Refering to EMIO GPIO pins on Device Tree
I have connected an interrupt to PS GPIO via  EMIO 0. what would be the pin index for this at device tree?
  interrupt-parent = <&gpio>;
  interrupts = <pin index  0>;
  gpios = <&gpio0 pin_index 0>;
Jothi
Voyager
Voyager
Hi @jothiadith,
You should take a look here: http://www.wiki.xilinx.com/Linux+GPIO+Driver
Trigger
I understand when ps_gpio is routed thro' MIO. The page doesnt explain well when the ps_gpio is routed thro' EMIO.
I agree, I find the wiki page utterly confusing as it keeps using terms without defining what they mean.
Look here
https://forums.xilinx.com/t5/Embedded-Linux/GPIO-control-in-Linux-sysfs/m-p/833075#M24402
The 3rd reply is from a xilinx mod that explains it very explicitly and I found it very helpful
Thank you. I am using Zynq so the 54 is emio's 1st index.
it should be gipos = <&gpio0 51 0>;
correct?
