duane
Recover from moving project directory
I moved my project directory from one location to another. I could no longer build using petalinux-build. If I start over from the .bsp file, the petalinux-build works properly.
What do I need to do in order to use petalinux-build after moving the directory? Is there a "clean" that can be used?
The error I received is:
$ petalinux-build -v
[INFO] building project
[INFO] sourcing bitbake
ERROR: Failed to source bitbake
ERROR: Failed to build project
webtalk failed:PetaLinux statistics:extra lines detected:notsent_nofile!
webtalk failed:Failed to get PetaLinux usage statistics!
And the build.log contained:
$ cat build/build.log
SDK environment now set up; additionally you may now run devtool to perform development tasks.
Run devtool --help for further details.
### Shell environment set up for builds. ###
You can now run 'bitbake <target>'
Common targets are:
core-image-minimal
core-image-sato
meta-toolchain
meta-ide-support
You can also run generated qemu images with a command like 'runqemu qemux86'
ERROR: Only one copy of bitbake should be run against a build directory
ERROR: Failed to add meta-plnx-generated layer
shabbirk
It looks from this error message (ERROR: Only one copy of bitbake should be run against a build directory) that alredy you have a running instance of bitbake.
Check to see if you have bitbake.lock file in build/ directory and remove it and also clean the build using petalinux-build -x mrproper and do the rebuild using petalinux-build
Best Regards
Shabbir
shabbirk
Best Regards
Shabbir
