jcruchaga
Secondary eth1 ethernet port not working
We are having trouble getting a second Ethernet port working with Zynq and Petalinux 2017.3 We are using two Marvell 88E1512 phys. The device tree is attached (system.dts).
The device tree contains next interfaces:
        gem1: ethernet@ff0c0000 {
            compatible = "cdns,zynqmp-gem";
            status = "disabled";
            interrupt-parent = <&gic>;
            interrupts = <0 59 4>, <0 59 4>;
            reg = <0x0 0xff0c0000 0x0 0x1000>;
            clock-names = "pclk", "hclk", "tx_clk";
            #address-cells = <1>;
            #size-cells = <0>;
            #stream-id-cells = <1>;
            iommus = <&smmu 0x875>;
            power-domains = <&pd_eth1>;
        gem3: ethernet@ff0e0000 {
            interrupts = <0 63 4>, <0 63 4>;
            reg = <0x0 0xff0e0000 0x0 0x1000>;
            #size-cells = <0>;
            iommus = <&smmu 0x877>;
            power-domains = <&pd_eth3>;
It seems these interfaces are well configured.When we execute the kernel and execute ifconfig command only the eth0 interface is showed:
root@tyr_mpsoc2:~# ifconfig
eth0      Link encap:Ethernet  HWaddr 00:0A:35:00:20:18
          inet6 addr: fe80::20a:35ff:fe00:2018%4879720/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:12 errors:0 dropped:0 overruns:0 frame:0
          TX packets:22 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:3936 (3.8 KiB)  TX bytes:4892 (4.7 KiB)
          Interrupt:30
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1%4879720/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
But we can find that eth1 is well defined into /etc/network/interfaces:
# Wired or wireless interfaces
auto eth0
iface eth0 inet dhcp
iface eth1 inet dhcp
But when I try to launch the eth1 interface:
root@tyr_mpsoc2:/etc/network# ifconfig eth1 up
Only shows a unique lo:
[ 7230.410790] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
Instead of a well behaviour:
root@tyr_mpsoc2:/etc/network# ifconfig eth0 down
root@tyr_mpsoc2:/etc/network# [ 7202.154929] macb ff0c0000.ethernet eth0: link down
root@tyr_mpsoc2:/etc/network# ifconfig eth0 up
[ 7219.010840] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7219.017017] macb ff0c0000.ethernet eth0: link up (1000/Full)
[ 7219.022631] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
As result we have no communication through eth1, trying a ping no packages are sended through such interface. It seems like something between phisycal and logical layer is not working well.
Somebody could help me?
ottob
What does the boot log say ?
dmesg | grep 'macb\|phy'
My guess is that this is a problem with the second PHY's MDIO
sandeepg
Hi @jcruchaga,
Can you decompile the dtb to dts and attach here.
$ dtc -I dtb -O dts -o system.dts system.dtb
Sandeep
jcruchaga
I @ottob here my boot log:
root@tyr_mpsoc2:~# dmesg | grep 'macb\|phy'
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 33.33MHz (phys).
[    2.669640] libphy: Fixed MDIO Bus: probed
[    2.689976] macb ff0c0000.ethernet: Not enabling partial store and forward
[    2.697168] libphy: MACB_mii_bus: probed
[    2.775213] macb ff0c0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0c0000 irq 30 (00:0a:35:00:22:01)
[    2.784975] Marvell 88E1510 ff0c0000.etherne:01: attached PHY driver [Marvell 88E1510] (mii_bus:phy_addr=ff0c0000.etherne:01, irq=-1)
[    2.797175] macb ff0e0000.ethernet: Not enabling partial store and forward
[    2.804350] libphy: MACB_mii_bus: probed
[    2.883148] macb ff0e0000.ethernet eth1: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 31 (00:0a:35:00:22:01)
[    2.892911] Marvell 88E1510 ff0e0000.etherne:01: attached PHY driver [Marvell 88E1510] (mii_bus:phy_addr=ff0e0000.etherne:01, irq=-1)
[    7.627351] macb ff0c0000.ethernet eth0: link up (1000/Full)
jcruchaga
Hi @sandeepg here my system.dts.
jcruchaga
We are using macb driver (http://www.wiki.xilinx.com/Macb+Driver) in our Petalinux build.
We need to change the state of some phy registers through mdio interface. As far as I know the driver supports for mdio access, but it is not very clear to me how. Can somebody tell me how that can be done? Is there any documentation about how to use the interfaces of MDIO support for PHY layer management?
Julen.
ottob
We use phytool for this
phytool write eth1/0xF/0x18 0x0d0b #Green Link / Act. Amber = Error
phytool write eth1/0xF/0x19 0x0000 #Fix LED polarity
jcruchaga
Hi @ottob,
How do you install such tool into petalinux build? Is there any options into petalinux-config?
Julen
sandeepg
Hi @jcruchaga,
In <plnx-proj-root>/project-spec/meta-user/conf/petalinuxbsp.conf add this
IMAGE_INSTALL_append += "\
    phytool \
We will check your dts
Sandeep
jcruchaga
Hi @ottob,
How do you read the different pages of PHY registers? Do you need to write into pages register the number of current page or something like this?
Julen.
ottob
Hi Julen !
The PHY's I've dealt with have just been straight forward register writes. i.e.
phytool write [interface]/[MDIO/PHY Address]/[Register] [Value]
For anything more complicated see the PHY datasheet or possibly the kernel driver for hints on how to access it
/Otto
