Running Petalinux 2014.2 build from Flash on Zedboard
Hi I have successfully produced a custom Petalinux 2014.2 build from a Vivado 2014.2 hardware design. The build is booting from an SD card on the Zedboard, this build has debugging via the Ethernet and a console output. I would like to now place this build into the on board FLASH (QSPI) and auto run my application from power up like a normal turnkey system. Are there any simple step by step instructions to show a relative newcomer how to first translate the SD build and put it into Flash and then auto run my application from Flash using Petalinux 2014.2 and the Zedboard? Thanks in advance Steve
