Segmentation fault (core dumped) about petalinux
I install petalinux2019.1 on ubuntu 18.04.1
i create a petalinux project and config it, it is normal
but when i use
 petalinux-build
to build ,it says
ERROR:  OE-core's config sanity checker detected a potential misconfiguration.
    Either fix the cause of this error or at your own risk disable the checker (see sanity.conf).
    Following is the list of potential problems / advisories:
    Do not use Bitbake as root.
I exit sudo and run again even other command runs wrong
it says
ysy@ubuntu:~/petalinux2019/linuxprj2019$ petalinux-build
ysy@ubuntu:~/petalinux2019/linuxprj2019$ petalinux-config
ysy@ubuntu:~/petalinux2019/linuxprj2019$ petalinux-create
but if i use sudo -s and run again it will not show this question
what should i do to fix this bug! thank you so much for your reply !
The Petalinux tool should not be installed as root user.
PetaLinux build commands works only in non sudo user, it fails to build with sudo or root user.
Note: Do not change the installer permissions to CHMOD 775 as it can cause BitBake errors.
This installs the PetaLinux Tools into /opt/pkg/petalinux/2019.1 directory.
IMPORTANT! Once installed, you cannot move or copy the installed directory. In the above example, you cannot
move or copy /opt/pkg/petalinux since the full path will be stored into Yocto e-SDK environment file.
Note: You cannot install the tool as root user. Ensure that /opt/pkg/petalinux is writeable. You can
change the permissions after installation to make it globally read-execute (0755). It is not mandatory to
install tool in /opt/pkg/petalinux directory. You can install at any desired location that has the 755
permissions.
permissions.
thank you !
