rtapiador
Reset PL from Petalinux Zynq MPSoC
Hi all,
I am triying to reset the PL from PS using petalinux.
My first attemp was using GPIO, However the system gets hangs when I tried to write a 1 to enable the reset.
Then I tried to use the ZynqMp reset driver to reset the PL reset, I did everything that I read here:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842455/ZynqMP+Linux+Reset-controller+Driver
However the reset-mgr is not listed. I enabled the reset driver, but I have some doubts about where to write the dts entry. I wrote in /project-spec/meta-user/recipes-bsp/device-tree/files/system-user.dtsi
This is the entry:
rst: reset-controller {
compatible = "xlnx,zynqmp-reset";
#reset-cells = <1>;
I need to reset the logic and I would like to know if i wrote wrongly the dts entry or why the GPIO hangs the system.
If there is another way to reset the logic please tell me.
Thanks in advance
zouyu930503
Same question here. Did you find any solution to do that?
pedro_uno
Advisor
Advisor
I'm not sure what you mean by "reset the PL".  If you reset everything in your PL design including the AXI logic I can see why it would hang.
It is more common for software controlled resets to just reset a specific part of your design.
Another option to reset the whole PL would be to just reconfigure the fpga.  Petalinux has drivers that let you reconfigure the PL and it happens real fast.  That would put the whole PL back to the boot-up state.
DSP in hardware and software
zouyu930503
I followed the tutorial to program PL from PetaLinux, but it's very vague, some parts are not clearly explained.
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841847/Solution+ZynqMP+PL+Programming#SolutionZynqMPPLProgramming-PetalinuxFlow
What is this hdf directory? PetaLinux 2019.2 does not use hdf anymore.
Thank you.
zouyu930503
I re-programmed the PL, but it seems that peripherals are not reset at all.
pedro_uno
Advisor
Advisor
For reconfiguring the PL I don't think you need to enable anything like fpga manager in Petalinux. Here are some instructions I made for myself. I copy the .bin file to /lib/firmware then run a command as root. I am running a non-volatile root filesystem so things might be different for me.
Copy .../fpga/implement/results/top.bit.bin to /lib/firmware. I think you need to do this as sudo.
Change to root with "sudo su".
echo top.bit.bin > /sys/class/fpga_manager/fpga0/firmware
The blue done LED should flash off very briefly.
