Visitor noel.aye
RPU powerdown
For v2017.2, we are able to powerdown rpu 1 using the following command:
echo request_wakeup 8 1 0 1 > /sys/kernel/debug/zynqmp_pm/power
echo force_powerdown 6 > /sys/kernel/debug/zynqmp_pm/power
But, for v2018.2, the above twos are no longer working.
Is there any alternative to these commands?
Tags (4)
回复: RPU powerdown
I haven't tried to power down RPU yet. But the pm path is different in 2018.2. You can refer to turn off PL in below link.
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841757/ZU+Example+-+Typical+Power+States
 8.1 Turn off PL
(v2017.1-4) Run below command from Linux terminal on board to power off PL (force power down unused PU).
root@plnx_aarch64:~# echo request_wakeup 8 1 0 1 > /sys/kernel/debug/zynqmp_pm/power
root@plnx_aarch64:~# echo force_powerdown 8 >  /sys/kernel/debug/zynqmp_pm/power
root@plnx_aarch64:~# time echo release_node 69 > /sys/kernel/debug/zynqmp_pm/power
(v2018.1-x) Run below command from Linux terminal on board to power off PL (force power down unused PU).
root@plnx_aarch64:~# echo pm_request_wakeup 8 1 0 1 > /sys/kernel/debug/zynqmp-firmware/pm
root@plnx_aarch64:~# echo pm_force_powerdown 8 >  /sys/kernel/debug/zynqmp-firmware/pm
root@plnx_aarch64:~# time echo pm_release_node 69 > /sys/kernel/debug/zynqmp-firmware/pm
回复: RPU powerdown
 8.1 Turn off PL
Visitor noel.aye
回复: RPU powerdown
Thanks, we have tried the solution and found perfectly working.
One thing to add is that we need to build the kernel with
CONFIG_ZYNQMP_FIRMWARE_DEBUG=y
to see the node "/sys/kernel/debug/zynqmp-firmware/pm".
