senkoo
Ramdisk image is corrupt or invalid.
My name is Senna and I am working on the zc702 dev kit.
When i boot my kernel i get this and i have no clue on how i fix this... I looked through multiple posts but could'nt find my solution.
Maybe it is something simple and can just tell me.
The boot log:
U-Boot 2017.01 (Oct 04 2018 - 08:48:19 +0000)
Board: Xilinx Zynq
DRAM:  ECC disabled 1 GiB
MMC:   sdhci_transfer_data: Error detected in status(0x208000)!
sdhci@e0101000: 0 (eMMC)
SF: Detected n25q1024 with page size 256 Bytes, erase size 4 KiB, total 128 MiB
In:    serial
Out:   serial
Err:   serial
Net:   ZYNQ GEM: e000b000, phyaddr ffffffff, interface rgmii-id
PHY is not detected
GEM PHY init failed
No ethernet found.
U-BOOT for ets-prg
Zynq> sf probe
Zynq> sf write 0x1000000 0x0 0x500000
device 0 offset 0x0, size 0x500000
SF: 5242880 bytes @ 0x0 Written: OK
Zynq> sf write 0x2000000 0x520000 0x50000
device 0 offset 0x520000, size 0x50000
SF: 327680 bytes @ 0x520000 Written: OK
Zynq> sf write 0x3000000 0x570000 0x1500000
device 0 offset 0x570000, size 0x1500000
SF: 22020096 bytes @ 0x570000 Written: OK
Zynq> boot
SF: 22020096 bytes @ 0x570000 Read: OK
## Loading kernel from FIT Image at 01000000 ...
   Using 'conf@1' configuration
   Verifying Hash Integrity ... OK
   Trying 'kernel@0' kernel subimage
     Description:  Linux Kernel
     Type:         Kernel Image
     Compression:  uncompressed
     Data Start:   0x010000d4
     Data Size:    12169320 Bytes = 11.6 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: 0x00008000
     Entry Point:  0x00008000
     Hash algo:    sha1
     Hash value:   2dbdf0a07467c5d9607fd9f50c61633096c23ae1
## Loading ramdisk from FIT Image at 01000000 ...
   Trying 'ramdisk@0' ramdisk subimage
     Description:  ramdisk
     Type:         RAMDisk Image
     Data Start:   0x01b9e89c
     Data Size:    8718256 Bytes = 8.3 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: unavailable
     Entry Point:  unavailable
     Hash algo:    sha1
     Hash value:   d2fa492bac0a16e91ef42d87be82008c05eb1667
   Verifying Hash Integrity ... sha1 error!
Bad hash value for 'hash@1' hash node in 'ramdisk@0' image node
Bad Data Hash
trigger
Voyager
Voyager
Ok so first you can start with an "hello or maybe Hi"...
We don't have any information about your setup:
- Build from scratch, yocto ? petalinux ?
- Do you have check its file ?
- 8.3 Mo for an uncompressed ramdisk ?
Have you try to check the Hash value and compare with sources ?
Cheers,
Trigger
johnvivm
Voyager
Voyager
first think I would do is making sure the ramdisk image is ok
trigger
Voyager
Voyager
Cheers,
Trigger
senkoo
For some reason i just re-ran petalinux-build and it was ok.. I really don't know what happened.
senkoo
my apologies,
I't doesnt seem to be a problem anymore. I dont know what went wrong or why...
Cheers,
Senko
trigger
Voyager
Voyager
cool :-)
