SDIO WiFi Module Recommendations
Hey everyone,
I'm planning on adding WiFi to my ZC-702 board. Preferably an SDIO WiFi module since I running low on pins and would like something with FCC approval. Does anyone have any recommendations for modules that have worked for them or just have a good feeling about?
I'm using  Petalinux 2017.4 with kernel version 4.9.0.
Tags (3)
Re: SDIO WiFi Module Recommendations
Ti Wilink 8 parts work well for us
Hi Asuarez,
I used an SDIO based Wifi module from Avnet PBA-TD1MPD-1-01-00 and incorporated it in my design based on Zedbaoard which uses the zynq XC7Z020-1CLG484C FPGA part.
The link to the WiFi reference design and bsp is "www.zedboard.org/support/design/1521/11" They have both 2017.3 and 2017.4 bsps. I used the 2017.3 in my design.
