vharris007
Rx checksum
We seeing an odd issue with both the PS eMAC the soft-core AXI Ethernet MAC. In both cases the rx-checksumming is off. We've try to enable it with ethtool but feature isn't changeable. Is there any way to enable Rx checksum?
Van
[root@alarm ~]# uname -a
Linux alarm 3.17.0-xilinx-00114-gda2d296 #3 SMP PREEMPT Mon Jan 26 10:53:10 PST 2015 armv7l GNU/Linux
==============eth0 internal PS MAC ======================
[root@alarm ~]# ifconfig eth0
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 10.160.1.10  netmask 255.255.255.0  broadcast 10.160.1.255
        ether 00:0a:35:00:01:22  txqueuelen 1000  (Ethernet)
        RX packets 340  bytes 35630 (34.7 KiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 9  bytes 1986 (1.9 KiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        device interrupt 54  base 0xb000
[root@alarm ~]# ethtool -k eth0
Features for eth0:
rx-checksumming: off [fixed]
tx-checksumming: on
        tx-checksum-ipv4: on [fixed]
        tx-checksum-ip-generic: off [fixed]
        tx-checksum-ipv6: off [fixed]
        tx-checksum-fcoe-crc: off [fixed]
        tx-checksum-sctp: off [fixed]
scatter-gather: on
        tx-scatter-gather: on [fixed]
        tx-scatter-gather-fraglist: off [fixed]
tcp-segmentation-offload: off
        tx-tcp-segmentation: off [fixed]
        tx-tcp-ecn-segmentation: off [fixed]
        tx-tcp6-segmentation: off [fixed]
udp-fragmentation-offload: off [fixed]
generic-segmentation-offload: on
generic-receive-offload: on
large-receive-offload: off [fixed]
rx-vlan-offload: off [fixed]
tx-vlan-offload: off [fixed]
ntuple-filters: off [fixed]
receive-hashing: off [fixed]
highdma: off [fixed]
rx-vlan-filter: off [fixed]
vlan-challenged: off [fixed]
tx-lockless: off [fixed]
netns-local: off [fixed]
tx-gso-robust: off [fixed]
tx-fcoe-segmentation: off [fixed]
tx-gre-segmentation: off [fixed]
tx-ipip-segmentation: off [fixed]
tx-sit-segmentation: off [fixed]
tx-udp_tnl-segmentation: off [fixed]
tx-mpls-segmentation: off [fixed]
fcoe-mtu: off [fixed]
tx-nocache-copy: off
loopback: off [fixed]
rx-fcs: off [fixed]
rx-all: off [fixed]
tx-vlan-stag-hw-insert: off [fixed]
rx-vlan-stag-hw-parse: off [fixed]
rx-vlan-stag-filter: off [fixed]
l2-fwd-offload: off [fixed]
busy-poll: off [fixed]
[root@alarm ~]# ethtool -K eth0 rx on
Cannot change rx-checksumming
Could not change any device features
========eth2 AXI Ethernet soft-coare MAC ===============================
[root@alarm ~]# ifconfig eth2
eth2: flags=67<UP,BROADCAST,RUNNING>  mtu 1500
        inet 10.160.2.10  netmask 255.255.255.0  broadcast 10.160.2.255
        ether 00:0a:35:00:00:01  txqueuelen 1000  (Ethernet)
        RX packets 42  bytes 4653 (4.5 KiB)
        TX packets 5  bytes 378 (378.0 B)
[root@alarm ~]# ethtool -k eth2
Features for eth2:
tx-checksumming: on
scatter-gather: on
rx-fcs: off [fixed]
rx-all: off [fixed]
[root@alarm ~]#
[root@alarm ~]# ethtool -K eth2 rx on
jdehaven
The customer has confirmed that "rx_chksum_offld_en" bit is being set in the net cfg reg but for some reason ethtool is not reflecting this.  Getting RX checksum offload working is a critical  performance issue for us.
Anything you can do to help debug this quickly would be appreciated.
John
Avnet FAE
jd
masterfx
To get the rx-checksumming reflected via ethtool, just set the flag in the features struct
--- drivers/net/ethernet/xilinx/xilinx_emacps.org.c     2015-07-07 14:46:52.851649894 +0200
+++ drivers/net/ethernet/xilinx/xilinx_emacps.c     2015-07-07 14:49:04.000000000 +0200
@@ -2870,7 +2870,7 @@
        ndev->watchdog_timeo = TX_TIMEOUT;
        ndev->ethtool_ops = &xemacps_ethtool_ops;
        ndev->base_addr = r_mem->start;
-       ndev->features = NETIF_F_IP_CSUM | NETIF_F_SG;
+       ndev->features = NETIF_F_IP_CSUM | NETIF_F_SG | NETIF_F_RXCSUM;
        netif_napi_add(ndev, &lp->napi, xemacps_rx_poll, XEMACPS_NAPI_WEIGHT);
        lp->ip_summed = CHECKSUM_UNNECESSARY;
But I didn't see any difference in performance via netperf. Maybe its because the CPU is always at 50% CPU load (one Core = 100%)
