Reference HDL design for Zynq Releases
I'd like to work off of the reference design provided by the Xilinx wiki. Where can I find the Vivado HDL design that was used to create the pre-built Zynq Releases:
http://www.wiki.xilinx.com/Zynq+Releases
Thanks!
Re: Reference HDL design for Zynq Releases
It's pretty much the templates in Vivado. You may have to do some adjustments depending on your platform. but for the Zed this is it:
set project_name "zed"
set part xc7z020clg484-1
set version "2015.1"
set board [get_board_parts -latest_file_version -filter [list BOARD_NAME==$project_name]]
set project_dir vivado/$project_name
create_project $project_name $project_dir -part $part
set_property board_part $board [current_project]
create_bd_design "design_1"
create_bd_cell -type ip -vlnv xilinx.com:ip:processing_system7 processing_system7_0
apply_bd_automation -rule xilinx.com:bd_rule:processing_system7 -config {make_external "FIXED_IO, DDR" apply_board_preset "1" Master "Disable" Slave "Disable" }  [get_bd_cells processing_system7_0]
set_property -dict [list CONFIG.PCW_USE_M_AXI_GP0 {0} CONFIG.PCW_EN_CLK0_PORT {0} CONFIG.PCW_EN_RST0_PORT {0}] [get_bd_cells processing_system7_0]
make_wrapper -files [get_files $project_dir/$project_name.srcs/sources_1/bd/design_1/design_1.bd] -top
add_files -norecurse $project_dir/$project_name.srcs/sources_1/bd/design_1/hdl/design_1_wrapper.v
update_compile_order -fileset sources_1
update_compile_order -fileset sim_1
generate_target all [get_files  $project_dir/$project_name.srcs/sources_1/bd/design_1/design_1.bd]
file mkdir $project_dir/$project_name.sdk
write_hwdef  -file $project_dir/$project_name.sdk/design_1_wrapper.hdf
close_project
exit
close_project
exit
Thanks!
