Reset Vhdl logic from SDK application
I want to reset my Vhdl State machine logic from SDK application before starting any data packet transaction.
I have created a custom ip and connected it to AXI-4 bus.
How to incorporate the reset signal into my custom ip and how to use it from SDK application?
Kindly help.
mayankara
Scholar sampatd
Re: Reset Vhdl logic from SDK application
It can be achieved through software reset.
If you used the CIP wizard in XPS to create the custom IP, you can enable the software reset option (see the screenshot below). This will allow the peripheral to be reset from the software application.
HiSampatd,
I connected my custom ip to AXI-4 Bus (memory mapped). To enable the software reset, I have to enable User logic master support. After enabling user logic master support, I'm not able to use custom ip as a memory mapped interface.
I'm stuck as how to keep it as a memory mapped interface and then use reset signal from SDK application.
Any help will be appreciated.
mayankara
