yellowd
ROI function of VCU
Hi !
I want to use the ROI function of VCU in my custom gstreamer application and refer to the following link https://github.com/Xilinx/gst-omx/blob/xilinx-master/examples/zynqultrascaleplus/test-vcu-encode.c to write my application. When I compile the source files in qtcreator, the error is reported as follows. Where is the library containing the two functions?
yellowd
After adding the gstvideo lib, I can build the application correctly.
yellowd
