arastu
Regarding cross compilation in linux
I want to cross compile attached file for am-linux-gnueabihf tool chain. how to do it?
In xilinx SDK some example is given in embeddedsw. I need to cross compile in linux using Xilinx SDK.
I tried but i got many error. How to solve this cross compilation issue?
Is there any way to use this embeddedsw supported code[ Example ] in linux ?
how to change arm-xilinx-gnueabi toolchain into arm-linux-gnueabihf?
trigger
Voyager
Voyager
hello,
you have to install crosstool chain to cross compile your .c file
Please take a look in Google first : https://fr.lmgtfy.com/?q=cross+compilation+arm-linux-gnueabihf
or https://www.acmesystems.it/arm9_toolchain
Which error are you talking about ??
Trigger
arastu
Thanks for reply.
I already installed cross toolchain. But I want to cross compile attached file. Please find file in attachment and go through it. When i tried to cross compile,it did not support header file of code.
How to do it?
trigger
Voyager
Voyager
Ok ,
You don't paste error log, no cmdnline ...
So I can't help you. Good luck
Trigger
arastu
Xilinx SDK provides some standalone application program.
I tried to cross compilation this standalone application code in linux [ arm-linux-gnueabihf tool chain].
I would like to know  it is possible to cross compile this standalone application. If it is possible , then please guide me for that.
trigger
Voyager
Voyager
Please give us more info to in order to help you ...
last try:
Do you have install an SDK ? If yes which version ? If not you have to install Xilinx SDK first.
How did you try to cross compile your .c file ? Give us cmdline, sceenshot, any info to help you..
We don't have any idea about your setup, do you use evaluation board, custom board ?
Cheers,
Trigger
arastu
I am using Xilinx SDK 2018.1.
I have created one application for timer implementation and  followed some steps which are shown in attachment in form of images.
Please go through it. For tool chain i have used ARM v7 GNU/ Linux Toolchain to cross compile .
Is it correct way to cross compile for arm-linux-gnueabihf ?
code is also shown in images. When I tried to build , It shows Error which is shown in image[code with error].
How to solve this error? I added header file related to it.
