Participant haibingma
RTC retrieved date/time is not valid
For the RTC on my ZC702 board, I got:
rtc-pcf8563 5-0051: low voltage detected, date/time is not reliable.
rtc-pcf8563 5-0051: retrieved date/time is not valid.
What does that mean? Change battery? Or something else I need to do?
Haibing
Re: RTC retrieved date/time is not valid
I've seen that before also, I'm asking the board team what they think.
Thanks a lot, John. Really appreciate your help.
Just let you know that I got "low voltage dected", and I got this message for both of my boards. In theory, it shouldn't run out of battery.
Haibing
When I ask the board team it sounds like there could be some bad batteries but they are soldered on so it's a pain to change.
Visitor dainis
For RTC is used secondary battery B2 which is not mounted on PCB.
Don't use standart Lithium coins, because this B2 battey has charging circuit!!!
For others who find this thread:
This warning message occurs when the VL flag in the RTC's SECONDS register is set. This flag gets set when VDD falls below a certain threshold (like low battery). It stays set until cleared by writing a zero to bit 7 of the SECONDS register (offset 0x02).
After updating the date and time I no longer receive this warning and the date holds through power off.
Process:
  • Stop the clock
  • Update date and time (clearing VL flag)
  • Restart clock
The RTC chip has an auto incrementing address, so you can write all date and time fields in one go.
