SPI GPIO chipselect
there is possibility to map SPI device chipselect to GPIO?
I just modifiy a device driver:
gpiod_set_value(csgp, 0);
ret = spi_write_then_read(spi, &buf[0], 2, rbuf, num);
gpiod_set_value(csgp, 1);
but a I thing it is not so good solution.
What is the FPGA device part number?
linux native spi driver allows to use any GPIO as chip select.. this all explaine in the device tree bindings
http://lxr.free-electrons.com/source/Documentation/devicetree/bindings/spi/spi-bus.txt?v=3.14
I put a patch on the list, if you still have the issue:
https://lkml.org/lkml/2017/4/25/728
