SDK: Error while launching debugger
While launching debugger in SDK 2013 (windows 7 64-bit platform), I'm getting the following error:
ERROR : Unexpected error while launching program. java.lang.RuntimeException: Target request failed: Warning:\nCannot insert breakpoint 1.\nError accessing memory address 0x27c: (undocumented errno -1).\n.
    at com.xilinx.sdk.debug.core.XilinxAppLaunchConfigurationDelegate.debugApplication(Unknown Source)
    at com.xilinx.sdk.debug.core.XilinxAppLaunchConfigurationDelegate.launch(Unknown Source)
Kindly help to resolve the issue.
mayankara
Re: SDK: Error while launching debugger
There are a few known issues with the SDK GDB debugger.
Can you try using System Debugger ?
Reference: http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_6/SDK_Doc/tasks/sdk_t_tcf_limitations_faq.htm
Achutha
H Achutha,
I followed the steps as per the link, now, while launching it's showing the message:
SDK Linux TCF agent: Disconnected. Connection timed out.
and debugger is not getting launched.
I think TCF agent has to be there on the target platform.
While developing an application, TCF agent has to be included or it has to be there on the petalinux?
Any help will be appreciated.
mayankara
What's up with this? I'd wish Xilinx employees have answered this before, I'm having the same issue.
Debugger launch hangs at 57% then: SDK Linux TCF agent: Disconnected. Connection timed out.
Dosto
Tags (3)
Okay,
Anyone came here for the same reason; the solution for me was easy to forget as well as to solve: The build mode should be "Debug", not "Release".
Check this out.
Dosto
