SPI configuration
I am facing a problem in SPI configuration. I want to write some code for SPI for linux, but i could not find any document for basic configuring information of SPI. like in GPIO I have to configure export and direction file.
can anyone guide me how can I configure SPI in Linux environment or tell me about some helpful document.
thanks in advance
Sana
Check this AR: http://www.xilinx.com/support/answers/46503.htm
Hope this helps.
 The below applation notes also givesuseful information related to SPI configuration
http://www.xilinx.com/support/documentation/application_notes/xapp1020.pdf
http://www.xilinx.com/support/documentation/application_notes/xapp586-spi-flash.pdf
http://www.xilinx.com/support/documentation/application_notes/xapp951.pdf
