vijaydhoki
Run an application automatically at start up on Linux platform
Hey all,
I am trying to run a linux application on zcu102 in qspi mode.I am able to run my application manually after booting and i am able to see the output of my application.
But the problem is that i want to run my application automatically after boot up.
For this procedure i have a small knowledge about this is that we need add a script file and that contains the path of our application(I don't know whether this process is correct or not)
please tell me the procedure that i need to follow to run an application immediately after completion of booting.and if i need to add any script files please share me the link to that script file so that i can edit that file to run my application.
Vijay
aravindb
Hi @vijaydhoki
 Please follow below steps & build It should work.
1. petalinux-create -t apps --template install -n myapp-init --enable
2. vim project-spec/meta-user/recipes-apps/myapp-init/myapp-init.bb
#thiss file is the myapp-init recipe.
SUMMARY = "Simple myapp-init application"
SECTION = "PETALINUX/apps"
LICENSE = "MIT"
LIC_FILES_CHKSUM = "file://${COMMON_LICENSE_DIR}/MIT;md5=0835ade698e0bcf8506ecda2f7b4f302"
SRC_URI = "file://myapp-init \
S = "${WORKDIR}"
FILESEXTRAPATHS_prepend := "${THISDIR}/files:"
inherit update-rc.d
INITSCRIPT_NAME = "myapp-init"
INITSCRIPT_PARAMS = "start 99 S ."
do_install() {
install -d ${D}${sysconfdir}/init.d
install -m 0755 ${S}/myapp-init ${D}${sysconfdir}/init.d/myapp-init
FILES_${PN} += "${sysconfdir}/*"
3. Modify your script (project-spec/meta-user/recipes-apps/myapp-init/files/myapp-init)according to your requirements and build it.
Thanks & regards
Aravind
Thanks & Regards
Aravind
vijaydhoki
Hi @aravindb,Thanks for your reply
Sorry to say this,I am not using peta-linux,I am using linux platform only.
could please tell me the steps to follow to run this on linux.
Vijay
