mark@bish.net
Re: petalinux & u-boot default_boot command
@gudishak Thank you.
Also, how cna one add custom bootargs from u-boot.
I saw that someone was modifying components/plnx_workspace/device-tree-generation/skeleton.dtsi
/include/ "system-conf.dtsi"
chosen {
    bootargs = "console=ttyPS0,115200 earlyprintk  <more custom commands>";
This is the preferred way?
shabbirk
Hi Mark
To overwrite the kernel command line, you can just add something that would like to see, to the ./project-spec/meta-user/recipes-bsp/device-tree/files/system-user.dtsi:-
chosen {
     bootargs = "earlycon root=/dev/mmcblk0p2 rw";
Example DTSi file looks like this:-
chosen {
Best Regards
Shabbir
shabbirk
Hi Mark
chosen {
chosen {
Best Regards
Shabbir
_kumar
Hi @Shabbir,
This information helped to resolve my issue.
