Re: how to read/write from/to a register in Linux?
I have a design which is working well. Till now i am writing my c program in sdk for standalone version and launching through JTAG.
But now I would like to know that if I use linux OS and want to read and write to specific registers how could I do it ?
this subject has been discussed many times,
in a baremetal apps you can directly address physical addresses,
on Linux you can only use a virtual address mapped to the physical address.
That means you can't do stuff like this anymore
(unsigned int*)(FPGA_BASE+0x04) = 0x01; -- write example
val = (unsigned char *)(FPGA_BASE+0x00); -- reading one byte
you can use the /dev/mem driver which allows you to address physical addresses  from userspace
fd = open ("/dev/mem", O_RDWR);
page_addr = (fpga_base_addr & (~(page_size-1)));
page_offset = fpga_base_addr - page_addr;
virtual_address = mmap(NULL, page_size, PROT_READ|PROT_WRITE, MAP_SHARED, fd, page_addr); //memory map
 see this page for nice tutorials mmap
this job is usually done in the kernel space by a driver, here's how to map a virtual pointer to a physical address retrieved from the devicetree
sdev->regs = devm_ioremap_resource(&pdev->dev, res);
if(IS_ERR(sdev->regs)){
     printk(KERN_ERR "devm_ioremap failed for %s\n",
          sdev->name);
     status = -ENOMEM;
     goto free_dev_name;
G.W.,
NIST - Time Frequency metrology
Observer sconvertini
I followed your instructions to read the register of the global timer (physical address 0xF8F00200 defined in xparameter.h)
so, I open the /dev/mem file as follow:
int memfd;
	memfd = open("/dev/mem", O_RDWR | O_SYNC); // to open this, the program needs to be run as root
	if (memfd == -1) {
		printf("Can't open /dev/mem.\n");
		exit(0);
to provide the virtual address, I use a custom function as follow:
void *getvaddr(int phys_addr, int memfd) {
	void *mapped_base;
	void *mapped_dev_base;
	off_t dev_base = phys_addr;
	// Map one page of memory into user space such that the device is in that page, but it may not
	// be at the start of the page
	mapped_base = mmap(0, MAP_SIZE, PROT_READ | PROT_WRITE, MAP_SHARED, memfd,
			dev_base & ~MAP_MASK);
	if (mapped_base == (void *) -1) {
		printf("Can't map the memory to user space.\n");
		exit(0);
	// get the address of the device in user space which will be an offset from the base
	// that was mapped as memory is mapped at the start of the page
	mapped_dev_base = mapped_base + (dev_base & MAP_MASK);
	return mapped_dev_base;
Then I initialized a variable as follow:
int *global_timer_addr = getvaddr(XPAR_PS7_GLOBALTIMER_0_S_AXI_BASEADDR, memfd);
	int *timer_0 = global_timer_addr;
I'm using a while statement to test the timer register as follow:
while (1) {
		if (*timer_0 > 333333333) {
			SetLedPin();
			*timer_0 = 0;
		else
			ClearLedPin();
I have no problem in reading *timer0 but whe I attempt to write 0 value in *timer, my MicroZed freezes and I need to hardware reset the board.
Do you have any idea how to solve it?
Thank you for your support.
有人解决这个问题吗?
