dima2882
Running Go on Petalinux
Hi all,
Has anyone successfully run Go - golang - scripts on Petalinux? What's involved in cross-compiling something like that to Petalinux 2014.4?
Thanks!
rfs613
It works quite well in fact. Just set GOARCH=arm, and optionally GOARM=7. See http://dave.cheney.net/2013/07/09/an-introduction-to-cross-compilation-with-go-1-1 or http://www.goinggo.net/2013/10/cross-compile-your-go-programs.html
The golang compiler produces static binaries, which run nicely on the ARM processor. The only challenge is that the binaries are large (hello world comes in around 8MB) which can be an issue if you only have 16MB of QSPI flash. But from an SD card or USB stick it is workable.
balkris
I believe this is not supported yet
Thanks and Regards
Balkrishan
rfs613
rfs613
A small correction: the size of "hello world" with the current v1.4.2 golang compiler is about 1.6MB when compiled for ARM. Looks like they've managed to shrink the images a bit.
dima2882
@rfs613
 go/bin/linux_arm
I went through Chaney's guide and build a cross-compile environment. The ~/go/bin/linux_arm location now has the executables to build the ARM apps on the x86_64 host. I compiled a hello world - that worked when tested, and was cross-compiled to linux-arm as shown in the file properties - but this immediatly segfaulted on the Zedboard running PetaLinux.
I realized that my FTP client was silently changing the file, even though it should have been binary. Sending with ftp directly via command line fixed the problem.
Thanks rfs613 - knowing that running Go was possible was enough to get it going on my system.
