nju0441
[Repost] Error when adding ros into xilinx linux
Very appreciated if anyone can give some suggestion on thread: https://forums.xilinx.com/t5/Adaptive-Computing-Challenge/Error-when-adding-ros-into-xilinx-linux/td-p/1152513
Also, I'm confused about petalinux SDK.... It should be tools used by user. Why there's a command "petalinux-build --sdk" ?
