Reserved DDR memory region : Unable to handle kernel paging request
Hi everyone and thank you for reading me,
I'm working with vivado and petalinux 2018.3 design flow, my FPGA target is a MPSoC Ultrascale+ (Xu5ev) implemented on Mercury Xu5Ev board from enclustra.
I'm able to boot linux on the board, loading template modules also works.
Problems starts when I try to implement a memory reservation. I followed instructions from this tutorial : https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841683/Linux+Reserved+Memory
But everytime I try to boot, when the module is inserted I got the following message :
Unable to handle kernel paging request at virtual address 7fff35d8
It seems to be triggered on the driver instruction :
rc = of_address_to_resource(np, 0, &r);
I have checked memory settings of my board (4GB) so I added the memory node
memory {
device_type = "memory";
reg = <0x0 0x0 0x0 0x80000000>, <0x00000008 0x00000000 0x0 0x80000000>;
In my system_user.dtsi
I used the same procedure on a Zynq device where it worked properly...
Do you have any advice ? What am I missing ? My understanding of the problem is that some addresses cannot be mapped for some reasons, from what I see on the enclustra board, it seems like there are 4 dies of DDR memory, in that case shouldn't I describe my memory noe I a differrent way ?
You can you find the code of the driver I modified, the log and my user device-tree linked below.
Thank you for any help
I found that using the dma API resolved my issue. Using the combination of compatible = "shared-dma-pool"; in my DT and the referenced driver code line in this tutorial https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841683/Linux+Reserved+Memory
For information I had to add
#include <linux/of_reserved_mem.h>
#include <linux/dma-mapping.h>
at the begining of the driver code to use the API
regards,
LB
regards,
LB
