Setting FPGA clock rate
When calling clk_set_rate() on the Zynq FPGA clocks (fclk0-3), which clk_ops are applicable?  I cannot tell in which file to find the ones that apply to the Zynq FPGA clocks.
Re: Setting FPGA clock rate
The gate and second divider both have the CLK_SET_RATE_PARENT flag (https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/tree/drivers/clk/zynq/clkc.c#n149), allowing a set_rate operation to walk up the clock tree. Hence, the set_rate operation will eventually operate on the divider clocks (https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/tree/drivers/clk/clk-divider.c).
That should not be too hard to trace through the code:
FCLK instantiation starts here: https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/tree/drivers/clk/zynq/clkc.c#n365
Which leads to https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/tree/drivers/clk/zynq/clkc.c#n113, where the individual muxes, dividers and gates are instantiated.
The last one is the gate that is later exported as output from this module; https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/tree/drivers/clk/zynq/clkc.c#n158
clk_register_gate() assigns clk_gate_ops to its ops pointer (https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/tree/drivers/clk/clk-gate.c#n147), which is defined here: https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/tree/drivers/clk/clk-gate.c#n107
I was trying to follow from the emacps driver calling clk_set_rate() here:
https://github.com/Xilinx/linux-xlnx/blob/f672c6bf89ae093b147e244f13d9e5886c5bfdbc/drivers/net/ethernet/xilinx/xilinx_emacps.c#L719
Then it calls clk_core_set_rate_nolock():
https://github.com/Xilinx/linux-xlnx/blob/f672c6bf89ae093b147e244f13d9e5886c5bfdbc/drivers/clk/clk.c#L1816
which calls clk_change_rate():
https://github.com/Xilinx/linux-xlnx/blob/f672c6bf89ae093b147e244f13d9e5886c5bfdbc/drivers/clk/clk.c#L1778
Then it walks a clock tree:
https://github.com/Xilinx/linux-xlnx/blob/f672c6bf89ae093b147e244f13d9e5886c5bfdbc/drivers/clk/clk.c#L1691
And calls clk->ops->set_rate() on each node:
https://github.com/Xilinx/linux-xlnx/blob/f672c6bf89ae093b147e244f13d9e5886c5bfdbc/drivers/clk/clk.c#L1723
This is where I get lost.  The clock tree I'm interested in is this one for Zynq's FPGA2 clock:
              fclk2_div0                   1            1   124999999          0 0
                 fclk2_div1                1            1   124999999          0 0
                    fclk2                  2            2   124999999          0 0
I added some debug messages and saw that set_rate() is only called for fclk2_div0 and stops there without calling set_rate on the children, but which set_rate() is the one for fclk2_div0?  The ones you pointed to are clk gate ops with enable/disable.  I'm looking for set_rate.
Thanks for your help.
