb0
[  699.049950] [<0000000000008b0b>] 0x8b0b
[  762.036340] INFO: rcu_sched detected stalls on CPUs/tasks:
[  762.041742]  0-...: (1 GPs behind) idle=1ee/140000000000001/0 softirq=8193/8195 fqs=6863
[  762.049900]  (detected by 1, t=84034 jiffies, g=5116, c=5115, q=15)
[  762.056148] Task dump for CPU 0:
[  762.059359] iwlist          R  running task        0  2325   2295 0x00000002
[  762.066392] Call trace:
[  762.068823] [<ffffff8008085878>] __switch_to+0x98/0xb0
[  762.073945] [<0000000000008b0b>] 0x8b0b
[  825.060339] INFO: rcu_sched detected stalls on CPUs/tasks:
[  825.065738]  0-...: (1 GPs behind) idle=1ee/140000000000001/0 softirq=8193/8195 fqs=7470
[  825.073895]  (detected by 1, t=99790 jiffies, g=5116, c=5115, q=15)
[  825.080144] Task dump for CPU 0:
[  825.083354] iwlist          R  running task        0  2325   2295 0x00000002
[  825.090387] Call trace:
[  825.092819] [<ffffff8008085878>] __switch_to+0x98/0xb0
[  825.097940] [<0000000000008b0b>] 0x8b0b
[  888.084338] INFO: rcu_sched detected stalls on CPUs/tasks:
[  888.089742]  0-...: (1 GPs behind) idle=1ee/140000000000001/0 softirq=8193/8195 fqs=8077
[  888.097899]  (detected by 1, t=115546 jiffies, g=5116, c=5115, q=15)
[  888.104235] Task dump for CPU 0:
[  888.107445] iwlist          R  running task        0  2325   2295 0x00000002
[  888.114478] Call trace:
[  888.116910] [<ffffff8008085878>] __switch_to+0x98/0xb0
[  888.122031] [<0000000000008b0b>] 0x8b0b
[  951.108337] INFO: rcu_sched detected stalls on CPUs/tasks:
[  951.113737]  0-...: (1 GPs behind) idle=1ee/140000000000001/0 softirq=8193/8195 fqs=8684
[  951.121894]  (detected by 1, t=131302 jiffies, g=5116, c=5115, q=15)
[  951.128230] Task dump for CPU 0:
[  951.131440] iwlist          R  running task        0  2325   2295 0x00000002
[  951.138473] Call trace:
[  951.140905] [<ffffff8008085878>] __switch_to+0x98/0xb0
[  951.146026] [<0000000000008b0b>] 0x8b0b
[ 1014.132335] INFO: rcu_sched detected stalls on CPUs/tasks:
[ 1014.137741]  0-...: (1 GPs behind) idle=1ee/140000000000001/0 softirq=8193/8195 fqs=9291
[ 1014.145898]  (detected by 1, t=147058 jiffies, g=5116, c=5115, q=16)
[ 1014.152234] Task dump for CPU 0:
[ 1014.155444] iwlist          R  running task        0  2325   2295 0x00000002
[ 1014.162477] Call trace:
[ 1014.164909] [<ffffff8008085878>] __switch_to+0x98/0xb0
[ 1014.170030] [<0000000000008b0b>] 0x8b0b
[ 1077.156334] INFO: rcu_sched detected stalls on CPUs/tasks:
[ 1077.161737]  0-...: (1 GPs behind) idle=1ee/140000000000001/0 softirq=8193/8195 fqs=9897
[ 1077.169894]  (detected by 2, t=162814 jiffies, g=5116, c=5115, q=16)
[ 1077.176229] Task dump for CPU 0:
[ 1077.179440] iwlist          R  running task        0  2325   2295 0x00000002
[ 1077.186472] Call trace:
[ 1077.188905] [<ffffff8008085878>] __switch_to+0x98/0xb0
[ 1077.194025] [<0000000000008b0b>] 0x8b0b
[ 1140.180333] INFO: rcu_sched detected stalls on CPUs/tasks:
[ 1140.185740]  0-...: (1 GPs behind) idle=1ee/140000000000001/0 softirq=8193/8195 fqs=10504
[ 1140.193985]  (detected by 1, t=178570 jiffies, g=5116, c=5115, q=16)
[ 1140.200320] Task dump for CPU 0:
[ 1140.203530] iwlist          R  running task        0  2325   2295 0x00000002
[ 1140.210564] Call trace:
[ 1140.212995] [<ffffff8008085878>] __switch_to+0x98/0xb0
[ 1140.218116] [<0000000000008b0b>] 0x8b0b
[ 1203.204332] INFO: rcu_sched detected stalls on CPUs/tasks:
[ 1203.209736]  0-...: (1 GPs behind) idle=1ee/140000000000001/0 softirq=8193/8195 fqs=11110
[ 1203.217980]  (detected by 2, t=194326 jiffies, g=5116, c=5115, q=16)
[ 1203.224316] Task dump for CPU 0:
[ 1203.227526] iwlist          R  running task        0  2325   2295 0x00000002
[ 1203.234559] Call trace:
[ 1203.236991] [<ffffff8008085878>] __switch_to+0x98/0xb0
[ 1203.242112] [<0000000000008b0b>] 0x8b0b
[ 1266.228331] INFO: rcu_sched detected stalls on CPUs/tasks:
[ 1266.233731]  0-...: (1 GPs behind) idle=1ee/140000000000001/0 softirq=8193/8195 fqs=11716
[ 1266.241975]  (detected by 2, t=210082 jiffies, g=5116, c=5115, q=16)
[ 1266.248311] Task dump for CPU 0:
[ 1266.251521] iwlist          R  running task        0  2325   2295 0x00000002
[ 1266.258554] Call trace:
[ 1266.260986] [<ffffff8008085878>] __switch_to+0x98/0xb0
[ 1266.266107] [<0000000000008b0b>] 0x8b0b
[ 1329.252330] INFO: rcu_sched detected stalls on CPUs/tasks:
[ 1329.257735]  0-...: (1 GPs behind) idle=1ee/140000000000001/0 softirq=8193/8195 fqs=12322
[ 1329.265980]  (detected by 2, t=225838 jiffies, g=5116, c=5115, q=16)
[ 1329.272315] Task dump for CPU 0:
[ 1329.275525] iwlist          R  running task        0  2325   2295 0x00000002
[ 1329.282558] Call trace:
[ 1329.284990] [<ffffff8008085878>] __switch_to+0x98/0xb0
[ 1329.290111] [<0000000000008b0b>] 0x8b0b
Complete logs:
Xilinx Zynq MP First Stage Boot Loader
Release 2018.2   Jun 15 2018  -  04:17:37
NOTICE:  ATF running on XCZU9EG/silicon v4/RTL5.1 at 0xfffea000
NOTICE:  BL31: Secure code at 0x0
NOTICE:  BL31: Non secure code at 0x10080000
NOTICE:  BL31: v1.4(release):xilinx-v2018.1-4-g93a69a5a
NOTICE:  BL31: Built : 10:09:42, Jun 15 2018
PMUFW:  v1.0
U-Boot 2018.01 (Dec 10 2018 - 15:46:54 +0500) Xilinx ZynqMP ZCU102 rev1.0
I2C:   ready
DRAM:  4 GiB
EL Level:       EL2
Chip ID:        zu9eg
MMC:   sdhci@ff170000: 0 (SD)
In:    serial@ff000000
Out:   serial@ff000000
Err:   serial@ff000000
Model: ZynqMP ZCU102 Rev1.0
Board: Xilinx ZynqMP
Bootmode: LVL_SHFT_SD_MODE1
Net:   ZYNQ GEM: ff0e0000, phyaddr c, interface rgmii-id
Warning: ethernet@ff0e0000 MAC addresses don't match:
Address in ROM is          00:0a:35:04:98:c5
Address in environment is  00:0a:35:00:22:01
eth0: ethernet@ff0e0000
U-BOOT for xilinx-zcu102-2018_2
ethernet@ff0e0000 Waiting for PHY auto negotiation to complete...user interrupt!
ZynqMP>
ZynqMP> run loadbootenv
reading uEnv.txt
457 bytes read in 18 ms (24.4 KiB/s)
ZynqMP> run importbootenv
Importing environment from SD ...
ZynqMP> run bootkernel
reading Image
14819840 bytes read in 971 ms (14.6 MiB/s)
reading system.dtb
41527 bytes read in 16 ms (2.5 MiB/s)
## Flattened Device Tree blob at 04000000
   Booting using the fdt blob at 0x4000000
   Loading Device Tree to 0000000007ff2000, end 0000000007fff236 ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.14.0-xilinx-v2018.2 (oe-user@oe-host) (gcc version 7.2.0 (GCC)) #1 SMP Mon Dec 10 19:13:26 PKT 2018
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] Machine model: ZynqMP ZCU102 Rev1.0
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 256 MiB at 0x000000006fc00000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] percpu: Embedded 21 pages/cpu @ffffffc87ff65000 s46488 r8192 d31336 u86016
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1033987
[    0.000000] Kernel command line: clk_ignore_unused root=/dev/mmcblk0p2 rw rootwait
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] software IO TLB [mem 0x6bc00000-0x6fc00000] (64MB) mapped at [ffffffc06bc00000-ffffffc06fbfffff]
[    0.000000] Memory: 3784340K/4193280K available (10108K kernel code, 648K rwdata, 3176K rodata, 512K init, 2170K bss, 146796K reserved, 262144K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008a60000   ( 10112 KB)
[    0.000000]     .rodata : 0xffffff8008a60000 - 0xffffff8008d80000   (  3200 KB)
[    0.000000]       .init : 0xffffff8008d80000 - 0xffffff8008e00000   (   512 KB)
[    0.000000]       .data : 0xffffff8008e00000 - 0xffffff8008ea2200   (   649 KB)
[    0.000000]        .bss : 0xffffff8008ea2200 - 0xffffff80090c0d38   (  2171 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf1dc00000   (   476 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc880000000   ( 34816 MB)
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  RCU event tracing is enabled.
[    0.000000]  RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arch_timer: cp15 timer(s) running at 99.99MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x170f8dc196, max_idle_ns: 440795203664 ns
[    0.000003] sched_clock: 56 bits at 99MHz, resolution 10ns, wraps every 4398046511099ns
[    0.000326] Console: colour dummy device 80x25
[    0.000600] console [tty0] enabled
[    0.000620] Calibrating delay loop (skipped), value calculated using timer frequency.. 199.98 BogoMIPS (lpj=399960)
[    0.000635] pid_max: default: 32768 minimum: 301
[    0.000738] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.000756] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.001314] ASID allocator initialised with 65536 entries
[    0.001365] Hierarchical SRCU implementation.
[    0.001696] EFI services will not be available.
[    0.001722] zynqmp_plat_init Platform Management API v1.0
[    0.001731] zynqmp_plat_init Trustzone version v1.0
[    0.001826] smp: Bringing up secondary CPUs ...
[    0.002082] Detected VIPT I-cache on CPU1
[    0.002110] CPU1: Booted secondary processor [410fd034]
[    0.002385] Detected VIPT I-cache on CPU2
[    0.002403] CPU2: Booted secondary processor [410fd034]
[    0.002667] Detected VIPT I-cache on CPU3
[    0.002684] CPU3: Booted secondary processor [410fd034]
[    0.002726] smp: Brought up 1 node, 4 CPUs
[    0.002765] SMP: Total of 4 processors activated.
[    0.002774] CPU features: detected feature: 32-bit EL0 Support
[    0.002785] CPU: All CPU(s) started at EL2
[    0.002802] alternatives: patching kernel code
[    0.003531] devtmpfs: initialized
[    0.007834] random: get_random_u32 called from bucket_table_alloc+0x108/0x260 with crng_init=0
[    0.008032] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.008054] futex hash table entries: 1024 (order: 5, 131072 bytes)
[    0.013421] xor: measuring software checksum speed
[    0.052010]    8regs     :  2302.000 MB/sec
[    0.092040]    8regs_prefetch:  2052.000 MB/sec
[    0.132071]    32regs    :  2830.000 MB/sec
[    0.172102]    32regs_prefetch:  2379.000 MB/sec
[    0.172111] xor: using function: 32regs (2830.000 MB/sec)
[    0.172182] pinctrl core: initialized pinctrl subsystem
[    0.172290] random: fast init done
[    0.172677] NET: Registered protocol family 16
[    0.173254] cpuidle: using governor menu
[    0.173755] vdso: 2 pages (1 code @ ffffff8008a66000, 1 data @ ffffff8008e04000)
[    0.173771] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.174229] DMA: preallocated 256 KiB pool for atomic allocations
[    0.203622] reset_zynqmp reset-controller: Xilinx zynqmp reset driver probed
[    0.204176] ARM CCI_400_r1 PMU driver probed
[    0.208971] zynqmp-pinctrl ff180000.pinctrl: zynqmp pinctrl initialized
[    0.216664] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.284371] raid6: int64x1  gen()   405 MB/s
[    0.352283] raid6: int64x1  xor()   444 MB/s
[    0.420392] raid6: int64x2  gen()   690 MB/s
[    0.488382] raid6: int64x2  xor()   602 MB/s
[    0.556413] raid6: int64x4  gen()  1042 MB/s
[    0.624482] raid6: int64x4  xor()   719 MB/s
[    0.692497] raid6: int64x8  gen()   979 MB/s
[    0.760565] raid6: int64x8  xor()   744 MB/s
[    0.828651] raid6: neonx1   gen()   726 MB/s
[    0.896631] raid6: neonx1   xor()   851 MB/s
[    0.964706] raid6: neonx2   gen()  1169 MB/s
[    1.032744] raid6: neonx2   xor()  1206 MB/s
[    1.100776] raid6: neonx4   gen()  1504 MB/s
[    1.168825] raid6: neonx4   xor()  1439 MB/s
[    1.236901] raid6: neonx8   gen()  1651 MB/s
[    1.304930] raid6: neonx8   xor()  1531 MB/s
[    1.304938] raid6: using algorithm neonx8 gen() 1651 MB/s
[    1.304946] raid6: .... xor() 1531 MB/s, rmw enabled
[    1.304953] raid6: using neon recovery algorithm
[    1.306357] SCSI subsystem initialized
[    1.306519] usbcore: registered new interface driver usbfs
[    1.306555] usbcore: registered new interface driver hub
[    1.306592] usbcore: registered new device driver usb
[    1.306656] media: Linux media interface: v0.10
[    1.306682] Linux video capture interface: v2.00
[    1.306720] pps_core: LinuxPPS API ver. 1 registered
[    1.306728] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.306748] PTP clock support registered
[    1.306774] EDAC MC: Ver: 3.0.0
[    1.307113] zynqmp-ipi ff9905c0.mailbox: Probed ZynqMP IPI Mailbox driver.
[    1.307260] FPGA manager framework
[    1.307365] fpga-region fpga-full: FPGA Region probed
[    1.307528] Advanced Linux Sound Architecture Driver Initialized.
[    1.307775] Bluetooth: Core ver 2.22
[    1.307805] NET: Registered protocol family 31
[    1.307813] Bluetooth: HCI device and connection manager initialized
[    1.307824] Bluetooth: HCI socket layer initialized
[    1.307834] Bluetooth: L2CAP socket layer initialized
[    1.307851] Bluetooth: SCO socket layer initialized
[    1.308364] clocksource: Switched to clocksource arch_sys_counter
[    1.308436] VFS: Disk quotas dquot_6.6.0
[    1.308480] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.312388] NET: Registered protocol family 2
[    1.312681] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    1.312892] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    1.313278] TCP: Hash tables configured (established 32768 bind 32768)
[    1.313348] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    1.313424] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    1.313571] NET: Registered protocol family 1
[    1.313771] RPC: Registered named UNIX socket transport module.
[    1.313780] RPC: Registered udp transport module.
[    1.313788] RPC: Registered tcp transport module.
[    1.313795] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.314192] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[    1.314335] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.314955] audit: initializing netlink subsys (disabled)
[    1.315308] audit: type=2000 audit(1.304:1): state=initialized audit_enabled=0 res=1
[    1.315354] workingset: timestamp_bits=62 max_order=20 bucket_order=0
[    1.316012] NFS: Registering the id_resolver key type
[    1.316034] Key type id_resolver registered
[    1.316042] Key type id_legacy registered
[    1.316054] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.316074] jffs2: version 2.2. (NAND) (SUMMARY)  �© 2001-2006 Red Hat, Inc.
[    1.339510] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    1.339527] io scheduler noop registered
[    1.339535] io scheduler deadline registered
[    1.339555] io scheduler cfq registered (default)
[    1.339564] io scheduler mq-deadline registered
[    1.339571] io scheduler kyber registered
[    1.340196] nwl-pcie fd0e0000.pcie: Link is UP
[    1.340239] OF: PCI: host bridge /amba/pcie@fd0e0000 ranges:
[    1.340260] OF: PCI:   MEM 0xe0000000..0xefffffff -> 0xe0000000
[    1.340272] OF: PCI:   MEM 0x600000000..0x7ffffffff -> 0x600000000
[    1.340405] nwl-pcie fd0e0000.pcie: PCI host bridge to bus 0000:00
[    1.340419] pci_bus 0000:00: root bus resource [bus 00-ff]
[    1.340430] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xefffffff]
[    1.340441] pci_bus 0000:00: root bus resource [mem 0x600000000-0x7ffffffff pref]
[    1.341020] pci 0000:00:00.0: BAR 8: assigned [mem 0xe0000000-0xe00fffff]
[    1.341035] pci 0000:01:00.0: BAR 0: assigned [mem 0xe0000000-0xe001ffff 64bit]
[    1.341062] pci 0000:01:00.0: BAR 6: assigned [mem 0xe0020000-0xe002ffff pref]
[    1.341075] pci 0000:00:00.0: PCI bridge to [bus 01-0c]
[    1.341087] pci 0000:00:00.0:   bridge window [mem 0xe0000000-0xe00fffff]
[    1.341893] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
[    1.342278] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[    1.342443] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[    1.342600] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[    1.342759] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[    1.342915] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[    1.343074] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[    1.343228] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[    1.343391] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[    1.343611] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
[    1.343763] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
[    1.343916] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
[    1.344066] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
[    1.344219] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
[    1.344392] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
[    1.344559] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
[    1.344717] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
[    1.369655] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.372534] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    1.376321] brd: module loaded
[    1.379590] loop: module loaded
[    1.380824] ahci-ceva fd0c0000.ahci: couldn't get PHY in node ahci: -517
[    1.380977] mtdoops: mtd device (mtddev=name/number) must be supplied
[    1.381994] m25p80 spi0.0: n25q512a (131072 Kbytes)
[    1.382018] 4 ofpart partitions found on MTD device spi0.0
[    1.382026] Creating 4 MTD partitions on "spi0.0":
[    1.382038] 0x000000000000-0x000001e00000 : "boot"
[    1.382448] 0x000001e00000-0x000001e40000 : "bootenv"
[    1.382827] 0x000001e40000-0x000004240000 : "kernel"
[    1.383192] 0x000004240000-0x000008000000 : "spare"
[    1.384384] libphy: Fixed MDIO Bus: probed
[    1.385343] tun: Universal TUN/TAP device driver, 1.6
[    1.385474] CAN device driver interface
[    1.387448] macb ff0e0000.ethernet: Not enabling partial store and forward
[    1.387824] libphy: MACB_mii_bus: probed
[    1.389470] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 31 (00:0a:35:00:22:01)
[    1.389487] TI DP83867 ff0e0000.ethernet-ffffffff:0c: attached PHY driver [TI DP83867] (mii_bus:phy_addr=ff0e0000.ethernet-ffffffff:0c, irq=POLL)
[    1.390017] usbcore: registered new interface driver asix
[    1.390068] usbcore: registered new interface driver ax88179_178a
[    1.390099] usbcore: registered new interface driver cdc_ether
[    1.390128] usbcore: registered new interface driver net1080
[    1.390158] usbcore: registered new interface driver cdc_subset
[    1.390190] usbcore: registered new interface driver zaurus
[    1.390231] usbcore: registered new interface driver cdc_ncm
[    1.390515] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
[    1.391553] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.391563] ehci-pci: EHCI PCI platform driver
[    1.391809] usbcore: registered new interface driver uas
[    1.391847] usbcore: registered new interface driver usb-storage
[    1.392285] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
[    1.392335] i2c /dev entries driver
[    1.393325] IR NEC protocol handler initialized
[    1.393334] IR RC5(x/sz) protocol handler initialized
[    1.393342] IR RC6 protocol handler initialized
[    1.393349] IR JVC protocol handler initialized
[    1.393356] IR Sony protocol handler initialized
[    1.393362] IR SANYO protocol handler initialized
[    1.393369] IR Sharp protocol handler initialized
[    1.393376] IR MCE Keyboard/mouse protocol handler initialized
[    1.393384] IR XMP protocol handler initialized
[    1.394340] usbcore: registered new interface driver uvcvideo
[    1.394349] USB Video Class driver (1.1.1)
[    1.394805] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer at ffffff8009165000 with timeout 10s
[    1.394974] Bluetooth: HCI UART driver ver 2.3
[    1.394985] Bluetooth: HCI UART protocol H4 registered
[    1.394993] Bluetooth: HCI UART protocol BCSP registered
[    1.395019] Bluetooth: HCI UART protocol LL registered
[    1.395027] Bluetooth: HCI UART protocol ATH3K registered
[    1.395035] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    1.395079] Bluetooth: HCI UART protocol Intel registered
[    1.395088] Bluetooth: HCI UART protocol QCA registered
[    1.395123] usbcore: registered new interface driver bcm203x
[    1.395156] usbcore: registered new interface driver bpa10x
[    1.395189] usbcore: registered new interface driver bfusb
[    1.395224] usbcore: registered new interface driver btusb
[    1.395233] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    1.395280] usbcore: registered new interface driver ath3k
[    1.395402] EDAC MC: ECC not enabled
[    1.395569] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[    1.396049] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 1199880 KHz
[    1.396103] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1199999 KHz
[    1.396494] sdhci: Secure Digital Host Controller Interface driver
[    1.396504] sdhci: Copyright(c) Pierre Ossman
[    1.396511] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.444503] mmc0: SDHCI controller on ff170000.sdhci [ff170000.sdhci] using ADMA 64-bit
[    1.450500] ledtrig-cpu: registered to indicate activity on CPUs
[    1.450640] usbcore: registered new interface driver usbhid
[    1.450649] usbhid: USB HID core driver
[    1.452403] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[    1.454151] pktgen: Packet Generator for packet performance testing. Version: 2.75
[    1.456381] Netfilter messages via NETLINK v0.30.
[    1.456495] ip_tables: (C) 2000-2006 Netfilter Core Team
[    1.456635] Initializing XFRM netlink socket
[    1.456695] NET: Registered protocol family 10
[    1.457102] Segment Routing with IPv6
[    1.457144] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    1.457320] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    1.457622] NET: Registered protocol family 17
[    1.457638] NET: Registered protocol family 15
[    1.457655] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    1.457669] Ebtables v2.0 registered
[    1.457767] can: controller area network core (rev 20170425 abi 9)
[    1.457800] NET: Registered protocol family 29
[    1.457815] can: raw protocol (rev 20170425)
[    1.457823] can: broadcast manager protocol (rev 20170425 t)
[    1.457834] can: netlink gateway (rev 20170425) max_hops=1
[    1.458034] Bluetooth: RFCOMM TTY layer initialized
[    1.458049] Bluetooth: RFCOMM socket layer initialized
[    1.458067] Bluetooth: RFCOMM ver 1.11
[    1.458080] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    1.458088] Bluetooth: BNEP filters: protocol multicast
[    1.458098] Bluetooth: BNEP socket layer initialized
[    1.458106] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    1.458116] Bluetooth: HIDP socket layer initialized
[    1.458224] 9pnet: Installing 9P2000 support
[    1.458245] Key type dns_resolver registered
[    1.458599] registered taskstats version 1
[    1.458916] Btrfs loaded, crc32c=crc32c-generic
[    1.465174] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 47, base_baud = 6249375) is a xuartps
[    1.620815] mmc0: new high speed SDHC card at address aaaa
[    1.628398] mmcblk0: mmc0:aaaa SU08G 7.40 GiB
[    1.635910]  mmcblk0: p1 p2
[    3.121536] console [ttyPS0] enabled
[    3.125683] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 48, base_baud = 6249375) is a xuartps
[    3.136224] xilinx-psgtr fd400000.zynqmp_phy: Lane:1 type:8 protocol:4 pll_locked:yes
[    3.144460] PLL: shutdown
[    3.147130] PLL: shutdown
[    3.150045] PLL: enable
[    3.152535] PLL: shutdown
[    3.155884] PLL: enable
[    3.158351] xilinx-dp-snd-codec fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0: Xilinx DisplayPort Sound Codec probed
[    3.168924] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed
[    3.176875] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed
[    3.185083] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[    3.197441] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[    3.210058] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: Xilinx DisplayPort Sound Card probed
[    3.220157] OF: graph: no port node found in /amba/zynqmp-display@fd4a0000
[    3.227030] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    3.233566] [drm] No driver support for vblank timestamp query.
[    3.239528] xlnx-drm xlnx-drm.0: bound fd4a0000.zynqmp-display (ops 0xffffff8008b17428)
[    4.324373] [drm] Cannot find any crtc or sizes
[    4.328988] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.zynqmp-display on minor 0
[    4.337023] zynqmp-display fd4a0000.zynqmp-display: ZynqMP DisplayPort Subsystem driver probed
[    4.345962] xilinx-psgtr fd400000.zynqmp_phy: Lane:3 type:3 protocol:2 pll_locked:yes
[    4.353771] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[    4.362659] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[    4.372993] scsi host0: ahci-ceva
[    4.376416] scsi host1: ahci-ceva
[    4.379737] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x100 irq 45
[    4.387581] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x180 irq 45
[    4.397215] xilinx-psgtr fd400000.zynqmp_phy: Lane:2 type:0 protocol:3 pll_locked:yes
[    4.407122] dwc3 fe200000.dwc3: stop_host(): INFO: Host already stopped
[    4.413983] dwc3 fe200000.dwc3: stop_peripheral(): INFO: Peripheral already stopped
[    4.458713] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    4.464125] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    4.471965] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x22010010
[    4.480609] xhci-hcd xhci-hcd.0.auto: irq 53, io mem 0xfe200000
[    4.486602] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    4.493313] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.500518] usb usb1: Product: xHCI Host Controller
[    4.505374] usb usb1: Manufacturer: Linux 4.14.0-xilinx-v2018.2 xhci-hcd
[    4.512058] usb usb1: SerialNumber: xhci-hcd.0.auto
[    4.517189] hub 1-0:1.0: USB hub found
[    4.520883] hub 1-0:1.0: 1 port detected
[    4.524942] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    4.530356] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    4.538036] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    4.546140] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    4.552852] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.560056] usb usb2: Product: xHCI Host Controller
[    4.564915] usb usb2: Manufacturer: Linux 4.14.0-xilinx-v2018.2 xhci-hcd
[    4.571600] usb usb2: SerialNumber: xhci-hcd.0.auto
[    4.576689] hub 2-0:1.0: USB hub found
[    4.580379] hub 2-0:1.0: 1 port detected
[    4.585432] pca953x 0-0020: 0-0020 supply vcc not found, using dummy regulator
[    4.595323] pca953x 0-0020: interrupt support not compiled in
[    4.601077] pca953x 0-0021: 0-0021 supply vcc not found, using dummy regulator
[    4.610932] pca953x 0-0021: interrupt support not compiled in
[    4.617366] ina2xx 3-0040: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.624071] ina2xx 3-0041: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.630766] ina2xx 3-0042: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.637454] ina2xx 3-0043: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.644146] ina2xx 3-0044: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.650847] ina2xx 3-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.657543] ina2xx 3-0046: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.664235] ina2xx 3-0047: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.670928] ina2xx 3-004a: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.677632] ina2xx 3-004b: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.683934] i2c i2c-0: Added multiplexed i2c bus 3
[    4.689271] ina2xx 4-0040: power monitor ina226 (Rshunt = 2000 uOhm)
[    4.692369] xhci-hcd xhci-hcd.0.auto: remove, state 4
[    4.692382] usb usb2: USB disconnect, device number 1
[    4.696504] xhci-hcd xhci-hcd.0.auto: USB bus 2 deregistered
[    4.696513] xhci-hcd xhci-hcd.0.auto: remove, state 4
[    4.696522] usb usb1: USB disconnect, device number 1
[    4.696924] xhci-hcd xhci-hcd.0.auto: USB bus 1 deregistered
[    4.696935] dwc3 fe200000.dwc3: stop_peripheral(): INFO: Peripheral already stopped
[    4.714549] ata2: SATA link down (SStatus 0 SControl 330)
[    4.714572] ata1: SATA link down (SStatus 0 SControl 330)
[    4.745795] ina2xx 4-0041: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.752484] ina2xx 4-0042: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.759177] ina2xx 4-0043: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.765864] ina2xx 4-0044: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.772556] ina2xx 4-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.779250] ina2xx 4-0046: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.785940] ina2xx 4-0047: power monitor ina226 (Rshunt = 5000 uOhm)
[    4.792246] i2c i2c-0: Added multiplexed i2c bus 4
[    4.837950] i2c i2c-0: Added multiplexed i2c bus 5
[    4.842785] i2c i2c-0: Added multiplexed i2c bus 6
[    4.847499] pca954x 0-0075: registered 4 multiplexed busses for I2C mux pca9544
[    4.854817] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 33
[    4.862334] at24 7-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
[    4.868985] i2c i2c-1: Added multiplexed i2c bus 7
[    4.873909] i2c i2c-1: Added multiplexed i2c bus 8
[    4.880605] si570 9-005d: registered, current frequency 300000000 Hz
[    4.886910] i2c i2c-1: Added multiplexed i2c bus 9
[    4.904366] si570 10-005d: registered, current frequency 148500000 Hz
[    4.910756] i2c i2c-1: Added multiplexed i2c bus 10
[    4.915771] i2c i2c-1: Added multiplexed i2c bus 11
[    4.920692] i2c i2c-1: Added multiplexed i2c bus 12
[    4.925605] i2c i2c-1: Added multiplexed i2c bus 13
[    4.930521] i2c i2c-1: Added multiplexed i2c bus 14
[    4.935323] pca954x 1-0074: registered 8 multiplexed busses for I2C switch pca9548
[    4.943173] i2c i2c-1: Added multiplexed i2c bus 15
[    4.948088] i2c i2c-1: Added multiplexed i2c bus 16
[    4.953002] i2c i2c-1: Added multiplexed i2c bus 17
[    4.958211] i2c i2c-1: Added multiplexed i2c bus 18
[    4.963132] i2c i2c-1: Added multiplexed i2c bus 19
[    4.968052] i2c i2c-1: Added multiplexed i2c bus 20
[    4.972973] i2c i2c-1: Added multiplexed i2c bus 21
[    4.977896] i2c i2c-1: Added multiplexed i2c bus 22
[    4.982694] pca954x 1-0075: registered 8 multiplexed busses for I2C switch pca9548
[    4.990268] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 34
[    4.997327] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    5.004139] rtc_zynqmp ffa60000.rtc: setting system clock to 2018-12-21 10:14:58 UTC (1545387298)
[    5.013053] clk: Not disabling unused clocks
[    5.017276] ALSA device list:
[    5.020184]   #0: DisplayPort monitor
[    5.029294] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[    5.177547] EXT4-fs (mmcblk0p2): recovery complete
[    5.183439] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    5.191478] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    5.197485] devtmpfs: mounted
[    5.200502] Freeing unused kernel memory: 512K
INIT: version 2.88 booting
Starting udev
[    5.512378] [drm] Cannot find any crtc or sizes
[    5.569372] udevd[1907]: starting version 3.2.2
[    5.620791] udevd[1908]: starting eudev-3.2.2
[    5.745065] pci 0000:00:00.0: enabling device (0000 -> 0002)
[    5.750716] ath9k 0000:01:00.0: enabling device (0000 -> 0002)
[    5.770173] ieee80211 phy0: Atheros AR9300 Rev:3 mem=0xffffff800cf80000, irq=57
[    6.112588] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[    6.148412] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
Starting internet superserver: inetd.
INIT: Entering runlevel: 5
Configuring network interfaces... [    6.459532] pps pps0: new PPS source ptp0
[    6.463489] macb ff0e0000.ethernet: gem-ptp-timer ptp clock registered.
[    6.470122] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
udhcpc (v1.24.1) started
Sending discover...
[    7.460651] macb ff0e0000.ethernet eth0: link up (1000/Full)
[    7.466253] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Sending discover...
Sending select for 137.202.157.22...
Lease of 137.202.157.22 obtained, lease time 1800
/etc/udhcpc.d/50default: Adding DNS 137.202.187.16
/etc/udhcpc.d/50default: Adding DNS 137.202.23.16
/etc/udhcpc.d/50default: Adding DNS 147.34.2.16
done.
Starting system message bus: dbus.
Starting Dropbear SSH server: dropbear.
Starting syslogd/klogd: done
Starting tcf-agent: OK
PetaLinux 2018.2 xilinx-zcu102-2018_2 /dev/ttyPS0
xilinx-zcu102-2018_2 login: root
Password:
Login incorrect
Password:
root@xilinx-zcu102-2018_2:~# ls
root@xilinx-zcu102-2018_2:~# lsmod
Module                  Size  Used by
ath9k                 147456  0
ath9k_common           36864  1 ath9k
ath9k_hw              483328  2 ath9k,ath9k_common
ath                    36864  3 ath9k_hw,ath9k,ath9k_common
uio_pdrv_genirq        16384  0
root@xilinx-zcu102-2018_2:~# echo 1 > /sys/bus/pci/rescan
root@xilinx-zcu102-2018_2:~# ifconfig -a
can0      Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
          NOARP  MTU:16  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:10
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
          Interrupt:11
eth0      Link encap:Ethernet  HWaddr 00:0A:35:00:22:01
          inet addr:137.202.157.22  Bcast:137.202.157.255  Mask:255.255.254.0
          inet6 addr: fe80::20a:35ff:fe00:2201%4882584/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:402 errors:0 dropped:0 overruns:0 frame:0
          TX packets:23 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:34243 (33.4 KiB)  TX bytes:3434 (3.3 KiB)
          Interrupt:31
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1%4882584/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
sit0      Link encap:IPv6-in-IPv4
          NOARP  MTU:1480  Metric:1
wlan0     Link encap:Ethernet  HWaddr 00:0E:8E:6A:04:B6
          BROADCAST MULTICAST  MTU:1500  Metric:1
root@xilinx-zcu102-2018_2:~# rfkill list
0: phy0: wlan
        Soft blocked: no
        Hard blocked: no
root@xilinx-zcu102-2018_2:~# [  203.270941] random: crng init done
          RX packets:3339 errors:0 dropped:0 overruns:0 frame:0
          TX packets:121 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:254415 (248.4 KiB)  TX bytes:22470 (21.9 KiB)
          Interrupt:31
root@xilinx-zcu102-2018_2:~# 5F
-sh: 5F: command not found
root@xilinx-zcu102-2018_2:~# ./iwconfig
sit0      no wireless extensions.
can0      no wireless extensions.
eth0      no wireless extensions.
lo        no wireless extensions.
wlan0     IEEE 802.11  ESSID:off/any
          Mode:Managed  Access Point: Not-Associated   Tx-Power=0 dBm
          Retry short limit:7   RTS thr:off   Fragment thr:off
          Encryption key:off
          Power Management:off
root@xilinx-zcu102-2018_2:~# ifconfig  wlan0 up
[  367.339554] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
root@xilinx-zcu102-2018_2:~# uname -a
Linux xilinx-zcu102-2018_2 4.14.0-xilinx-v2018.2 #1 SMP Mon Dec 10 19:13:26 PKT 2018 aarch64 aarch64 aarch64 GNU/Linux
[ 1392.276329] INFO: rcu_sched detected stalls on CPUs/tasks:
[ 1392.281731]  0-...: (1 GPs behind) idle=1ee/140000000000001/0 softirq=8193/8195 fqs=12929
[ 1392.289975]  (detected by 1, t=241594 jiffies, g=5116, c=5115, q=16)
[ 1392.296311] Task dump for CPU 0:
[ 1392.299521] iwlist          R  running task        0  2325   2295 0x00000002
[ 1392.306553] Call trace:
[ 1392.308985] [<ffffff8008085878>] __switch_to+0x98/0xb0
[ 1392.314106] [<0000000000008b0b>] 0x8b0b
[ 1455.300327] INFO: rcu_sched detected stalls on CPUs/tasks:
[ 1455.305735]  0-...: (1 GPs behind) idle=1ee/140000000000001/0 softirq=8193/8195 fqs=13536
[ 1455.313979]  (detected by 1, t=257350 jiffies, g=5116, c=5115, q=16)
[ 1455.320314] Task dump for CPU 0:
[ 1455.323525] iwlist          R  running task        0  2325   2295 0x00000002
[ 1455.330557] Call trace:
[ 1455.332989] [<ffffff8008085878>] __switch_to+0x98/0xb0
[ 1455.338110] [<0000000000008b0b>] 0x8b0b
[ 1518.324326] INFO: rcu_sched detected stalls on CPUs/tasks:
[ 1518.329730]  0-...: (1 GPs behind) idle=1ee/140000000000001/0 softirq=8193/8195 fqs=14143
[ 1518.337974]  (detected by 1, t=273106 jiffies, g=5116, c=5115, q=16)
[ 1518.344310] Task dump for CPU 0:
[ 1518.347520] iwlist          R  running task        0  2325   2295 0x00000002
[ 1518.354553] Call trace:
[ 1518.356985] [<ffffff8008085878>] __switch_to+0x98/0xb0
[ 1518.362106] [<0000000000008b0b>] 0x8b0b
[ 1581.348325] INFO: rcu_sched detected stalls on CPUs/tasks:
[ 1581.353725]  0-...: (1 GPs behind) idle=1ee/140000000000001/0 softirq=8193/8195 fqs=14750
[ 1581.361969]  (detected by 1, t=288862 jiffies, g=5116, c=5115, q=16)
[ 1581.368305] Task dump for CPU 0:
[ 1581.371515] iwlist          R  running task        0  2325   2295 0x00000002
[ 1581.378548] Call trace:
[ 1581.380980] [<ffffff8008085878>] __switch_to+0x98/0xb0
[ 1581.386101] [<0000000000008b0b>] 0x8b0b
[ 1644.372324] INFO: rcu_sched detected stalls on CPUs/tasks:
[ 1644.377730]  0-...: (1 GPs behind) idle=1ee/140000000000001/0 softirq=8193/8195 fqs=15356
[ 1644.385974]  (detected by 2, t=304618 jiffies, g=5116, c=5115, q=16)
[ 1644.392309] Task dump for CPU 0:
[ 1644.395519] iwlist          R  running task        0  2325   2295 0x00000002
[ 1644.402552] Call trace:
[ 1644.404984] [<ffffff8008085878>] __switch_to+0x98/0xb0
[ 1644.410105] [<0000000000008b0b>] 0x8b0b
[ 1707.396323] INFO: rcu_sched detected stalls on CPUs/tasks:
[ 1707.401725]  0-...: (1 GPs behind) idle=1ee/140000000000001/0 softirq=8193/8195 fqs=15963
[ 1707.409969]  (detected by 1, t=320374 jiffies, g=5116, c=5115, q=16)
[ 1707.416304] Task dump for CPU 0:
[ 1707.419515] iwlist          R  running task        0  2325   2295 0x00000002
[ 1707.426548] Call trace:
[ 1707.428979] [<ffffff8008085878>] __switch_to+0x98/0xb0
[ 1707.434100] [<0000000000008b0b>] 0x8b0b
[ 1770.420322] INFO: rcu_sched detected stalls on CPUs/tasks:
[ 1770.425729]  0-...: (1 GPs behind) idle=1ee/140000000000001/0 softirq=8193/8195 fqs=16569
[ 1770.433973]  (detected by 2, t=336130 jiffies, g=5116, c=5115, q=16)
[ 1770.440308] Task dump for CPU 0:
[ 1770.443519] iwlist          R  running task        0  2325   2295 0x00000002
[ 1770.450552] Call trace:
[ 1770.452984] [<ffffff8008085878>] __switch_to+0x98/0xb0
[ 1770.458105] [<0000000000008b0b>] 0x8b0b
[ 1833.444321] INFO: rcu_sched detected stalls on CPUs/tasks:
[ 1833.449724]  0-...: (1 GPs behind) idle=1ee/140000000000001/0 softirq=8193/8195 fqs=17176
[ 1833.457968]  (detected by 1, t=351886 jiffies, g=5116, c=5115, q=16)
[ 1833.464304] Task dump for CPU 0:
[ 1833.467514] iwlist          R  running task        0  2325   2295 0x00000002
[ 1833.474547] Call trace:
[ 1833.476979] [<ffffff8008085878>] __switch_to+0x98/0xb0
[ 1833.482100] [<0000000000008b0b>] 0x8b0b
[ 1896.468320] INFO: rcu_sched detected stalls on CPUs/tasks:
[ 1896.473719]  0-...: (1 GPs behind) idle=1ee/140000000000001/0 softirq=8193/8195 fqs=17782
[ 1896.481964]  (detected by 2, t=367642 jiffies, g=5116, c=5115, q=16)
[ 1896.488299] Task dump for CPU 0:
[ 1896.491509] iwlist          R  running task        0  2325   2295 0x00000002
[ 1896.498542] Call trace:
[ 1896.500974] [<ffffff8008085878>] __switch_to+0x98/0xb0
[ 1896.506095] [<0000000000008b0b>] 0x8b0b
[ 1959.492318] INFO: rcu_sched detected stalls on CPUs/tasks:
[ 1959.497723]  0-...: (1 GPs behind) idle=1ee/140000000000001/0 softirq=8193/8195 fqs=18389
[ 1959.505968]  (detected by 1, t=383398 jiffies, g=5116, c=5115, q=17)
[ 1959.512303] Task dump for CPU 0:
[ 1959.515513] iwlist          R  running task        0  2325   2295 0x00000002
[ 1959.522547] Call trace:
[ 1959.524978] [<ffffff8008085878>] __switch_to+0x98/0xb0
[ 1959.530099] [<0000000000008b0b>] 0x8b0b
Complete kernel configrations are attached.
shabbirk
Just for debugging purpose, can you try disabling CPU IDLE from kernel config and see if stall issue goes away?
Best Regards
Shabbir
hkarimmgc
I Disable CPU_IDLE config .
root@zcu102-zynqmp-mel:~# zcat /proc/config.gz | grep IDLE
CONFIG_NO_HZ_IDLE=y
CONFIG_GENERIC_SMP_IDLE_THREAD=y
CONFIG_GENERIC_IDLE_POLL_SETUP=y
# CONFIG_IDLE_PAGE_TRACKING is not set
# CONFIG_CPU_IDLE is not set
# CONFIG_ARCH_NEEDS_CPU_IDLE_COUPLED is not set
# CONFIG_NETFILTER_XT_TARGET_IDLETIMER is not set
But got the same response.
root@zcu102-zynqmp-mel:~# echo 1 > /sys/bus/pci/rescan
[  179.737513] pci 0000:00:00.0: BAR 8: assigned [mem 0xe0000000-0xe00fffff]
[  179.744259] pci 0000:01:00.0: BAR 0: assigned [mem 0xe0000000-0xe001ffff 64bit]
[  179.751549] pci 0000:01:00.0: BAR 6: assigned [mem 0xe0020000-0xe002ffff pref]
[  179.758734] pci 0000:00:00.0: PCI bridge to [bus 01-0c]
[  179.763933] pci 0000:00:00.0:   bridge window [mem 0xe0000000-0xe00fffff]
[  179.771143] pci 0000:00:00.0: enabling device (0000 -> 0002)
[  179.776738] ath9k 0000:01:00.0: enabling device (0000 -> 0002)
[  179.795797] ieee80211 phy0: Atheros AR9300 Rev:3 mem=0xffffff800fc80000, irq=49
[  179.803202] ath9k 0000:01:00.0 wlp1s0: renamed from wlan0
root@zcu102-zynqmp-mel:~# iwconfig
wlp1s0    IEEE 802.11  ESSID:off/any
          Mode:Managed  Access Point: Not-Associated   Tx-Power=off
          Encryption key:off
root@zcu102-zynqmp-mel:~# rfkill list
0: phy0: wlan
        Soft blocked: yes
        Hard blocked: no
root@zcu102-zynqmp-mel:~# rfkill unblock all
root@zcu102-zynqmp-mel:~# [  237.348196] IPv6: ADDRCONF(NETDEV_UP): wlp1s0: link is not ready
[  237.836890] NOHZ: local_softirq_pending 80
[  258.416884] INFO: rcu_sched detected stalls on CPUs/tasks:
[  258.422294]  0-...: (1 ticks this GP) idle=6c6/140000000000001/0 softirq=5410/5410 fqs=0
[  258.430449]  (detected by 2, t=5255 jiffies, g=529, c=528, q=33)
[  258.436438] Task dump for CPU 0:
[  258.439651] kworker/u8:0    R  running task        0     5      2 0x00000000
[  258.446691] Workqueue: phy0 ieee80211_scan_work
[  258.451195] Call trace:
[  258.453630] [<ffffff8008085e54>] __switch_to+0x94/0xf0
[  258.458749] [<ffffffc87b8a2a00>] 0xffffffc87b8a2a00
[  258.463612] rcu_sched kthread starved for 5263 jiffies! g529 c528 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x402 ->cpu=0
[  258.473682] rcu_sched       I    0     8      2 0x00000000
[  258.479147] Call trace:
[  258.481579] [<ffffff8008085e54>] __switch_to+0x94/0xf0
[  258.486704] [<ffffff8008af37d0>] __schedule+0x1c8/0x6a0
[  258.491911] [<ffffff8008af3ccc>] schedule+0x24/0x80
[  258.496774] [<ffffff8008af6f20>] schedule_timeout+0x78/0x3e0
[  258.502416] [<ffffff80080fa8e4>] rcu_gp_kthread+0x614/0xdc8
[  258.507972] [<ffffff80080bff98>] kthread+0x130/0x138
[  258.512918] [<ffffff8008084f2c>] ret_from_fork+0x10/0x1c
[  321.436882] INFO: rcu_sched detected stalls on CPUs/tasks:
[  321.442287]  0-...: (1 ticks this GP) idle=6c6/140000000000001/0 softirq=5410/5410 fqs=0
[  321.450444]  (detected by 2, t=21010 jiffies, g=529, c=528, q=211)
[  321.456606] Task dump for CPU 0:
[  321.459816] kworker/u8:0    R  running task        0     5      2 0x00000000
[  321.466854] Workqueue: phy0 ieee80211_scan_work
[  321.471361] Call trace:
[  321.473795] [<ffffff8008085e54>] __switch_to+0x94/0xf0
[  321.478916] [<ffffffc87b8a2a00>] 0xffffffc87b8a2a00
[  321.483779] rcu_sched kthread starved for 21018 jiffies! g529 c528 f0x2 RCU_GP_WAIT_FQS(3) ->state=0x200 ->cpu=0
[  321.493936] rcu_sched       R    0     8      2 0x00000000
[  321.499401] Call trace:
[  321.501833] [<ffffff8008085e54>] __switch_to+0x94/0xf0
[  321.506957] [<ffffff8008af37d0>] __schedule+0x1c8/0x6a0
[  321.512165] [<ffffff8008af3ccc>] schedule+0x24/0x80
[  321.517027] [<ffffff8008af6f20>] schedule_timeout+0x78/0x3e0
[  321.522670] [<ffffff80080fa8e4>] rcu_gp_kthread+0x614/0xdc8
[  321.528225] [<ffffff80080bff98>] kthread+0x130/0x138
[  321.533172] [<ffffff8008084f2c>] ret_from_fork+0x10/0x1c
[  384.456881] INFO: rcu_sched detected stalls on CPUs/tasks:
[  384.462289]  0-...: (1 ticks this GP) idle=6c6/140000000000001/0 softirq=5410/5410 fqs=0
[  384.470446]  (detected by 2, t=36765 jiffies, g=529, c=528, q=375)
[  384.476608] Task dump for CPU 0:
[  384.479818] kworker/u8:0    R  running task        0     5      2 0x00000000
[  384.486854] Workqueue: phy0 ieee80211_scan_work
[  384.491364] Call trace:
[  384.493797] [<ffffff8008085e54>] __switch_to+0x94/0xf0
[  384.498918] [<ffffffc87b8a2a00>] 0xffffffc87b8a2a00
[  384.503781] rcu_sched kthread starved for 36773 jiffies! g529 c528 f0x2 RCU_GP_WAIT_FQS(3) ->state=0x200 ->cpu=0
[  384.513938] rcu_sched       R    0     8      2 0x00000000
[  384.519403] Call trace:
[  384.521835] [<ffffff8008085e54>] __switch_to+0x94/0xf0
[  384.526959] [<ffffff8008af37d0>] __schedule+0x1c8/0x6a0
[  384.532167] [<ffffff8008af3ccc>] schedule+0x24/0x80
[  384.537029] [<ffffff8008af6f20>] schedule_timeout+0x78/0x3e0
[  384.542671] [<ffffff80080fa8e4>] rcu_gp_kthread+0x614/0xdc8
[  384.548227] [<ffffff80080bff98>] kthread+0x130/0x138
[  384.553175] [<ffffff8008084f2c>] ret_from_fork+0x10/0x1c
[  447.476880] INFO: rcu_sched detected stalls on CPUs/tasks:
[  447.482282]  0-...: (1 ticks this GP) idle=6c6/140000000000001/0 softirq=5410/5410 fqs=0
[  447.490439]  (detected by 2, t=52520 jiffies, g=529, c=528, q=529)
[  447.496601] Task dump for CPU 0:
[  447.499811] kworker/u8:0    R  running task        0     5      2 0x00000000
[  447.506848] Workqueue: phy0 ieee80211_scan_work
[  447.511357] Call trace:
[  447.513790] [<ffffff8008085e54>] __switch_to+0x94/0xf0
[  447.518911] [<ffffffc87b8a2a00>] 0xffffffc87b8a2a00
[  447.523775] rcu_sched kthread starved for 52528 jiffies! g529 c528 f0x2 RCU_GP_WAIT_FQS(3) ->state=0x200 ->cpu=0
[  447.533932] rcu_sched       R    0     8      2 0x00000000
[  447.539397] Call trace:
[  447.541829] [<ffffff8008085e54>] __switch_to+0x94/0xf0
[  447.546952] [<ffffff8008af37d0>] __schedule+0x1c8/0x6a0
[  447.552160] [<ffffff8008af3ccc>] schedule+0x24/0x80
[  447.557022] [<ffffff8008af6f20>] schedule_timeout+0x78/0x3e0
[  447.562665] [<ffffff80080fa8e4>] rcu_gp_kthread+0x614/0xdc8
[  447.568220] [<ffffff80080bff98>] kthread+0x130/0x138
[  447.573168] [<ffffff8008084f2c>] ret_from_fork+0x10/0x1c
HenryYu
I met the same problem using XDMA on PCIe card
Is this problem solved?
