SDK debugging with Petalinux core files
Hi all
Petalinux 2015.2
SDK 2015.2
I have a Petalinux application which generates a segfault while running on my custom Zynq target board. I can generate a core file using
ulimit -c unlimited
but can't see how to connect the SDK to it either remotely via TCF or after pulling it off the target. Usually there is a "C/C++ Postmortem Debugger" debug configuration option in Eclipse but it doesn't seem to be there in the SDK.
Any help would be appreciated.
Chris
Re: SDK debugging with Petalinux core files
Will try on the Embedded Development Tools board and report back...
Chris
Please refer to reply in https://forums.xilinx.com/t5/Embedded-Linux/Re-SDK-debugging-with-Petalinux-core-files/td-p/724396
Praveen
hi
  try copy your application and corefle in your host linux,and debug with arm-xilinx-linuxgnu-gdb.
 arm-xilinux-linuxgnu-gdb <your application> <core>
