Running Python Script on Zynq-7000
Hello all,
I am working with a ZC706 eval board and I am trying to run a python script that should convert incoming data packets from ethernet into peek and poke commands on the processor.  I am using Petalinux2018.3 and ubuntu 16.04.
I have the python scripts written but I am unclear on how to get the scripts onto the Zynq board and then to execute them once there.  I have already enabled python and the necessary packages via:
petalinux-config -c rootfs
Any help is greatly appreciated,
Thank you
Re: Running Python Script on Zynq-7000
HI @stephen.lindeman
I think if you have a phython script on Sdcard, then you can simply mount your sdcard & copy to /home/root folder Then run suing below commands.
1. mount /dev/mmcblk0p1 /mnt/.
2.cp -rf /mnt/file_name.py .
3. chmod 777 file_name.py
4. phython file_name.py
Thanks & regards
Araivnd
Enable the python:
  • Filesystem Packages → devel →python
    • python-mmap
    • python-shell
    • python-io
    • python-distutils
    • python-pydoc
If you want to do peek and poke, you will need to do:
petalinux-config -c kernel
  • kernel hacking → [] Filter access to /dev/mem
You can create a recipe to place your python files in the sysroot, or .. just copy to the SD card
and mount the SD card and execute from there.
