eliezer
Removing Packages does not decrease image size (Petalinux)
At one point, the image produced by Petalinux for my custom project was ~50MB in size. After I added some packages/modules, it shot up to 225MB. I am trying to bring the image size back down.
In UG1144, under "Managing Image Size", the only method listed is the removal of packages from the RootFS/Kernel.
I just removed 3 of the packages from the RootFS config menu, and rebuilt my project -- and it is the same size. Not even 1MB smaller.
What's going on here? Is it impossible to actually remove packages once they are included, or are the packages I removed just incredibly small? Is there a better way to figure out what is taking up all of that space?
eliezer
Well apparently you need to run a distclean to get rid of all the old packages you are no longer using.
Like so:
petalinux-build -x distclean
and then rebuild
petalinux-build
After I did that, my image size went back to 50MB. Problem solved.
If anyone from Xilinx sees this, I do think it should be mentioned in the "Managing Image Size" section of UG1144. Currently, it is not.
eliezer
Like so:
and then rebuild
petalinux-build
